Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-01-2006   #46 (permalink)
MajinB
Drunken Master-7thgen Ninja
MajinB's Avatar
MajinB is a splendid one to behold MajinB is a splendid one to behold MajinB is a splendid one to behold MajinB is a splendid one to behold MajinB is a splendid one to behold MajinB is a splendid one to behold MajinB is a splendid one to behold MajinB is a splendid one to behold MajinB is a splendid one to behold MajinB is a splendid one to behold
Send a message via AIM to MajinB Send a message via Yahoo to MajinB
dude its cause they can afford it/got sponsored. give me a break. if i had 2k to drop on a ECU then i would get the EMS. duh. not everyone can afford it. To remove this ad, register today for free or log in if already registered!
__________________
Quote:
Originally Posted by white2K2EX
As I've said before, hp/l is a ricer measurement.
myspace /my fogs /my drop/ CF hood/ Megan catback / suck at sleeping crew #8
MajinB is offline   Reply With Quote
Sponsored Links
Old 06-01-2006   #47 (permalink)
Hwoody77
Diamond Member
Hwoody77 can only hope to improve
Send a message via ICQ to Hwoody77 Send a message via AIM to Hwoody77
Quote:
Originally Posted by XSRCivic
there's a reason why so many turbo/all motor guys go with stand alone units. Even those with "mild" setups use the EMS. It will produce more power over the emanage anyday. Ask Andyman97,SuperMex & 02fpcivic our 3 top turbo members why they switched to the EMS.
Prove it.
Of course an EMS is better unit and will ultimately gain more power. I am not denying that.
The reason people switch to standalone is because they have more extreme set-ups, bigger injectors and more boost.
Now in MY case, which is my argument, I don't need an EMS. And yes, an EMS might gain a tad bit more power in MY case, it would not be worth the extra money.
I don't see how an EMS can do THAT much more power.
I'm talking basic mechanics here.
If engine one does 12.0 AFR throughout the powerband on a boosted motor with an EMS and the same engine does 12.0 AFR throughout the powerband on a standalone the horsepower will be the same. To tell me it won't be is denyng basic logic.
For example.
Let's say Injector A requires 5 V of power to run @ 100% Duty Cycle, which will give you a nice 12.0 AFR throughout the powerband (This would almost never apply in real life, but just for arguments sake). This is on a EMS.
Now, without changing the parameters I want to acheive the same effect with a piggyback.
So I need to get it to 5V to acheive that 12.0 AFR.
5V is 5V no matter what, it dosen't matter if it hacked, or modified, who cares you are doing the same thing.
It's the OTHER features that an EMS has that allow it to give more power.
BUT in a midly built D17, like MINE, you won't see much of a power gain.
Quote:
the difference in a 12.5 afr on the emanage and 12.5 afr on the ems is a consistant afr one where the computer isnt consistantly trying to over and under compensate becasue its doesnt get a real reading just a hacked signal
You have no idea what you are talking about.
Do you know what Closed loop is?
One more time, in closed loop the factory ECU does not "Over and under compensate". Is it THAT HARD to understand?
Hwoody77 is offline   Reply With Quote
Old 06-01-2006   #48 (permalink)
SODJAZERO
Diamond Member
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Send a message via AIM to SODJAZERO Send a message via Yahoo to SODJAZERO
so, have you encountered any problems of the ecu causing conflicts with the emanage?
__________________
"when I was younger I used to faint at the sight of blood, now that I'm older I noticed it ain't at the sight of blood, now the sight of blood equals the very sight of love, menstrual cycles feelin' like you right at your height of drugs" - TECH N9NE
_____________________________________________
183whp 175tq @ 7psi
Fs: Sony Ericcson W600i Brand New In Box 220 Shipped, price drop
SODJAZERO is offline   Reply With Quote
Old 06-01-2006   #49 (permalink)
familycar
Ultimate Member
familycar's Avatar
familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all familycar is a name known to all
Quote:
Originally Posted by Hwoody77
Prove it.
For example.
but at part throttle the ecu isnt in closed loop. just at WOT. and at part throttle that is where a real tune from an EMS comes into play with MAPS. a hacked signal doesnt give a consistant afr at least no where near the EMS. as in a previous post in this thread which i am not going to explain again it takes an undercompensation for the sensor to make an adjustment then it over compensates. that is the bottom line. and as i stated many many times now it may not be your choice but several times now you have stated it wont give a better tune. now in your past post you say it will. so which is it? it seems you cant even make up your mind let alone understand why there is a difference. oterwise everyone would run emanage on every vehicle and ther would be no need for stand alone units. your fighting a dead horse man and now you back peddling from your previous statements. and trying to correct an emanage user XSR. you want proff go look it up. we dont need to provide you the info we had to learn and look it up ourselves. so you go post in every thread that other users have posted in showing dyno number difference going from emanage to EMS and gained power and tell them its BS. you arent doing anything here besides making yourself look dumb by trying to argue with fact. and after its been said by numerous people you are retracting your statement but still want to argue. what is your deal man????
familycar is offline   Reply With Quote
Old 06-01-2006   #50 (permalink)
ncirom2003
ncirom2003's Avatar
Send a message via AIM to ncirom2003
Quote:
Originally Posted by familycar
it probably is, but that doesnt mean you cant get more power out of an EMS tune than you can with a emanage tune. which is his whole argument and is incorrect. its a stand alone for a reason it is a much better way of tuning and that is a given. his whole trip is he cant get more power by tuning with a EMS which is complete bull shyt. not to mention that 95% of people who do end up boosting also end up turning up the boost after a while. taking that into consideration if you looking for more power than EMS is the best option especially considering that becasue of the fine tuning it will allow ytou to increase the boost higher than the emanage will allow you to tune. there are only so many sensor adjustments you can make. a map is a way better way of tuning. that is why i am just not going to argue with the guy. he knows all so who am i to correct him? LOL
are you referring to me? because if so you need to chill out and re-read my post.
