Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-11-2005   #1 (permalink)
Ex_Coupe
New Member
Ex_Coupe is an unknown quantity at this point
Problems with TSI turbo
I got the turbo everything is working good... but the problem is that my car is too rich... I could not set it... I am using SAFC, with Acura RSX type S injectors... maybe the problem is with the map unit or black box???... To remove this ad, register today for free or log in if already registered!
Ex_Coupe is offline   Reply With Quote
Sponsored Links
Old 12-11-2005   #2 (permalink)
ajhdragon
7thgens official a$$hole
ajhdragon's Avatar
ajhdragon is a splendid one to behold ajhdragon is a splendid one to behold ajhdragon is a splendid one to behold ajhdragon is a splendid one to behold ajhdragon is a splendid one to behold ajhdragon is a splendid one to behold ajhdragon is a splendid one to behold ajhdragon is a splendid one to behold ajhdragon is a splendid one to behold ajhdragon is a splendid one to behold
Send a message via AIM to ajhdragon Send a message via Yahoo to ajhdragon
your probably always going to be running a little rich with the SAFC. The SAFC II will give you a little better tunning options because you have 12pts instead of 6. Really any piggy back system your be runnig either rich or lean. I'm running a little rich with the VAFC II. You need an EMS to get a perfect tune. Thats what im saveing for so i can run the Stage 2 CAM as well.
__________________
Team Orange
I <3 my Honda
.....But my Yamaha's faster.....
ajhdragon is offline   Reply With Quote
Old 12-11-2005   #3 (permalink)
Ex_Coupe
New Member
thanks for your answer... but I am using SAFC II... my problem is to big, that I cant use the car...
Old 12-11-2005   #4 (permalink)
03-Acura-1.7-EL
Platinum Member
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light 03-Acura-1.7-EL is a glorious beacon of light 03-Acura-1.7-EL is a glorious beacon of light 03-Acura-1.7-EL is a glorious beacon of light 03-Acura-1.7-EL is a glorious beacon of light 03-Acura-1.7-EL is a glorious beacon of light
Is your car running and is it drivable?
You need to be more specific.
I run rich and no probs.
__________________
Yes, t-25 @ 9psi
Video of my Turbo Acura: http://www.civicforums.com/forums/79...turbo-run.html
If you dont know how to repp users, then PM me!
03-Acura-1.7-EL is offline   Reply With Quote
Old 12-11-2005   #5 (permalink)
ajhdragon
ajhdragon's Avatar
how much boost are you ruinning. don't run to much over 7-8psi with the safc II. im running basically the same thing as you. t25bb on a custom kit, and RSX-S injectors and no problem. please be more specific on your problem. If it is to rich basci rule of thumb lean it out. it is simple with the SAFC II. the apexi untis make it lean and rich by changeing the timming so if you run to it means your timing is to advanced add to rich means your timing is retarted to much.
__________________
Team Orange
I <3 my Honda
Old 12-11-2005   #6 (permalink)
Ex_Coupe
New Member
... the car is not driveable,,, It is to rich, and I can`t go lean, because all the corrections are in -50, -45, -40, -35... I dont know what to do...
Old 12-11-2005   #7 (permalink)
03-Acura-1.7-EL
Platinum Member
Did you wire injectors right?
__________________
Yes, t-25 @ 9psi
Old 12-11-2005   #8 (permalink)
Ex_Coupe
New Member
Quote:
I think so... I need help... my can`t use my car...
Old 12-11-2005   #9 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
get emanage because it has injector duty cycle control?
__________________
________________________________________
Restore Performance, Reduce Costs
www.lubecontrol.com
LC20 - go 10k miles on a single oil change
Go Here For Real Medicine
http://www.youngliving.com
Member 1025782
The DX-Resource
http://bellz.sqweebs.com/
gearbox is offline   Reply With Quote
Old 12-11-2005   #10 (permalink)
XSRCivic
XSRCivic's Avatar
XSRCivic is just really nice XSRCivic is just really nice XSRCivic is just really nice XSRCivic is just really nice XSRCivic is just really nice
Send a message via AIM to XSRCivic
have you tried using your stock injectors vs the rsx injectors? how rich does a car have to be to not be able to run?
__________________
XSRCivic is offline   Reply With Quote
Old 12-12-2005   #11 (permalink)
Jeromie
Senior Member
Jeromie's Avatar
Jeromie is an unknown quantity at this point
Send a message via AIM to Jeromie
sounds like ur safc aint wired right,
must not be correcting at all,
my car wouldent start without the afc connected becuz it was waaayyy 2 rich...
__________________
http://i57.photobucket.com/albums/g2...jeromie8wa.jpg
no more 7thgen....
Jeromie is offline   Reply With Quote
Old 12-12-2005   #12 (permalink)
03-Acura-1.7-EL
Platinum Member
Very good point. I would follw it.
Ex_Coupe, I dont know why you have your title as "turbo problem", you dont have ptoblem with turbo.
Did you install everything yourself?
__________________
Yes, t-25 @ 9psi
Old 12-12-2005   #13 (permalink)
Ex_Coupe
New Member
I will open a new post
Old 12-12-2005   #14 (permalink)
Ex_Coupe
New Member
Map Unit (black Box) Tsi Turbo Kit Question
Hello again... I just have a question... Do I have to use the green wire that goes to the intake air temp. sensor? because in the black box unit it says NOT USE THE GREEN WIRE, but in the manual it says that it goes to the intake air temp sensor...
If it goes to that sensor, where I have to connect it? because there are two wires!
Thanks for your answers...
Old 12-12-2005   #15 (permalink)
Havok2k1
Wicked Pissah Admin
Havok2k1's Avatar
Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future
I merged the two.
One thread only please.
__________________
I Like Cheeseburgers
Havok2k1 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
TSI problems (newbie) zach_04LX Forced Induction and Swaps 45 08-04-2005 08:36 AM
Tsi turbo question morrmarr Forced Induction and Swaps 5 07-18-2005 02:56 PM
TSI - Turbo Kit.... Liro Canada East 34 10-13-2004 05:50 PM
Anyone got TSI turbo kit? vtecd17 Forced Induction and Swaps 7 07-24-2004 03:30 AM
Help on TSI Turbo Kit!! 2k2stylinchick Forced Induction and Swaps 13 06-13-2004 02:11 PM
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
DIY Mechanical O2 simulator
K20z1 Swap/Turbo in process.
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
