Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-05-2007   #1 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold
Send a message via AIM to dezod
Dezod Motorsports Tech Post: Boost Pressure (excellent read)
Ok. Some common misunderstandings and myths resolved. Let's start with the basics.
The atmosphere we all breathe and drive our N/A beater cars in are breathing normal air, which is standard atmospheric pressure that is contingent upon your altitude above sea level. With that being said:
Relative pressure-Pressure deemed over and above the atmospheric pressure. Example, "I run 6 PSI of boost"
Absolute pressure- Pressure including atmospheric pressure. An example is, when we where in FL, we where about 20 ft about sea level, so we where almost exactly 1 Atmosphere, ( I will get into the measurements later), and running 6 PSI of boost would mean: Atmospheric + 6 PSI of turbo pressure
Now for the specifics on pressure:
1 Atmosphere ~ 14.5 PSI ~ 101kPA~ 1 BAR
^^These are all approx equal!
With this useful information, I can know explain absolute pressure of 14.5 PSI + 6 PSI of pressure, which would mean 20.5 PSI of ABSOLUTE PRESSURE
Now that we know the equivalents of one another, we can easily convert amongst each.
IE: 1.7 BAR in relative pressure is approx 23 PSI ~ 160kPa.
:P
Now, that we understand that....Now the correlation of altitude comes into play. Recall as I stated before, that barometric pressure changes as altitude changes.....With that being said, at sea level or around there it is 101kpA. (Kilopascals, for those wondering ) Anyway, as the altitude increases the barometric pressure decreases because the air gets thinner. As a result, you will have a lesser base (atmospheric pressure) therefore will make less boost overall due to this fact. Understand?
At sea level, your pressure is 101kpa. So with 6 PSI of boost ~ 60 kpa that is ADDED to the 101 (speaking in terms of absolute pressure), is 160kpa. Great!
Now move to the 5000 ft above sea level (in the mountains or Denver), and it's approx 84kpa, which now means 6 PSI of boost ~ 60 kpa is ADDED to the 84, which means that it is 144kpa. This means you will see about 4 PSI on your boost gauge. This means LESS boost and LESS power on your boost gauge due to barometric pressure changes caused by altitude.
Questions?!??!
__________________
Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
7thgen Dedicated Section
Dezod Myspace
W: www.dezodmotorsports.com
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
dezod is offline   Reply With Quote
Sponsored Links
Old 10-05-2007   #2 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Re: Dezod Motorsports Tech Post: Boost Pressure (excellent read)
So you will need to crank the boost up as your altitude changes - albeit drastically like moving from Miami to Colorado Springs - in order to maintain the same power level right? How would this affect the AFRs?
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 10-05-2007   #3 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Quote:
Yes, correct.
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 10-05-2007   #4 (permalink)
tuningmycivic
Ultimate Member
tuningmycivic's Avatar
tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all tuningmycivic is a name known to all
Send a message via AIM to tuningmycivic Send a message via Yahoo to tuningmycivic
along the same lines as Clint's question, since there is less oxygen in the air at higher altitudes, not to mention less air in general, couldn't arbitrarily cranking up the boost also cause greater issues since you'd be dumping in more fuel, but not necessarily taking in a great deal more oxygen? or do we assume the O2 content per volume of "air" moved remains constant?
__________________
T.E.A.R.S. Member #5 All turbo builds end in T.E.A.R.S
My turbo build thread 169.39 WHP/157.15 WTQ
Quote:
Originally Posted by TRIZ View Post
you cant just add a k20 to a car like an extra plastic brick to your lego people house.
“Great pain is, as the teacher of great suspicion, the ultimate liberator of the spirit.” - Friedrich Nietzsche as quoted by Mark Twight of Gym Jones
tuningmycivic is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
