Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-25-2005   #1 (permalink)
BigL350
New Member
BigL350 is an unknown quantity at this point
Newb w/some turbo questions
Hi, everyone. A friend of mine wants to turbo his '02 EX and asked if I can build a kit for it. I'm a newb to the 7th gen civic world, but not to the turbo world. These are some pics of my '79 Malibu and the turbo kit I fabricated for it.
I've read through all of the stickies and they've been extremely helpful, but there's a few things I'm unclear on and I'd apprieciate it if you guys could help.
Is the D17 header flange the same as earlier D series motors or is it unique?
I see you guys are using extra injectors or piggyback computors to add more fuel, but what are you doing about timing? Are you guys using any type of retard device?
Do you have to add an FMU or RRFPR to raise fuel pressure or can the stock system keep up, assuming a better pump is used?
Thanks
Larry
BigL350 is offline   Reply With Quote
Sponsored Links
Old 09-25-2005   #2 (permalink)
iamboo
Retired - SoCal FI Mod
iamboo's Avatar
Send a message via AIM to iamboo
Thanks
Larry
the earlier d series flange will not fit on the d17 platform...
timing can be retarded or advanced using e-manage, AEM ems... there are a couple other piggyback but as of yet, no standalone...
you don't have to use an fmu to raise fuel pressure.. by converting the fuel system to a return system, buying a better fuel pump like a walboro 255, e-manage, and RSX 330cc injectors, you'll be able to supply and most importantly, tune your fuel curves...
correct me guys and part of this is wrong guys....
iamboo is offline   Reply With Quote
Old 09-25-2005   #3 (permalink)
Blahman240
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
there is a stand alone, its from AEM. But you need to give up ac and something else to use it.
Blahman240 is offline   Reply With Quote
Old 09-25-2005   #4 (permalink)
BigL350
New Member
Damn you guys are quick! Can the regular emanage control timing or just the emanage ultimate? Has anyone used something like an MSD BTM?
Old 09-25-2005   #5 (permalink)
Pedro Lopes
Senior Member
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
Both emanages control timing but the ultimate has a lot more features than the regular emanage.
Pedro Lopes is offline   Reply With Quote
Old 09-25-2005   #6 (permalink)
Michalo187
Abortion Survivor
Michalo187's Avatar
Michalo187 is a glorious beacon of light Michalo187 is a glorious beacon of light Michalo187 is a glorious beacon of light Michalo187 is a glorious beacon of light Michalo187 is a glorious beacon of light
Send a message via MSN to Michalo187
The new aem ems should be out soon its standalone and 7 wires from the stock ecu need to be used as a piggy bank. The return fuel system is a good way to go with rsx type s injectors.
__________________
God Created Turbo Lag to give V8s a chance!
Need Vtec? Vtec refils for sale now! Pm me for pricing! Make sure you replace your Vtec every 10,000 miles, Also Available for Domestics
Ek Hatch H.M.O. B18c + BOOOST!!!! =
Michalo187 is offline   Reply With Quote
Old 09-25-2005   #7 (permalink)
BigL350
New Member
The emanage ultimate is nice, but it's pricey. I was going over the contents of the TSI turbo kit, but I don't see anything about timing control. Are you guys finding it unnecessary at low boost levels?
Old 09-25-2005   #8 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
E-manage ultimate has NOT been tested to my knowledge on the D17! Regular e-manage is the best bang for the buck currently. I currently use a 1:1 RRFPR but its not currently hooked to vacuum/boost and im tuned with out its feature and doing great!
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 09-25-2005   #9 (permalink)
civic01vtec
The only job I need is a blowjob
civic01vtec's Avatar
civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned
Send a message via AIM to civic01vtec
Damn, your malibu is sick. My very first car was a '79 malibu, i loved it.
As far as retarding timing, by rights you should retard it a few degrees. Many ppl on a budget have boosted 8-10 psi daily without pulling some timing, including myself. The main problem with our cars is supplying enough fuel. The stock pump and injectors can not supply enough fuel to run safely over 8 psi.....especially during a 14 sec run at the track.
