Quote:
Originally Posted by NastyNunez The stock d17 shifter cables are shorter then the k20a2 cables. I knew i should have taken a picture of them for people to see. Little things like that is what im talking about. Maybe theres a trick to making the stock ones work? Who knows @@ As soon as i put on the k20 cables, it shifted perfect. |
uhhhhumm... is that the little things you were talking about that was missing from the DIY.... welllll..
hate to burst your bubble but in my DIY it
does say you need the shifter cables from the RSX..
the only way ur gona get stock ones to work is the extend the length of the d17 cables... i tried... been there done that... trust me.. failed miserably... it actually costed me more to attempt to try and make my cables longer versus buying some new/used k20 ones.. i tried taking short cuts and finding cheaper routes to do the swap..
Quote:
Originally Posted by Yaj00003 xproductionz do I need a ac compressor just to put in the alternator cuz it also doesnt come with it...and I think there like a front mount that on it too right...from what I see and research there only 3 mounting that I need the passenger front side, rear, and trans mount right....? |
u only need 3.. driver.. passenger and rear mount... thats what hasport kit comes with..
you got 2 options with the a/c compressor.. you can get rid of the compressor but you gotta run a custom length belt. OR... you can put in the compressor and run a factory belt... ur choice.. hoever i do have a compressor for sale if you need one
