Forced Induction and SwapsPost information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Another quick question that i know a lot of people have...
how many volts does the MAP sensor see under zero vaccum? And where do you think they should clamp the MAP sensor voltage at?
Ive been asked this many times, and i know it all varies due to conditions. But you are much more experienced with the emanage than i am, so i figure you could elaborate on this a little better than i could.
copied from HERE are the specs for the greddy sensor
Quote:
Thanks Tnaff. Saved me some typing. Map trace function is great to use as well.
__________________ Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
I still do not understand what clamping the map voltage means, why he asked about zero vaccum pressure, or what those numbers mean exactly?
Thanks for the the thread dezod, it answered a lot of questions I had.
__________________ Have you paid your dues jack? The check is in the mail
The voltage clamp prevents the ECU from seeing a certain amount of MAP voltage. Let's say 5V = 100% throttle. So if you clamp it at 4.5V, the ECU thinks it never sees past 78% throttle. So you will have to tune all fuel delivery above and beyond that. That is what the voltage clamp does.
Furthermore, if you are not careful and clamp too at say 3V out of 5V, you will max out your injectors quickly because now you have to accomodate for normal fuel delivery on top of boost fuel requirements.
The voltages listed above are how the GReddy Pressure Sensor voltage is read in terms of boost amounts. Thats all.
I dont have a specific answer to where people are clamping the stock sensor at. Are you clamping it at 3.5v? 4.5v? 4.95v? And also a short explanation of why you are clamping it there.
Thats what i was getting at. Not voltage of the greddy sensor.
__________________ <--- Now known as Myika.
Quote:
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
7thgen civic 13 second club Member #1 13.624 @ 101.887
I am hearing many people say 4.95V, but I am not sure the stock MAP even sees 5 volts................
mine is clamped at 5 volts and ive never had a CEL because of boost
__________________ 169.8whp / 154 ft lbs tq @ 7psi with an auto trans! Click Image for my turbo install!
