Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-18-2007   #31 (permalink)
j182j
Member
j182j's Avatar
j182j has a spectacular aura about j182j has a spectacular aura about j182j has a spectacular aura about
Re: Found a DIY for the d16y8 Intake Manifold swap
so this will not work like the DIY said you have to either run a stand alone or change flanges to get around the egr equalling ports?? To remove this ad, register today for free or log in if already registered!
j182j is offline   Reply With Quote
Sponsored Links
Old 09-18-2007   #32 (permalink)
02fpcivic
Diamond Member
02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light
IDK I never had the stock ecu in. What I did was pull that coolant barb out of the flange and weld a plug in its place, when my EGR was hooked up it never leaked but I'm sure it wasnt functioning properly. I doubt it would hurt anything, the computer probably cant tell the difference but I wont give a definete answer on that.
__________________
JDM Fabtech
02fpcivic is offline   Reply With Quote
Old 09-19-2007   #33 (permalink)
lovelyangelgirl
New Member
lovelyangelgirl is an unknown quantity at this point
I wonder after you trim everything the y8 intake manifold just bolt right in ?
lovelyangelgirl is offline   Reply With Quote
Old 09-19-2007   #34 (permalink)
j182j
Member
j182j's Avatar
Cool thnaks for the help what TB are you running I was wondering if older TB fit the D16 intake (EX-GSR or and b-series)
Old 09-19-2007   #35 (permalink)
02fpcivic
Diamond Member
I welded a flange on for the D17 tb and all the stuff to bolt right up. I needed to make a custom throttle cable bracket too. I even went so far as to put a MAP sensor bung in there to use the factory map sensor for the guy that bought it. I kept the cruise control too so I was pretty happy about that.
__________________
JDM Fabtech
Old 10-03-2007   #36 (permalink)
7thgen.nick
7thgen.nick has a spectacular aura about 7thgen.nick has a spectacular aura about
I remember a DIY on the EGR bypass setup....
7thgen.nick is offline   Reply With Quote
Old 10-03-2007   #37 (permalink)
skipbarber
skipbarber's Avatar
skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all
Send a message via AIM to skipbarber
you can remove the EGR by getting a D17a1 thermostat housing. a1 and a2 heads are both setup for EGR, but the a1 doesnt have it, so the thermostat housing just isnt flanged for it. voila, factory block off plate. this will throw codes if you arent using a stand alone, however.
__________________
sig by speedfoos
The DX resource site.
-2002 SSM EM2 - D17A1/A2 hybrid turbo(vtec, non-egr, steel oil pan, Hondata managed) 240 fwhp, 210 lb/ft tq @ 9.5 psi
-1991 MK3 Toyota Supra turbo (full cage, track setup) TBA
-2008 Honda NPS50 Ruckus - Stock 5 rwhp
skipbarber is offline   Reply With Quote
Old 10-03-2007   #38 (permalink)
7thgen.nick
dont you just make the 2 tubes come together so the fluid will still circulate and then close off the flanges on the TB? why would that throw a code, the fluid is still flowing and i believe that is what its lookin for. its just there to thaw the TB if your in cold temperatures.
Old 10-03-2007   #39 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
It's not the TB we're talking about here. It's the EGR (Exhaust Gas Recirc) channels on the back of the D17 injector plate and the corresponding port on the intake mani and tstat housing like Edwin was talking about. You're thinking of the TB coolant lines. Two completely different things.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 10-03-2007   #40 (permalink)
7thgen.nick
ohhh, shit, right on... well im havin a prob with that too, lmao... and i already got a CEL up for that one.... i guess i lost pressure on the exhaust side upgrading to 2.5" and its been throwin a CEL ever since. Any way i can fix that?
im assuming when i hook up my emanage and remove the AFC2 that my vtec is no longer going to work because the ecu will be controlling the vtec again and not the afc controller.... damnit
Old 10-03-2007   #41 (permalink)
speedfoos
speedfoos's Avatar
Which DTC are you throwing? Changing out the exhaust to whatever diameter shouldn't throw a code at all. Unless you ditched the cat and aren't running an o2 simulator.
__________________
www.7thgenhonda.com
Old 10-03-2007   #42 (permalink)
7thgen.nick
yah, i ditchd the cat and have defoulers on the plug, so i got rid of one CEL code... now its flagin the EGR valve problem...
Old 10-03-2007   #43 (permalink)
7thgen.nick
for those that dont know...
Exhaust gas recirculation (EGR) is a NOx (nitrogen oxide and nitrogen dioxide) reduction technique used in most gasoline and diesel engines.
EGR works by recirculating a portion of an engine's exhaust gas back to the engine cylinders. Intermixing the incoming air with recirculated exhaust gas dilutes the mix with inert gas, lowering the adiabatic flame temperature and (in diesel engines) reducing the amount of excess oxygen. The exhaust gas also increases the specific heat capacity of the mix lowering the peak combustion temperature. Because NOx formation progresses much faster at high temperatures, EGR serves to limit the generation of NOx. NOx is primarily formed when a mix of nitrogen and oxygen is subjected to high temperatures.
Tags
civic , d16y8 , dx , dyno , forums , fuel , intake , manifold , metal , performance , pressure , removal , sensor , sheet , swap , tank
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
