Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-29-2005   #16 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold
Send a message via AIM to dezod
Quote:
Originally Posted by Michalo187
Alright and when do you estimate this will be out and what kind of price are you estimating? I really want big injectors that fit without hitting the tps.
For which item(s)?
__________________
Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
7thgen Dedicated Section
Dezod Myspace
W: www.dezodmotorsports.com
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
dezod is offline   Reply With Quote
Sponsored Links
Old 09-29-2005   #17 (permalink)
Michalo187
Abortion Survivor
Michalo187's Avatar
Michalo187 is a glorious beacon of light Michalo187 is a glorious beacon of light Michalo187 is a glorious beacon of light Michalo187 is a glorious beacon of light Michalo187 is a glorious beacon of light
Send a message via MSN to Michalo187
the fuel system and im
__________________
God Created Turbo Lag to give V8s a chance!
Need Vtec? Vtec refils for sale now! Pm me for pricing! Make sure you replace your Vtec every 10,000 miles, Also Available for Domestics
Ek Hatch H.M.O. B18c + BOOOST!!!! =
Michalo187 is offline   Reply With Quote
Old 10-07-2005   #18 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Anyone else?
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 10-08-2005   #19 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned
Send a message via AIM to andyman97 Send a message via Yahoo to andyman97
Hey Paul, whenever you get a chance, I really need to talk to you about the ultimate. I got the car running today finally and everything seemed cool but I got a code fo the vtec. Then I ended up misfiring on cyl 3 and 4. I can't seem to figure out why....but I'd like to discuss it with you. The VTEC issue seems to me like it has something to do with the jumpers and maybe the setting for the vehicle....
__________________
02 Civic d17a2 turbo
490 whp/360 tq @ 31 psi
-If you pm me and I don't respond, it's because, either:
a) Your question is stupid
-or-
b) it can be found by searching if you'd quit being lazy
andyman97 is offline   Reply With Quote
Old 10-09-2005   #20 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Quote:
VTEC sounds def like a jumper issue. Why your misfiring...????? That could be a number of different things.
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 10-09-2005   #21 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
Not sure why. I'm afraid it may be related to the jumpers. Last night, when I checked the voltage on the injectors, 3 and 4 had nothing and 1 and 2 had about 12V. I tried again today to see if I could figure out if it was maybe an ecu driver so I pulled the emanage harness and plugged the ecu harness directly into the ecu with no emanage and had current on all injectors and I double checked my coils just in case and everything seemed good.
So I decided to check the jumpers again. It's weird. The ultimate has a jumper for VTEC input. One setting is just for vtec and the other setting was for vtec K20a. So I had it set for K20a and decided to try changing to regular vtec. Neither worked. There's also a support tool setting for engine type, one of which was for K20a, so that was the closest one I could use. Bottom line, I couldn't get it started today so I'm not sure, just going to have to make some phone calls and see what I can figure out.
__________________
-or-
Old 10-09-2005   #22 (permalink)
02fpcivic
Diamond Member
02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light 02fpcivic is a glorious beacon of light
dezod if you want I can send you a boost manifold for cost. I have a few different options with them but I can put together a beautiful topmount TB manifold with velocity stack runners that will work really really good with boost. It will save mucho time in development and help the 7thgen community. I have all the cnc flange programs to except the factory o-ring gaskets, and the factory cruise control is still functional as well.
__________________
JDM Fabtech
02fpcivic is offline   Reply With Quote
Old 10-09-2005   #23 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
For as alike as the K20 is, it is also different. They have i-VTEC.
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 10-09-2005   #24 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Quote:
PM me with what your talking about.
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 10-09-2005   #25 (permalink)
Curiouz_G
Ultimate Member
Curiouz_G's Avatar
Curiouz_G is just really nice Curiouz_G is just really nice Curiouz_G is just really nice Curiouz_G is just really nice
ehh this is WAYYY off topic but GB and Saints played today and it wasnt pretty =(
Curiouz_G is offline   Reply With Quote
Old 10-10-2005   #26 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Quote:
Yeah tell me about it...
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 10-10-2005   #27 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
Well, update on the ultimate....
I got it working. I couldn't figure out the vtec settings. For now, I'm just going to bypass the vtec control from the emanage but everything else seems cool.
No more barometric pressure code, either. At least as long as you don't use the injector correction control factor. If you just use the individual injector maps, you can trim the fuel up no problem.
Nothing else is giving any trouble at this point. I am going to try desperately to get tuned next weekend. If I find out anything else by then, I'll post it up.
And the issue I was having with the misfiring was due to my injectors freezing up. I went ahead and swapped them out and that took care of that issue.
__________________
-or-
Old 10-10-2005   #28 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
issue.
Have you tried any of the additional options?
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 10-10-2005   #29 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
Nah, I'm just trying to get it to work correctly before I try anything else.
__________________
-or-
Old 10-10-2005   #30 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Running good so far??
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
injen CAI, progress rear sway adapter now on ebay, SSM coupe grille **PICS** skipbarber Honda Civic Parts for Sale 24 10-27-2005 10:04 PM
Newb w/some turbo questions BigL350 Forced Induction and Swaps 17 09-26-2005 07:51 AM
my EMANAGE MAPS for those interested C2i0v0i1C Forced Induction and Swaps 45 09-12-2005 04:51 PM
V-AFC II terms and meanings ? kkk Other Honda Civic Parts and Products 20 11-07-2004 01:57 PM
couple of questions. cin>>needed. CiViCPrAnInG2k1 Off Topic 7 03-26-2004 12:26 AM
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
