Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-23-2008   #16 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
Re: Throttle Body swap.
stay on topic guys please! To remove this ad, register today for free or log in if already registered!
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Sponsored Links
Old 06-24-2008   #17 (permalink)
emjay
Super Member
emjay is a jewel in the rough emjay is a jewel in the rough emjay is a jewel in the rough emjay is a jewel in the rough
can someone touch on the y8 throttle body and fuel rail .. im doning a y8 intake mani swap but i wanted to know if i should get the TB and the fuel rail and run a return with the d16 rail ?? is that a good plan ? what are my other options im a newb to this kinda of mod please fill me in
__________________
boosted 1.7eL -- whp: classified
emjay is offline   Reply With Quote
Old 06-24-2008   #18 (permalink)
02fpcivic
Diamond Member
02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light
I think the y8 tb must be a tiny bit smaller than the d17. The reason I say that is because I had to do some moderate porting to the opening after I welded the flange on there. N/A wise, the D17 sized TBs are pretty dead on for the size of the engine, Honda has this funny thing about getting their specs right, hehe. I think you'd need some serious n/a mods to warrant a B series TB. If you need to you can take the D17 IAC valve off the TB and make it a remote mount like Andy did so you can use another TB and still keep stock idle control. Its pretty straight foward if you have some tools and skills.
__________________
JDM Fabtech
02fpcivic is offline   Reply With Quote
Old 06-25-2008   #19 (permalink)
j182j
Member
j182j's Avatar
j182j has a spectacular aura about j182j has a spectacular aura about j182j has a spectacular aura about
Thanks for getting back on topic. Do you have any pics or info on how he made the remote mount IAC?? Thanks
__________________
The Black And Green 83
School of choice: www.uti.edu
j182j is offline   Reply With Quote
Old 06-25-2008   #20 (permalink)
emjay
Super Member
would the d16 fuel rail work ?? if the TB's on the d17 is larger, shouldn't i use that?
__________________
Old 06-25-2008   #21 (permalink)
02fpcivic
Diamond Member
Yeah, but the bolt pattern is different. The y8 rail would probably work with older style injectors and clips. You'd probably need to convert to return if you cant find a safe way to block off the rail. I think andy used a plate that bolted to the iac valve with some npt fittings. You can run a hose from one side to a lil baby air filter or into your air intake for the inlet, and the other side to a vac manifold or the opposite side of the TB. All it really does is create a controled vacuum leak. Its much simpler than it sounds.
__________________
JDM Fabtech
Old 06-27-2008   #22 (permalink)
emjay
Super Member
ok .. so since im 100% getting the y8 intake manifold for more boost .. should i also get the TB and rail and go return? or keep my stock d17 tb and rail and convert that to a return ?
__________________
Old 06-27-2008   #23 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of
mother fucker!
__________________
02BLKCIVIC is offline   Reply With Quote
Old 09-15-2008   #24 (permalink)
gmcuajo
Member
gmcuajo can only hope to improve
Quote:
Originally Posted by j182j View Post
I have searched and cant find anything on this. I was wondering if anyone who has done the D16Y8 intake manifold swap has used a throttle body other that the D17 one? I want to use a larger one like off of a B series motor. I know that you would have to change the sensors and wiring but I was wondering if anyone had done this and got any gains from it?? Thanks
y8 manifold with k24 CRV throttle body and CRV sensors. It fit on the y8 manifold but with the cable to the firewall. Now I will use an adapter plate. You have open the port a little
gmcuajo is offline   Reply With Quote
Tags
2007 , 95 , body , cfm , civic , d16 , dx , honda , mustang , si , size , stock , swap , throttle , y8
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
