Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-04-2006   #1 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold
Send a message via AIM to dezod
E-manage: Clearing up myths and such.... |Dezod Motorsports LLC|
E-manage per GReddy:
e-Manage is an inexpensive programmable fuel management system that allows you to properly tune your factory fuel system without having to change the entire factory ECU system to an expensive "stand-alone" unit. The e-Manage system is a universal "piggy-back" type unit which taps into most Japanese factory ECU wiring, by utilizing the existing sensors. Basic functions will allow the user to slightly alter factory injector duty-cycle (± 20% at 5 preset RPM points) by intercepting and altering airflow or MAP sensor signals. For Honda VTEC cars you can adjust the VTEC shift point. Additional features are built into the system but are only accessible through the use of the e0-1 programmer or our PC-Windows based "e-Manage Support Tool" communication software (Please see our Authorized GReddy Support Dealers for more information). There is a 16x16 airflow adjustment map, larger main injector correction adjustment, upgrade air flow meter adjustment, boost limiter cut, anti-engine stall, VTEC-fuel adjustment, real-time map trace, real-time display, real-time communication and basic Data-logging. With the use of our "Optional Injector Harness" and the software, the unit has the ability to control an additional 16x16 injector duty cycle map and the controls for adding up to 2 additional sub-injectors. If the "Optional Ignition Harness" and the software are used the unit has the ability to control a 16x16 ignition timing map. All of the above maps can also be map-traced in real-time as well. If the factory range of map or airflow meter is surpassed, you can incorporate our "Optional GReddy Pressure Sensor and Pressure Harness" to set larger scales of adjustment. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some functions may not be compatible with some applications.)
E-manage in Laymans terms:
To put it bluntly, it is a dumb box that does what you tell it to do. It changes/modifies what signals are sent and received by the stock ECU. It has a couple of good options like a voltage clamp, VTEC adjustment (doesn't work well on the D17), injector correction factor, ignition timing adjustment....These options all make it one to have, and a worth while quasi-EMS for your money. The unit runs $300, and the harness are all extra as well as the support tool (which is required to tune the e-man with a laptop).
It has a fair amount of data-logging, but I feel is a bit inadequate overall. It is fair enough for a novice though.
What it does and how it does it:
We have gotten excessive amounts of calls from various dyno tuning shops from around the world tuning turbo D17s and asking tons of questions and having concerns. This lead us to this FYI....
The e-manage adds and subtracts fuel through manipulation of the MAP sensor voltage. It drives it up and down according to the tune put into the map to add or take away fuel. Now, for those that do not know this, this can actually alter timing as well at the same time. So, in a nut shell, this can make tuning a bit harry if your a perfectionist and trying to do it right.
With respect to ignition timing, it suppliments the ECUs determination of timing based upon the primary O2 sensor's feedback from the previous combustion cycle, coolant temp, throttle position, air intake temp....So in other words, if you input a -2 value in the map on 4500 RPMS @ a throttle position of 90%, this does not mean that your timing will be retarded two degrees, but it may actually end up being say 15 degrees advanced (17 might have been optimal determined by the ECU and the other 2 you told the e-manage to pull out). This is not a standalone ignition computer, so please do not treat it like that, nor a standalone fuel computer. If you want to know what the ECU is doing you can get an OBD2 diagnostic machine like a Snap On MT2500 like we have or something like this: www.autoenginuity.com
What it is and what it is not......
The e-manage does not have an O2 sensor skew option that allows for blocking or revising of this signal to prevent drastic changes off the tune...(commonly referred to as re-learning). This brings us into another topic........
The Primary O2 sensor acts as a spy for the ECU telling it that no matter what the other signals tell it about fuel and spark, it is REALLY like this. The ECU will then revert to this signal for primary source of data regarding the previous combustion cycle to determine the next combustion cycle.
If your closed-loop tuning (not in Wide Open Throttle) is waaay off base, then you will experience some severe relearning because you will be effecting the short term fuel trims (which is what the ECU looks to for a projection of how well it's doing on the fuel trims for the future based upon previous one, like a forecast). The key is to have an OBD2 scanner like the Snap On MT2500 or something that will allow you to monitor Short Term & Long Term fuel trims to see how far off base you are. The farther you stray off base, the worse re-learning will occur. The key is to be close to zero as possible. This means the ECU likes what it sees and will not make changes to the tune. This sometimes, is not always great for partial throttle cruising at moderate to low RPMS with a little boost (1-3 PSI let's say) because you might have to be at a 13:1 AFR, which is pretty damn lean for a turbo set-up. The balance is very delicate and can be acheived, but takes time, logic and patience.....
If your open-loop tuning (WOT), your golden. The e-manage is stellar in that scenario and will hold a 12:1 or richer all day.