__________________
The 2nd Amendment America's original homeland security
'01 Civic EX -- boosted
'99 Chevy 2500 Ext. cab 4x4 with a
454 <--- under 10 mpg
'02 Chevy Trailblazer
civic01vtec is offline   Reply With Quote
Old 09-25-2005   #10 (permalink)
ncirom2003
ncirom2003's Avatar
Send a message via AIM to ncirom2003
andyman is being a pioneer with the emanage ultimate.
the tsi kit can come with 2 extra injectors and management (w/ turbotimer in it blah blah) and hteres also an option of vafc-2 (can control fuel and spark) and that comes with some lil goodies too (forgot the goodies...)
btw THAT IS FREAKING AWSOME! i love old bowties, and a turbo thats almost the size of the car definately helps lol
__________________
03 nissan 350Z
02 honda civic turbo----for sale, check below.
TURBO AND ELECTRONIC GOODIES FOR SALE.
I NEED TO SELL ASAP SO I HAVE LOW LOW PRICES.
[/color]
http://www.civicforums.com/forums/19...ool-d17er.html
MYSPACE
ncirom2003 is offline   Reply With Quote
Old 09-25-2005   #11 (permalink)
turboengnr
DONT PANIC
turboengnr's Avatar
turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all
Send a message via AIM to turboengnr Send a message via MSN to turboengnr
Easiest way to do the fuel system correctly on this car would be an emanage and injectors. That would be sufficient for a relatively low boost application (even with the stock pump).
fftopic:
What kind of carb are you using on your malibu? Im starting on the setup for our 56 belair. Debating whether or not to turbo the 327. Im not a big fan of blowing through the carb with just a hat, since i havent dont that yet. I have sucked through a carb, and built a box that completely encloses the carb.
__________________
<--- Now known as Myika.
Quote:
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
7thgen civic 13 second club Member #1
13.624 @ 101.887
I suck at sleeping Crew Member #1
I love my wife... Click here to find out why!!
turboengnr is offline   Reply With Quote
Old 09-25-2005   #12 (permalink)
BigL350
New Member
Thanks for all the help guys. Emanage and a set of RSX injectors sounds like the plan. I'll get him started on 6lbs then swap the pump if he wants a little more. We still have to go over some of his options, but I'll let you guys know what the whole plan is going to be.
Thanks for the kind words about the 'bu. The carb is a holley 750 double pumper with a proform main body and annular boosters prepped by Carb Solutions Unlimited. The carb tuning gets kind of intense with this kind of setup, but as long as you have a wideband O2 sensor you can get it perfect. The tricks to gettin a blow-through system to work well are, use a proven hat like from www.superiorairflow.com or www.csucarbs.com, use a carb at least 100cfm smaller than you'd use n/a to create a strong enough vaccum signal to the boosters, or switch to annular boosters on a bigger carb. www.turbomustangs.com has all the info you could ever need. I couldn't have built my car without the help of that site.
Old 09-25-2005   #13 (permalink)
turboengnr
DONT PANIC
turboengnr's Avatar
thanks. I will have to look into that.
Good luck with the civic project.
__________________
13.624 @ 101.887
Old 09-25-2005   #14 (permalink)
BigL350
New Member
Do all of the mods in your sig apply to the SRT-4 pics you have? What's the plan for the BelAir?
Old 09-25-2005   #15 (permalink)
ncirom2003
ncirom2003's Avatar
i need to get a new carb for my dads 71 chevelle, are all holley 750's hard to tune? i was looking into them but if its that intense to tune it ill look for something else. what do you think of an edelbrock carb? (motor is not FI)
__________________
03 nissan 350Z
[/color]
MYSPACE
« Nitrous | Injectors »
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
The 7thGen Swap FAQ. Hawk Forced Induction and Swaps 283 10-07-2009 12:39 AM
you can all talk the talk but can you walk the walk ironcow Forced Induction and Swaps 9 06-18-2003 05:47 PM
New Member? blazed870 South Cali 29 02-07-2003 06:34 PM
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
