Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-26-2007   #46 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of
Re: DIY Mechanical O2 simulator
ok so i install this on the second hole of my megan cat and i drill out the defouler correct?
then install it.
and just the o2 sensor goes in the first hole?
__________________
02BLKCIVIC is offline   Reply With Quote
Sponsored Links
Old 11-26-2007   #47 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
you are correct , you leave the first o2 sensor alone. this is all done at the second o2 sensor
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 11-26-2007   #48 (permalink)
02BLKCIVIC
02BLKCIVIC's Avatar
wow i was way off!
thank you sir!!!
__________________
Old 07-28-2008   #49 (permalink)
jj_diamond
Member
jj_diamond is an unknown quantity at this point
did any of you have to make the wiring for the first O2 sensor longer when ugrading to headers?
jj_diamond is offline   Reply With Quote
Old 07-28-2008   #50 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
Quote:
Mine is on a boosted setup, with a custom down pipe. so i mounted the O2 were it was easy to reach with the wires. I've got no knowledge on N/A setups. But you may want to take the wires out of the loom and see if you can make them reach?
__________________
Or
DIY Head gasket
Old 08-10-2009   #51 (permalink)
mclean987
Diamond Member
mclean987 is an unknown quantity at this point
i did this with one long fouler so i didnt have to drill it out, its the same size of the two put together , has anyone else done this?
mclean987 is offline   Reply With Quote
Old 09-04-2009   #52 (permalink)
mclean987
Diamond Member
anyone know where to buy a o2 simulator that you wire in, not spacer like in this thread?
Tags
02 , civic , diy , ep3 , honda , installation , mod , o2 , oxygen , rear , sensor , sesor , simulator , simulators , singapore
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Mechanical Engineering? hondacivicd17 Off Topic 23 04-09-2005 03:37 PM
Electrical or mechanical? CrewChief Other Honda Civic Parts and Products 2 10-16-2003 06:29 PM
DIY: o2 simulator *updated with 7thgen instructions* WannaBFast Honda Civic DIYs and Civic Tech Chat 17 10-16-2003 01:38 AM
o2 simulator prob, no diy here 2002vtecsir Honda Civic DIYs and Civic Tech Chat 0 06-21-2003 07:14 PM
Mechanical Engineering??? CivicRacer5 Off Topic 16 02-24-2003 08:46 PM
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