The e-manage has the injector correction factor which pulls voltage from the MAP sensor accross the board to compensate for less pulsation and duration creating a more like stock feel to the injectors. The addition of the notorious RSX 310CC injectors into the 240cc D17 realm is VERY common. This is a ~29% increase in flow, so you decide to plug in these values and boom your done.........or so you think................Your driving along and bam, you got a mysterious CEL and it comes up Map/Baro sensor error. WTH gives you say????? Well let's jump into that...............
The injector correction pulls map sensor voltage, which means the e-manage takes the MAP voltage, intercepts it, lowers it because of the correction factor, then spits that signal out. What this causes a variation in input to output. The ECU thinks that the MAP sensor is shot, so it codes it.
The input of the MAP might be .95 volts, but with the correction your output might be around .78 volts. THIS IS WHY YOUR ECU HATES YOU AND THROWS THE CEL. Too much variation in signal. So what do you have to do? You have tighten up the injector correction factor from say 240 >> 310 to 240 >> 280-300 and see what the signal is....Try to get it within a .7-.1 variation with still having some correction so your not pig rich all the time. Using the map trace function, trace input from Airflow Meter and output and see the datalogged variation.
I hope this clears up a lot of myths, questions and problems some people are having with the unit. Overall it is super easy and is a quick and dirty, cost effective means of tuning if you can not afford the AEM standalone which is a 1000% better and reliable. Truly the more reliable and easier way to go, but VASTLY more expensive.
Let me know if there is anything else I can add...........REP if this helps.
__________________________________________________ ______________
Supplimental Material:
Any tips or tactics to tuning it? Yup! Past the link into your browser and READ.
http://www.gadgetonline.com/U-Tune.pdf#search='tuning%20a%20piggyback'
Quote:
Originally Posted by jackburton
I still do not understand what clamping the map voltage means, why he asked about zero vaccum pressure, or what those numbers mean exactly?
Thanks for the the thread dezod, it answered a lot of questions I had.
The voltage clamp prevents the ECU from seeing a certain amount of MAP voltage. Let's say 5V = 100% throttle. So if you clamp it at 4.5V, the ECU thinks it never sees past 78% throttle. So you will have to tune all fuel delivery above and beyond that. That is what the voltage clamp does.
Furthermore, if you are not careful and clamp too at say 3V out of 5V, you will max out your injectors quickly because now you have to accomodate for normal fuel delivery on top of boost fuel requirements.
The voltages listed above are how the GReddy Pressure Sensor voltage is read in terms of boost amounts. Thats all.
Pressure Sensor Specs:
PSI - Voltage - inHg
-14= 0.54 -- 28.504
-13= 0.60 -- 26.468
-12= 0.67 -- 24.432
-11= 0.74 -- 22.396
-10= 0.81 -- 20.36
-9= 0.88 -- 18.324
-8= 0.95 -- 16.288
-7= 1.02 -- 14.252
-6= 1.09 -- 12.216
-5= 1.16 -- 10.18
-4= 1.22 -- 8.144
-3= 1.29 -- 6.108
-2= 1.36 -- 4.072
-1= 1.43 -- 2.036
0= 1.50
1= 1.57
2= 1.64
3= 1.71
4= 1.78
5= 1.84
6= 1.91
7= 1.98
8= 2.05
9= 2.12
10= 2.19
11= 2.26
12= 2.33
13= 2.40
14= 2.46
15= 2.53
16= 2.60
17= 2.67
18= 2.74
19= 2.81
20= 2.88
21= 2.95
22= 3.02
23= 3.09
24= 3.15
25= 3.22
26= 3.29
27= 3.36
28= 3.43
29= 3.50
30= 3.57
31= 3.64
32= 3.71
33= 3.77
34= 3.84
35= 3.91
36= 3.98
37= 4.05
38= 4.12
39= 4.19
40= 4.26
41= 4.33
42= 4.39
43= 4.46
__________________
Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
7thgen Dedicated Section
Dezod Myspace
W: www.dezodmotorsports.com
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
dezod is offline   Reply With Quote
Sponsored Links
Old 04-04-2006   #2 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
you know... thats the first explaination I actually comprehended in full
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Old 04-04-2006   #3 (permalink)
kingofheartz
Member
kingofheartz will become famous soon enough kingofheartz will become famous soon enough
im so n00b, yet i understand that. clears up a lot, thanks!
kingofheartz is offline   Reply With Quote
Old 04-04-2006   #4 (permalink)
01HonderCivic
Don't be a n00b, search ftw
01HonderCivic's Avatar
01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future 01HonderCivic has a brilliant future
__________________
...Holdin' it down, Oregon style bitches!
01HonderCivic is offline   Reply With Quote
Old 04-04-2006   #5 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
I am glad this is making sense and clears up some stuff about it.
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 04-04-2006   #6 (permalink)
SODJAZERO
Diamond Member
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
Send a message via AIM to SODJAZERO Send a message via Yahoo to SODJAZERO
i have a head ache
ok so now reading this, would the mechanical o2 sim be a problem be a problem with emanage?
