Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-17-2007   #16 (permalink)
ronaldo9
Platinum Member
ronaldo9's Avatar
ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned ronaldo9 should not be questioned
Send a message via AIM to ronaldo9
Re: Wideband Sensors Explained
That is a gauge type wideband aem uego.
ronaldo9 is offline   Reply With Quote
Sponsored Links
Old 07-17-2007   #17 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
The PLX can substitue the NB sensor but it was much easier for me to just weld in a 3rd bung and not worry about it
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 07-17-2007   #18 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned
Send a message via AIM to andyman97 Send a message via Yahoo to andyman97
Quote:
I agree. I tried to wire in the narrowband wire and use the wideband in place a long time ago when I was running a stock ecu and I never managed to get rid of the CEL for the primary sensor. Not to say it can't or hasn't been done but its a PITA.
__________________
02 Civic d17a2 turbo
490 whp/360 tq @ 31 psi
-If you pm me and I don't respond, it's because, either:
a) Your question is stupid
-or-
b) it can be found by searching if you'd quit being lazy
andyman97 is offline   Reply With Quote
Old 07-24-2007   #19 (permalink)
03-Acura-1.7-EL
Platinum Member
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light 03-Acura-1.7-EL is a glorious beacon of light 03-Acura-1.7-EL is a glorious beacon of light 03-Acura-1.7-EL is a glorious beacon of light 03-Acura-1.7-EL is a glorious beacon of light 03-Acura-1.7-EL is a glorious beacon of light
Is this chart specific to 2001+ Civic or for any OBD-II?
__________________
Yes, t-25 @ 9psi
Video of my Turbo Acura: http://www.civicforums.com/forums/79...turbo-run.html
If you dont know how to repp users, then PM me!
03-Acura-1.7-EL is offline   Reply With Quote
Old 07-25-2007   #20 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
No, its the general (generic) voltage operating range of most any narrowband sensor.
__________________
-or-
Old 07-25-2007   #21 (permalink)
03-Acura-1.7-EL
Platinum Member
Does anyone have the o2 voltage operating band for the 7th gen?
...Also, on additional note... anytime when I have ignition on my AM radio starts to interfere, it was OK before I installed my AEM wideband.
Has anything like this happened to you?
__________________
Yes, t-25 @ 9psi
Tags
afr , diy , wideband
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
