Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-22-2007   #1 (permalink)
supermex
supermex's Avatar
supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all
FAQ; D17 engine internals for turbo (up dated july 07)
Here is the only COMPLETE FAQ with real info on how to build your d17 the right way.
No short cuts where taked when building this engine, Sleeves, needed or not they are there doing their job.
All my parts where research and developed from scratch other than the obious (turbo,block, guard and,,, just it) I didn't purchase any bolt on parts.
The need of notching the D17 was first discovered and done by yours truly the same goes for the ARP studs, fuel system, intakes etc.
Pistons developed specialy for me by Racing Enginering out Florida and they have being already available since 2004
NOW THIS ENGINE IS ON A FULL STREET TUNED CAR. This engine is driven almosty every day for the last 3 years with no problems at all.
(exteremely relaiable)
Fully functional with A/C and all the amenities, the motor is done done no excuses here!
I was at NOPI 2006 in Atlanta and will go to NOPI 2007 I'm driving there and back to Florida like the last year for anyone that cares to check the car in person.
Well, I read all the stories of engines go bad after turbocharging.
I figured since some of you already bought the turbo kit and had a bad experience with the engine cause of improper installation or to much boost is time to rebuild.
If you are going to all the trouble get it done, then do it right with the proper internals.
I had my engine done in preparation for a turbo and I would like to share my experience with the project.
Project starting date Jan 03
First it will help to get a Honda Factory service manual, it will be your bible when building your engine
You can order one from Factory Manuals.com
Is better to get a motor to work with , keep your original as spare.
Q: Were can I find another motor?
A: By now you may be able to get one at the auto recyclers.
Try your local places or the website http://car-part.com/ there is a lot of places that will have one for sure.
I bought my block and head from a car that blew a head gasket after an accident and ran with it for awhile the insurance paid for a new one.
I got it for $600.00 back in 2003 now you may find them a lot cheaper.
Q: Can I use my own block?
If you didn't have a major malfunction that cracked the block or sleeves you may still use your own motor.
You may have a mechanic take it out of your car or if you have the tools and garage rent an engine hoist and do it your self.
Q: Once I have the block what do I do?
A: Since my stock engine was running fine and I purchase the block I was able to safe money by take in it apart in my garage.
I bought an engine stand for $80.00 an the Honda service manual for $100.00
It was very educational and a lot of fun striping that block bare.
I could do no harm since it was already messed up.
(note) save all the screws, bolts and extra parts you'll need them on the future.
Q:What parts do I need and were do I get them?
A: At the time there was no pistons or sleeves for this block so I hit the web and started calling manufacturers.
I found a place in Lake Worth Florida were they do research and design parts for well known manufacturers.
The place is call Race Engineering Tel: (561) 533- 5500 ask for Jonh if you call him, deffinately tell him I, Hector told you about them and he'll work you a discount also tell him about our 7thgencivic site.
Any way I took the bare block to him with a stock piston.
And they designed a full floating piston and had Wiseco build it.
(Full floating piston are pistons that use a losse connecting pin that attaches them to the rod as opposed to the pressure conecting rods from stock reducing friction,they are a bit noisy and rattle when the engine is cold)
At the time I went for a bigger size piston 76mm (stock 75.02mm)
Piston part # XT- 519P76 Wiseco 76mm 9:01 compression about $450.00
I check my compression at about 95 lbs after installing this pistons
(stock 135- 145 lbs)
Wiseco now makes 75mm pistons (stock size)
Tell them that you are turbocharging and they will recomend the right set of rings and gap clearence.
depending on how much HP and size of turbo you'll be using the type of rings will be suggested.
Heat will expand and contract this rings so gap and type of rings will make a difference if you are racing at the track of just if you just driving day to day
Definately talk to the ppl at Racing Eng. for your application
Sleeves part #DS-300-010 Darton flanged sleeve from a D16- 75mm
I had to bore this babes out to 76mm to fit my oversized pistons.
Skip this step if you are using 75mm pistons.
About $210 a set of 4
Rods where already available CR- BR3740B Crower Billet Honda 1.7 $600.00
The good thing about Racing Engineering is that they will give you all the specs and measurements that you need for the machine shop.
This sure helps if you are not a car guru.
Q: And theeeen?
Take the block and parts to a machine shop and give them the specs that you'll get from Racing Eng. along with the Honda service manual
The block will have to be bored to fit the sleeves about 78mm and the cranck shaft line honed.
Also make sure the shop resurface the top of your block so is nice and flat.