__________________
"when I was younger I used to faint at the sight of blood, now that I'm older I noticed it ain't at the sight of blood, now the sight of blood equals the very sight of love, menstrual cycles feelin' like you right at your height of drugs" - TECH N9NE
183whp 175tq @ 7psi
Fs: Sony Ericcson W600i Brand New In Box 220 Shipped, price drop
SODJAZERO is offline   Reply With Quote
Old 04-04-2006   #7 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Quote:
Originally Posted by SODJAZERO
i have a head ache
If your simulating the 2ndary O2 sensor, no. That 2ndary O2 (after the cat) is just used to measure catalytic converter efficiency. That does not effect tuning. DO NOT USE IT ON THE PRIMARY O2 SENSOR.
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 04-04-2006   #8 (permalink)
jknudsen
MAVS FAN 4EVER
jknudsen's Avatar
jknudsen is a jewel in the rough jknudsen is a jewel in the rough jknudsen is a jewel in the rough jknudsen is a jewel in the rough
great write-up man
__________________
Quote:
Originally Posted by scatman
hey ******
i could give a fvck if you like me or not so next time you wanna send me some rep, have the balls to put ur name there (even though i can se everyones name who leaves me rep anyway).....oh and good job hiding it in a thread that you didnt post in. your not on my level.
scott.
jknudsen is offline   Reply With Quote
Old 04-04-2006   #9 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Thanks guys! Rep if this helped.
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 04-04-2006   #10 (permalink)
eye_see_you
let the devil out
eye_see_you's Avatar
eye_see_you has much to be proud of eye_see_you has much to be proud of eye_see_you has much to be proud of eye_see_you has much to be proud of eye_see_you has much to be proud of eye_see_you has much to be proud of eye_see_you has much to be proud of eye_see_you has much to be proud of eye_see_you has much to be proud of eye_see_you has much to be proud of eye_see_you has much to be proud of
Send a message via AIM to eye_see_you Send a message via MSN to eye_see_you Send a message via Yahoo to eye_see_you
a great write up that even the noobie gear head could understand DEZOD does it once again
__________________
My rsx-s| Pics of my old vic |TCI Auto Tranny Kit review
Corona Lovers Club Member #2
My ride: 2002 rsx-s
ICE:Clarion vrx735vd::JL Audio 300/4::JL Audio 500\1::JL VR-600-CXI::JL VR-525-CSI:: JL 13W7
Interior:ITR shift Knob::Buddyclub SS
Exterior:DC5 Side markers
Engine:ESMM::Ingalls Tq Damper,Buddy Club Race Condensor,Skunk2 PerformanceExhaust, Fujita F5 CAI,Hondata IMG
Suspension:Function/Form2 Coilovers, Ingalls Camber
Wheels-brakes: Volk VSpeed , Volk Lugnuts, Rotora Rotors, EBC Red Stuff
eye_see_you is offline   Reply With Quote
Old 04-04-2006   #11 (permalink)
djmota
djmota's Avatar
djmota is just really nice djmota is just really nice djmota is just really nice djmota is just really nice
awsome write up man this should help lots of noobs
I am gonna quote this for a while.
luv it
__________________
133.48 whp 117.57 tq all motor untuned dynojet
188.87 whp 187.99 tq 75 shot n20 untuned dynojet
147.5 hhp 130.5 htq all mtr tuned church's dynapack
my old d17 set up.
now swapped k20a2 4.7fd lsd kpro
djmota is offline   Reply With Quote
Old 04-04-2006   #12 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Rofl @ Mota
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 04-04-2006   #13 (permalink)
Havok2k1
Wicked Pissah Admin
Havok2k1's Avatar
Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future
added to turbo FAQ
__________________
I Like Cheeseburgers
Havok2k1 is offline   Reply With Quote
Old 04-04-2006   #14 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
I am really glad you guys are getting good info out of this.......
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 04-05-2006   #15 (permalink)
turboengnr
DONT PANIC
turboengnr's Avatar
turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all
Send a message via AIM to turboengnr Send a message via MSN to turboengnr
Another quick question that i know a lot of people have...
how many volts does the MAP sensor see under zero vaccum? And where do you think they should clamp the MAP sensor voltage at?
Ive been asked this many times, and i know it all varies due to conditions. But you are much more experienced with the emanage than i am, so i figure you could elaborate on this a little better than i could.
__________________
<--- Now known as Myika.
Quote:
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
7thgen civic 13 second club Member #1
13.624 @ 101.887
I suck at sleeping Crew Member #1
I love my wife... Click here to find out why!!
turboengnr is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
New @ Dezod Motorsports.... dezod Honda Civic Retail Sales 6 07-06-2005 09:14 AM
Dezod Motorsports :) sleekcivic2004 Transaction Feedback 1 03-17-2005 04:49 PM
New at Dezod Motorsports... dezod Honda Civic Retail Sales 22 12-16-2003 11:37 AM
Dezod Motorsports? Weaponx12o Transaction Feedback 11 10-03-2003 04:38 PM
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
