Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Reload this Page
Opinions on my Goals - 03' EX
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
LinkBack Thread Tools
Old 06-12-2007   #1 (permalink)
Soldja210
New Member
Soldja210 is an unknown quantity at this point
I have an 03' Civic ex stock, and I have a dream...
My bare-bone goal for this Civic is 300 whp with decent torque(atleast 220)
I don't really care about track times, I'm more into the show aspect of Imports. I want to produce a real clean cut show car with decent power to shut the mouths of haters.
After reading oh so many posts on "swaps vs. turbo", "K20a2 vs. K20a3", and so many others.... I'm still stuck in my plans. I have went from wanting a B18C, to a K20a2, to staying with my D17A2 all in one week; not to mention the age old question of NA or FI.
I need your Opinions... Opinions of people who have actually done swaps, turbos, or combos of the two. Money is not a factor in this discussion although please do posts your budgets... just know that I'm not looking for the cheapest way around things.
Oh... and hi to all prior members or civic forums. I'm new and have learned so much from your all too interesting threads.
Soldja210 is offline   Reply With Quote
Sponsored Links
Old 06-12-2007   #2 (permalink)
RHCP0801
RHCP0801's Avatar
Re: Opinions on my Goals - 03' EX
RHCP0801 is offline   Reply With Quote
Old 06-12-2007   #3 (permalink)
gsniper666
Senior Member
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
personally i think u would get the most respect on a n/a setup on the d17.... its something we have all talked about.... turbo would be interesting... but you would be pushing it if it were to be a daily driver.... the k20 swap would work very well with your goals and is the simplest way to go at it... but that is the fact... its the easiest......
i think it would be better if you also said if it was a daily driver or not... how much u would deal with in driveability
gsniper666 is offline   Reply With Quote
Old 06-12-2007   #4 (permalink)
hwt101
Super Member
hwt101's Avatar
hwt101 is an unknown quantity at this point
the baddest 7thgen in the world ( and the fastest i believe) has a b18 in it and a spoiler, but yeah if you ahve the money and the time do a NA build the right way ( although getting 300 is very UN realistic) a stage 3 cam, 12.1 or higher compression over bored pistons, crower maxi light rods, arp head studs, sleeves, hondata or aem, and some major port and polishing done with a flow bench. Now if you really want to be custom and your car happens to be an 01 they did make an H22 prelude that year and that has not been done in our cars as far as i have heard and it would be SICK starting out with 200 is a nice number to build on and its a very strong motor(trust me i get to ride in an h22 w/12psi on it and it is fast )
hwt101 is offline   Reply With Quote
Old 06-12-2007   #5 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to behold
I think this topic is worthy of being open for a while- it has potential to become a good thread with peoples budgets- we know how much a k swap costs, but internal mods and tuning time included usually get left out. Same goes for an NA setup- either you get the price, or you get the numbers. This could become a good info block.
I'd like to see you go for getting 300 NA. You will almost have to turbo it to get that much, but maybe you got some ideas no1s thought of before, maybe.
Good luck with the build/swap.
TRIZ is online now   Reply With Quote
Old 06-13-2007   #6 (permalink)
dcoffman07
New Member
dcoffman07 is an unknown quantity at this point
What I want to see is a NA 300h/p daily driver...i'm sick of FI engines. The best way to do it I think would be an engine swap with K20/24 and build the hell out of it!
dcoffman07 is offline   Reply With Quote
Old 06-13-2007   #7 (permalink)
TRIZ
TRIZ's Avatar
I thought you wanted an NA D17. You'd probably be able to hit 300 NA with a swap for sure. Our engine is pretty stuborn though- with other engines you change the header and get 30hp, with ours you get.. 4hp at best?
Old 06-13-2007   #8 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questionedspeedfoos should not be questioned
Quote:
I'm not.
A 300 whp NA D17 would be pretty close to impossible. All depends on your what you want to end up with. A 7th gen with a different car's engine in it, or truly built D17. My personal opinion is to go for something different, maybe a supercharged D17? Those are not common, and to my knowledge, no one makes a "bolt-on" kit for the D17. If money is no object, that would be a pretty unique mod and may have the added benefit of gaining some support for a manufacturer to carry one. Just a thought.
speedfoos is online now   Reply With Quote
Old 06-13-2007   #9 (permalink)
Soldja210
New Member
OK... I have a few questions.
1. If I start out NA with a swap, and get pretty far into the building process... could I still go FI without scraping all my previous work.