Sleeves pressed in and bore out to fit the size piston you choose 75mm or 76mm and the bottom of sleeves noched to make room for the crower bigger rods to clear ( bigger rods will touch the bottom of the sleeves as they turn up and down,
Block before sleeves
After sleeves:
I found this out the hard way half way into the install.
Q: Now that I have all done how do I put it all together?
A; I deffinately recomend getting a good shop to do the job.
Make sure they are proficient in Hondas and take with you the service manual and ask them to see it carefully and use all the torque recomendations.
I would also purchase a gasket kit and new cranck shaft bearings $160.00
Check the manual book to learn how to order your bearings they come in colors yellow brown green etc.There are numbers on the block and the camsaft as well as on the rods.
The bearings can be any combination of colors and almost unique to your block.VERY IMPORTANT!
I went OEM you may choose after market.
KMS Block Guard if you want one, $40.00 http://www.7thgencivic.com/forums/sh...ms+block+guard
The BG is an insurance against cathastorphic failure on your internals.
It sort of keeps thing togerher.
It works great on racing cars one 1/4 of mile at the time, but on a daily driver can get the engine overheated on hot days
(there has being issues with Block Guard heating up the head because it obstructs the free flow of water to the head)
So I modifed the BG to flow more water by opening the holes on a side to side configuration as shown below
Also I intalled a huge superthin front pusher fan placed between the intercooler and the A/C core Autozone $50.00
Now you can apply a Nippon head gasket sold at the dealership $40.00.
Follow up with a set of ARP heat studsARP headstuds
ARP part # 2084301 Honda D-16 HSK for 1.6 SHOC vtec application. 10 studs
NOTE: ARP makes two types Z&Y (OURS is Z) about a $100.00
Q: What about the head?
I had the head P&P and valves installed a month later (stage 3 regrinded cam a yers later 2007) and end up having a shop make an Intake manifold with a big throttle body 75mm
But that will be another FAQ all together.
P&P Head KMS
If I was you I would only have my head cleaned and a 3 angle valve job just to get the thing going again without spending more money.
Can always take the head out later and deal with it like I did.
Before the mechanic installs the engine I ask for a full day with it to polished the block and the head cover
YEAR: LATE 2004 ---My engine installed looks like this
Just need that turbo now. Sep 04
But I know that engine will take it for sure.
I didn't bother on dyno it cause of the low compresion configuration and would do good numbers.
Price for all the labor varies from shop to shop.
So get quotes before you start doing anything.
JUNE 2005--A year later
The engine was turbo charged
Precision t3 t4 .69 trim .48 exhaust
Tial gaste gate
Custom piping
Greedy boost controler
Greddy type S BOV
Then I got an equal lenght manifold builded by a local guy nicked name GATO
and had it ceramic coated.
Did the same with the turbo housings
It helps move the air smoothly as it twirles inside the turbo housings.
Update July 4-05
UPDATE JULY 2006 fuel system taking care off, the return line was installed, on the bottom left you'll see a canister that holds a liter of fuel ready
available for when boosting at WOT won't dry out your line.
A Walbro 240 intank pump and a Mighty might inline pump is installed on front with a custom made fuel rail with Precision 550 injectors
Working together with an Aeromotive fuel pressure regulator holding 40 lbs of pressure.
With all put together it looked like this
75 SHOOT OF NITROUS
Courtecy of NX
Fogger system on the Precision IC
IN 2007 was time to change the old stage 2 ACT clutch and replaced it with the ACT stage 4
Wtih all nitrous / alchy injection and nitrous systems working plus racing fuel 104 and boosting 21 lbs I was able to dyno the following numbers
Tunning with an AEM EMS
This is the final result
up until now July 2007 the engine is holding up and I haven't had any engine problems at all
Hope this will help future D17 builders.
Don't let anyone tell you that the D17 is not a good plataform
Is actualy a very durable engine when modified.
You'll have a unique set up.
If you do what every one else is doing you'll be just like every one else.
modifing the vic and representing Since 2001
__________________
MY SHOW CAR IS FASTER THAN MY JDM CAR...FOR NOW
NX & AEM sponsored car.
