Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-03-2005   #1 (permalink)
Chompondis
Senior Member
Chompondis's Avatar
Chompondis is an unknown quantity at this point
Send a message via AIM to Chompondis
engine shutting off, please help
yestorday my buddy installed my rsx-s injectors and my greddy profec boost controller. after the install we went for a test drive and everything was alright except for when i hit 5 lbs(what i set the high setting to) then let off the gas, the car just died. no spuddering, jerking, i barely even noticed it was off. so it died 3 times when i was driving home. i reseted the ecu and drove to and from work with no problems today. tonight while i was driving i decided to have a little fun and i hit full boost (5lbs) and let off, the car died again. does anyone have any idea what could be wrong? are the injectors not spraying enough? too lean causing it to die? ecu problem? any help is appreciated cuz im stomped. thanks in advance To remove this ad, register today for free or log in if already registered!
Chompondis is offline   Reply With Quote
Sponsored Links
Old 11-03-2005   #2 (permalink)
scansel912
Platinum Member
scansel912's Avatar
scansel912 is just really nice scansel912 is just really nice scansel912 is just really nice scansel912 is just really nice
Send a message via AIM to scansel912
My car has done that when I hit the NOS. Even if its only for like 5 seconds, it has happened. It happened at the track too when I hit my 14.6. It was sorta scary trying to slow down from 100mph with your car completely off with no ps or ABS. I think it's because of the ECU being overloaded but I still have no clue.
__________________
B18C1 Powered 1992 Honda Civic Si
scansel912 is offline   Reply With Quote
Old 11-03-2005   #3 (permalink)
TransformedBG
I Hunt Goats, Rams, And Mustangs.
TransformedBG's Avatar
TransformedBG is a glorious beacon of light TransformedBG is a glorious beacon of light TransformedBG is a glorious beacon of light TransformedBG is a glorious beacon of light TransformedBG is a glorious beacon of light TransformedBG is a glorious beacon of light
Send a message via AIM to TransformedBG Send a message via Yahoo to TransformedBG
check the ohms of the rsx injectors vs that of your stock injectors.. the resistance could be different causing your ecu to heat up? not sure... just a thought.
__________________
Yeah so im kind of here but im kind of not... Im only here to post my opinions.
K20A swap, Jackson Racing SC, JRRH
277whp w/210ft.tq.
13.50@107.20 mph w/2.2 60ft time <Street tires>
12.92@106.30 mph w/2.1 60ft time <Slicks>
My sponsors:
other valuable sites
www.7thgenhonda.com , www.importpassion.com , www.emhonda.com
TransformedBG is offline   Reply With Quote
Old 11-03-2005   #4 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
Quote:
What kinda of fuel management do you have?
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 11-03-2005   #5 (permalink)
stl01civic
BOOSTED DOHC i-VTEC
stl01civic's Avatar
stl01civic is an unknown quantity at this point
did you guys tune it after installing those injectors??? If not it is probley running too rich.
__________________
06 STi - 309.1AWHP 360.7TQ - Stage 2
01 Civic -239.8WHP 212TQ @ 7.5psi
stl01civic is offline   Reply With Quote
Old 11-03-2005   #6 (permalink)
iamboo
Retired - SoCal FI Mod
iamboo's Avatar
Send a message via AIM to iamboo
if you get a CEL you might be running too rich... you need something to control your 330cc rsx injectors... if you want... try turning UP the boost a lil if you don't have a fuel management unit in place like an e-manage... either that or pull out the injectors until you have something to control the fuel with....
if you're not running too rich, it sounds like the infamous missing link check valve problem... if you don't have one of those installed, your car will die if it sees any sort of boost at all...
iamboo is offline   Reply With Quote
Old 11-03-2005   #7 (permalink)
Michalo187
Abortion Survivor
Michalo187's Avatar
Michalo187 is a glorious beacon of light Michalo187 is a glorious beacon of light Michalo187 is a glorious beacon of light Michalo187 is a glorious beacon of light Michalo187 is a glorious beacon of light
Send a message via MSN to Michalo187
I also say your running to rich. You gotta get a emanage or something to control them
__________________
God Created Turbo Lag to give V8s a chance!
Need Vtec? Vtec refils for sale now! Pm me for pricing! Make sure you replace your Vtec every 10,000 miles, Also Available for Domestics
Ek Hatch H.M.O. B18c + BOOOST!!!! =
Michalo187 is offline   Reply With Quote
Old 11-04-2005   #8 (permalink)
Chompondis
Senior Member
Chompondis's Avatar
thanks for the help guys. i dont have any fuel management right now so that could be cause #1. neither do i have a missing link, cause #2. my car did throw a cel today so maybe a missing link will fix this? trying to slow down from 80 is a bit sketchy when your power steering goes out. should i just pull the rsx injectors and install my stocks with a missing link? thanks alot
Old 11-04-2005   #9 (permalink)
Michalo187
Abortion Survivor
Michalo187's Avatar
If you install stock don't boost thats just too dangerous. Get the missing link and a e-manage thats the only way your going to fix this
__________________
Old 11-04-2005   #10 (permalink)
2K1Civic17"Gabe
2K1Civic17"Gabe's Avatar
Send a message via AIM to 2K1Civic17"Gabe
You need to tune the injectors. Running too rich/lean will cause your car to shut off, and not having a ML will cause the CEL without a doubt.
Your codes will probably be:
-High voltage Map BARO, or something like that, which means no ML, ecu is seeing boost
-Something with fuel running lean
2K1Civic17"Gabe is offline   Reply With Quote
Old 11-04-2005   #11 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
I bet if hes running rsx injectors with out some sort of fuel management it will be a rich condition more than likely. Im actually removing like 20-30% from the RSX injectors at WOT
__________________
Or
DIY Head gasket
Old 11-04-2005   #12 (permalink)
thc
New Member
thc is an unknown quantity at this point
the same thing happens to me when i spray its cause it runs to rich
thc is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
engine feel shutting off HELP_ME Mechanical Problems/Vehicle Issues and Fix-it Forum 16 08-17-2004 09:17 PM
is your windows XP shutting down on its own? ihkskim South Cali 28 08-13-2003 03:09 PM
OH No!!! Shutting down Kazaa?? dru106 Off Topic 23 01-03-2003 06:40 PM
radio keeps shutting off... help! fourkilos I.C.E. & Electrical 1 03-28-2002 12:16 AM
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
