Quote:
Originally Posted by subworm07 sorry for bring back and old tread I did this swap and yesterday I changed the engine harness to the manual one as well as the ECU and the ignition because i got the key for the ECU. but now my car doesn't want to start I am still using the Auto Dash harness and found out I need to connect the Clutch Pedal I know I have to ground one but what do I do with the other wire please help. |
you just loop the two thicker black wires to the clutch pedal sensor! (the top sensor on the clutch pedal)
now i need help on wiring the car to PARK/ to remove the key... i also sent you a pm