__________________
03 nissan 350Z
02 honda civic turbo----for sale, check below.
TURBO AND ELECTRONIC GOODIES FOR SALE.
I NEED TO SELL ASAP SO I HAVE LOW LOW PRICES.
[/color]
http://www.civicforums.com/forums/19...ool-d17er.html
MYSPACE
ncirom2003 is offline   Reply With Quote
Old 06-01-2006   #51 (permalink)
familycar
Ultimate Member
familycar's Avatar
Quote:
no no that is too hwoody77
Old 06-01-2006   #52 (permalink)
Hwoody77
Diamond Member
Ok, you are contradicting yourself.
You said
Quote:
you will gain more power with a EMS tune rather then the emanage.
Quote:
witched from emanage to ems and saw a significant increase in power
Quote:
you can see if the afr how its always over and under compensating
Quote:
will not give a linear fuel curve because the emanage cant give the right adjustment it always over compensates
Quote:
and you can clearly see through a dyno or datalog how much smoother and better a stand alone is.
Ok.
What are you talking about?
You are making no sense.
Because of fine tuning you can increase the boost levels, now that is pretty much only done at WOT.
Adjusting fuel at anything other than WOT will not allow you to increase boost levels.
Then you say
But I'm not talking about part throttle, last time I checked I'm talking about making power at WOT, and obviously you aren't either because you said
And when a car is dynoed that is WOT.
Guess what buddy. A dyno chart is for tuning at WOT, where if you know what you are doing you will can get a consistent AFR whether you use an E-Manage or an EMS. Which is my original argument.
Ok so now your talking about part throttle again...where EVERY ECU over and under compensates. Your factory ECU does it, your Piggybacked ECU does it, and guess what...so does the EMS!
Maybe you should learn the different between WOT, closed loop, open loop, part throttle and what your ECU is doing during those times.
Now.
I've been on these forums for WAY longer then you have. So don't tell me
Because I've read it all.
Why don't you show me where someone gained power from just switching a E-Manage to standalone in a EM2 on this forum.
You can't, I promise.
So to recap.
I am stating WOT tuning, which is where people tune at.
You are saying that an EMS is better then an E-Manage because it dosen't over and under compensate...
But that's not what's happening at WOT.
So then you say part throttle, but people don't dyno at part throttle...?
BTW you still have avoided answering anything about the following wrong statements.
"the ultimate isnt too much differnt than its predecessor blue, besides having a few more options. the way it hacks the signal is still the same"
"plenty of people that have tried the emanage have relayed that they we unsucessful in raising the rev limiter as well as people like DEZOD"
BTW...
Quote:
ultimate will not give a linear fuel curve because the emanage cant give the right adjustment it always over compensates and then has to correct the over compensation and undercompensate. this is the way a PIGGYBACK works. and you can clearly see through a dyno or datalog how much smoother and better a stand alone is.
This is how ALL ECUs work buddy.
AND I haven't backpeddled anywhere in this thread. Go reread what I wrote and then go read some more on ECUs so you can understand how they work.
Old 06-02-2006   #53 (permalink)
MajinB
MajinB's Avatar
damn guys what a way to kill his thread.
__________________
Old 06-02-2006   #54 (permalink)
familycar
Ultimate Member
familycar's Avatar
seriously, i am tired of fighting its getting really old to sit and have to repeat myself time and time again its old. so im done , its not worth it you do what you want. that is how its going to be any way and the original argument has now been skewed becasue he doesnt like to be wrong. he is doing everything he can to make me look like the one who is wrong when this whole arugment started because he says you cant get a beter tune with EMS than you can with emanage. so since we all know that is wrong i am not going to participate in this any more. its worse than talking to a 3yr old which i am used to considering i have one.
Old 06-02-2006   #55 (permalink)
Hwoody77
Diamond Member
Surrender noted.
Old 06-02-2006   #56 (permalink)
ncirom2003
ncirom2003's Avatar
owned
Quote:
Surrender noted
counter-owned
__________________
03 nissan 350Z
[/color]
MYSPACE
Old 06-02-2006   #57 (permalink)
MajinB
MajinB's Avatar
owned
counter-owned
__________________
Old 06-05-2006   #58 (permalink)
familycar
Ultimate Member
familycar's Avatar
Surrender noted.
the only thing i surrendered are deez nutz on your chin, as i stated before i am not going to continue to repeat myself. it honestly feels like i am talking to my 3yr old. all you want to do is argue and its not even about the same subject. you keep trying to change things up so you can seem like you right but the fact will remain the a EMS tune> emanage tune any day any time 24/7/365!!!
Old 06-05-2006   #59 (permalink)
ncirom2003
ncirom2003's Avatar
so on leap years, which one is better?
__________________
03 nissan 350Z
[/color]
MYSPACE
Old 06-06-2006   #60 (permalink)
familycar
Ultimate Member
familycar's Avatar
i find that as long as your in the leap year it doenst effect anything but if your not then it changes everything sometimes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
E-Manage Ultimate... Hwoody77 Forced Induction and Swaps 25 05-18-2007 05:52 PM
Checking interest: E-manage Ultimate PnP & some other goodies dezod Forced Induction and Swaps 41 10-22-2005 07:47 PM
E-Manage Ultimate is now here! dezod Honda Civic Retail Sales 8 09-12-2005 10:16 PM
e-Manage Ultimate TheSmuggler Forced Induction and Swaps 9 08-02-2005 08:49 PM
Installed my e-Manage today and... Hwoody77 Forced Induction and Swaps 27 11-02-2004 11:29 AM
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