2. What has more potential for build; B18C5, K20A, or H22A(haven't seen too much discussion on this one)
3. TRIZ - when you say " Our engine is pretty stuborn though " , what engine are you referring to? (Oh and nice tracks )
4. Thoughts on the supercharger post.
Also to clarify... this will not be a daily driver... but the occasional cruiser of course.
Old 06-13-2007   #10 (permalink)
gsniper666
Senior Member
gsniper666's Avatar
you could go forced at any point.. but things would have to be chanced... such as camshafts for n/a to turbo.... headers would be eliminated.... a bunch of stuff would change.... and u'd be throwing away some money if it wasn't considered correctly....
the b18 is not a direct swap.... the k20 is most likely ur best choice as it has the highest potential... you could also consider the k24 head on the engine as well.....i don't know about the h22... so ill leave it to someone else.....
the engine he is refering to is the d17a1 and the d17a2.. its a good engine... but bad for modifications... the engine runs good only on low boost unless heavily modified and it is mostly unresponsive to mods.... an i/h/e would really only yield about 10 hp for us....
a super charger would be the most original... i have seen some talk on here... but no follow through... it would probly open up new possibilities for the rest of us also.. it could be done... and there are some people around here that know enough about the engine to help you out
Old 06-13-2007   #11 (permalink)
ronaldo9
Platinum Member
ronaldo9's Avatar
ronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questionedronaldo9 should not be questioned
I'll make this really simple. The only way you can make 300hp on a d17 is with a turbo. 10+ pounds on a nice t3/t4 (stick to dezod) with some big injectors (SRT4) and good fuel management (EMS/Kpro) and a nice turbo cam (stage 2 or 3) and voila; say hello to 300hp. If you want to swap you'll still need forced induction whether it be a supercharger or turbo to make 300 hp. Only thing swappable in a 7th gen is a k series engine plain and simple.
ronaldo9 is online now   Reply With Quote
Old 06-13-2007   #12 (permalink)
hwt101
Super Member
hwt101's Avatar
not true ronaldo, the K swap is u a huge PITA swap the only diff. between it and a b18 swap is that people make brackets and a "wiring Harness' for it, the 01 gsr can be swapped with custom parts made and your own wiring, also never heard of the h22 going in our cars so clearance might be an isssue but if not it would be sick and original, and as far as i knwo you DO NOT put the k24 head on a K swap you use the bottom end of a k24 w/the k20 a or a2 head on it for the frank swap. Also you dont have to have forced induction on a B or K or H for 300hp it can be built and tuned NA and reach that number, but i think on a show circuit turbos/chargers get you more poitns especially w/a swap
Old 06-13-2007   #13 (permalink)
ronaldo9
Platinum Member
ronaldo9's Avatar
Hwt101 I'm not debating whether other engines can be swapped but you must agree the only user friendly swap is a k series and yes it is a PITA. The most I've seen N/A on a track car b18c was 250whp. On a K it won't be that much higher. Bolt-ons will not get you to 300whp on a k series. You'll need serious internals to do that including PnP head work and such. I guess I'll rephrase my statement. The EASIEST way to make 300whp is with forced induction.
I will also add swapping in a b18 or h22 will be illegal since you have an 03so those engines are out of the question for your goals. This topic has been exhausted but I hope I have given you things to consider.
Old 06-13-2007   #14 (permalink)
gsniper666
Senior Member
gsniper666's Avatar
my bad on the confusing the k24 and k20 head.... it was a mistake.... but i've seen numerous members on here with the t3/t4 hybrid turbo running over 300 boost.. its just that u need to run a bunch of systems... like the one guy on here with a hybrid turbo that running like 340 hp with a 75 shot of nos
Old 06-13-2007   #15 (permalink)
DaMadScientist
Pwning Noobs 24/7
DaMadScientist's Avatar
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
lot of misinformation
About the B18C5, and B series motor can be fit into our cars, it has been done, you need to weld up custom motor mounts, hwt101, needs to read more, mounting the tranny is all custom as well as running all the shifter cables is and you need to do some custome fitting for the tranny.
The most hp out of a N/A B18C was 320 HP, the car ran low 10's i believe, there is a thread on HT about a guy who is building a 300 HP B18C, before hand it was 265 HP daily driven, alot of work, custom parts out the wazzo
300 HP on a SOHC especially ours, its not nearly impossible...it is impossible, impossible is not the word...its more of unattainable
DaMadScientist is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY -- Installing SF Turbo kit
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
It has arrived !!!
K20z1 Swap/Turbo in process.
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