2004 HONDA TUNING featured car.
1st Place at NOPI Nationals 2006
1st Place Funk Master Flex 2007
1st Place HIN's Night Shift 2007
434.3 hp 352 Lbs torque @ 21 Psi fully build D17A1
CARS WEBSITE
DRIVEN!
supermex is offline   Reply With Quote
Sponsored Links
Old 07-22-2007   #2 (permalink)
bullet02ex
Senior Member
bullet02ex's Avatar
bullet02ex will become famous soon enough bullet02ex will become famous soon enough
Send a message via AIM to bullet02ex
Re: FAQ; D17 engine internals for turbo (up dated july 07)
great post +1 for taking the time to post this. and def one of the nicest 7thgens I've ever seen
__________________
N/A EM2 Crew Don’t jump on the turbo bandwagon!!! Go Naturally Aspirated Baby
-Once A 7thGener, Always A 7thGener
-BulletEX-
bullet02ex is offline   Reply With Quote
Old 07-22-2007   #3 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Pretty good, but you left out the chapter on what you've been tuning with, pushing the rev limiter to 8750rpm's doesnt happen with the flick of a switch, niether does the 430+hp (thats a vtechless d17a1 your boosting as well - which is def worth mention). That torque curve is amazing btw. Also, doesnt your aluminum oxidize after a month or so- what are you sealing it with to prevent that, if anything?
TRIZ is offline   Reply With Quote
Old 07-22-2007   #4 (permalink)
supermex
supermex's Avatar
Quote:
You know,, you are right
Is soo much info I left out
I use AEM EMS and I didn't took any pics of the install of it
Other that fitts snuggly in the back of my glove compartment.
The aluminun is oxidizing already, I just keep polishing the parts that are visible that I can reach with a power drill an extention and a wire brush attached to it.
__________________
CARS WEBSITE
DRIVEN!
Old 07-22-2007   #5 (permalink)
05CivicSprayin
New Member
05CivicSprayin's Avatar
05CivicSprayin is an unknown quantity at this point
I'm also on planning to build up an a1 w/o the vtec conversion, but was wondering how much it ran you to regrind down the cams to fit and who did the job for you.
05CivicSprayin is offline   Reply With Quote
Old 07-23-2007   #6 (permalink)
supermex
supermex's Avatar
Quote:
I had mine done localy, but the stage 3-4 cam is already available.
Do some reseach or contact Dezod or Crower.
The regring is making of a whole cam they don't take your actual cam and grind it down.
They take your original specs them find out how much power you want to make then they make it according to that.
Has to do with valve lifting duration time.
__________________
CARS WEBSITE
DRIVEN!
Old 07-23-2007   #7 (permalink)
burke420
The World Is Yours!
burke420's Avatar
burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned burke420 should not be questioned
Send a message via AIM to burke420
good work and hope to see it again this year Hector! i like it! i wanna hear this in action...
__________________
I MY Honda
Enkei RPF1
Type 1 Racing SPL exhaust
TEIN Hood Damper
Cusco front strut bar
FUNCTION7 LCA
burke420 is offline   Reply With Quote
Old 07-23-2007   #8 (permalink)
TRIZ
TRIZ's Avatar
I shoulda guessed AEM being your sponsered by them.
Oh, and I typed vtecHless, lol... hope no1 caught that- shit, well they all did now.
I'm going to have to look around for something to take care of the aluminum... has to be something out there. I'll hit u up if anything amazing surfaces.
Old 07-24-2007   #9 (permalink)
supermex
supermex's Avatar
AEM is the shish!
Let me know what you find out.
__________________
CARS WEBSITE
DRIVEN!
Old 07-24-2007   #10 (permalink)
Civicman1988
Ultimate Member
Civicman1988's Avatar
Civicman1988 is a glorious beacon of light Civicman1988 is a glorious beacon of light Civicman1988 is a glorious beacon of light Civicman1988 is a glorious beacon of light Civicman1988 is a glorious beacon of light Civicman1988 is a glorious beacon of light
there a place up here in Michigan that does aluimunum work and they say to polish it up and put a clear coat over it. I did it on my lower control arms last year never had to do them again. I still have 3/4 of a bottle left if anyone wants anything cleared i will do it for you
__________________
Don’t knock it, till you try it. That what i say about my D17
DIY: Shave Front license plate
http://www.7thgencivic.com/forums/sh...d.php?t=280175
Civicman1988 is offline   Reply With Quote
Old 07-24-2007   #11 (permalink)
supermex
supermex's Avatar
Quote:
I did clear coat my engine the first time and it got yellowish after a month or so. I used high temp paint.
turbocharged engines run hotter than normal.
Try it on a part close to the heat like valve cover or so and let us know how that works out.
By the way how is your intake manifold project turned out?
Any pics?
__________________
CARS WEBSITE
DRIVEN!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
