Forced Induction and SwapsPost information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Re: T.E.A.R.S. - Turbocharged Engines Anonymous Relief and Support Thread
My car won't stop leaking oil from a -AN compression fitting. At this rate I'll have a full new pan of oil every 8 days and the bottom of my car will NEVER rust.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
I hear that, Clint. Mine keeps leaking from the return line. I can't find the time to get under the car and find out what size the hose is. It's not attached using the standard drain, someone had welded on their own fitting and used this hose - which is now leaking out of the -AN fitting. I put 1 qt. in per week and it only leaks while driving so I never knew about it until my valvetrain got REALLY loud one day and I pulled over to discover I had ZERO oil left.
__________________ 7thGen.MT.C. Automotive Photography Guide BenArts
Formerly: D17A2 Turbo @ 9psi 193.96HP & 179.36 lb/ft
Currently: D17A2 Turbo @ 5psi Way too rich HP & Way too slow lb/ft
Well I had welded a -10 AN bung to my new (Edwin's old) steel pan to put the return bung in a better spot. Something got dorked along the way and my -10 AN fitting leaked from my -10 AN bung. Made no damn sense at all. Should have been as simple as 1+1=5. Nope, no such luck. I'm taking care of it though. New fitting on my original pan, doesn't leak (I've used it before) and am just waiting on some hose to install it.
__________________
need some help and input here ..... i am completly new to 4cyl and boost !! always been a v8 mustang guy and after all my buddies have converted to srt4's and wrx's i decided to buy and 05 lx and decided im gonna build a turbo kit. ill start with what i got so far ... hks manifold, 2.5 custom dp, 29/7/2.5 intercooler with all piping, oil feed adapter, all my couplings and clamps , fpr,
boost and air/fuel gauges , and a dash pod. OBVIOUSLY i still need to order a turbo, my manifold is setup for t25/t28 internal wastegate. any recommendations on a good turbo without breakin the bank? i dont want a cheap turbo but dont need the most expensive either ( this car is a just for fun toy) ... im gonna set wastegate to 6psi for now, so my big ? is (since ive never boosted a car before ) with only pushing 6psi do i need to upgrade my injectors, pump and ecu? i dont wanna half ass anything cuz i dont wanna constanly be breakin shit but at the same time i dont wanna go with anything that i dont really need.... any feedback from you guys would be awesome , appears alot of u guys are a really knowledgable group , and i just wanna do my best to avoid some of these horror stories ive read on hear lol . but yea please any response would be great or pm me . thanks fellas
chris
t.e.a.r.s member in the making
05 d17a
i just had a piece of alum piping welded to the pan where i had drilled the hole and ran a piece of rubber hose from turbo to pan no leaks and with a bit of alum heat wrap around the hose, it seems to be holding up pretty well that close to the DP
chris
05 d17a
i think the answers to your questions can be found in the turbo faq but i am not "the guy" on turbo sizes and specs. knowing that your manifold is made for a t25/28 def sets your left and right limits though. i upgraded to the rsx injectors and i'm only pushing 5 psi on a t3 super 60 and there don't seem to be any signs of running out of fuel at that level, but i've also read and heard that really anything more than that and the srt-4 injectors (clips will be needed and harness will have to be modded to accept them) are a good upgrade. big question here though is what will you be using for fuel/air management? little more info and a little more research and i think you should be able to get all the answers you need. hope this helps.
and hurry and claim your T.E.A.R.S. number before we have to give Clint a second one
well that was one of my biggest ?'s , im having alot of trouble finding a piggy back system or anything close to cheap ( and decent quality ) to go with for my air/fuel managment , so far all i bought was a aem fpr, and some gauges. other than that no injectors, fuel pump or anything for modding ecu.... any recommendations on a cheap but effective way to go ? thanks for the feedback greatly appreciated
go ahead and assign that t.e.a.r.s # cuz i know ill be needing it later lol
__________________ slow as shit............for now
Tony, you've been in too long....
Do a search for Justin's setup (boilermaker1), he's running a T25 snail on a built motor and has plenty of power to run around with. I just can't remember which turbo he's running off the top of my head.
Yes, you'll have to upgrade the injectors, and get a piggyback or full EMS, stock pump should be fine. Go with Tony's advice on the SRT-4 injectors (Ebay is your friend here) and your EMS isn't going to be exactly cheap. The AEM F/IC is about the best one going from a pricing and reliability standpoint (about $500). Sell the FPR unless you want to convert the fuel system to a return setup (not needed at 6 psi) and put it towards your EMS.
__________________
Quote:
Originally Posted by tfnaaf
why the compression fitting and not a single hose from turbo to pan?
Well... I wasn't the person to weld the fitting on to the turbo I bought, so... gotta live with it. It's a piece of steel braided line with the fitting on one end (turbo) and hack-sawed off on the other (oil pan). That end goes over a barbed fitting JB'ed into my oil pan with a clamp holding it on tight.
The hack-sawed end is the one that's fine.
