Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-22-2005   #31 (permalink)
leonhsieh
Senior Member
leonhsieh's Avatar
leonhsieh is an unknown quantity at this point
esc1 will make ecu goes into open loop when it senses postive pressure, which will prevent ecu to adjust fuel under boost. you still have to tune your close loop(not in boost) to desired a/f ratio at to prevent ecu touch your STFT. To remove this ad, register today for free or log in if already registered!
__________________
202hp, 189tq @ 8psi
leonhsieh is offline   Reply With Quote
Sponsored Links
Old 09-27-2005   #32 (permalink)
GLi4dr
Member
GLi4dr's Avatar
GLi4dr is an unknown quantity at this point
Send a message via MSN to GLi4dr
Mad props to 'turboengnr'!
So...after reading about eManage "not" working right...does this lil` trick fix the problem?? ie. If the time is spent to set up your throttle trims and then tune and WOT, things should be sweet and the factory ECU will leave it alone and wont go changing things yeah?? Or should you still keep tabs on it every now and then to make sure its still where you last left it??
One more quick thing...
Check list for tuning:
OBDII Scanner
WideBand
Laptop with EMS Software
Is that all that is needed??
Again, huge thnx for this info
-BEN
GLi4dr is offline   Reply With Quote
Old 09-27-2005   #33 (permalink)
mclean987
Diamond Member
mclean987 is an unknown quantity at this point
kool
mclean987 is offline   Reply With Quote
Old 09-27-2005   #34 (permalink)
turboengnr
DONT PANIC
turboengnr's Avatar
turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all turboengnr is a name known to all
Send a message via AIM to turboengnr Send a message via MSN to turboengnr
the biggest thing with the emanage is getting it to idle correctly with large injectors, without throwing a check engine light.
__________________
<--- Now known as Myika.
Quote:
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
7thgen civic 13 second club Member #1
13.624 @ 101.887
I suck at sleeping Crew Member #1
I love my wife... Click here to find out why!!
turboengnr is offline   Reply With Quote
Old 09-27-2005   #35 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold
Send a message via AIM to dezod
Quote:
Define large?
We did it with the RSX injectors.
__________________
Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
7thgen Dedicated Section
Dezod Myspace
W: www.dezodmotorsports.com
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
dezod is offline   Reply With Quote
Old 09-27-2005   #36 (permalink)
TheSmuggler
TheSmuggler's Avatar
TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned
Send a message via AIM to TheSmuggler
600cc+ lol
__________________
JDM'ing it since 1985
HighwayStar - /super highway/stunt driving/transport service/fast delivery/
RoadPirate - /live forever/interstate commander/highway hijack/
PerfectWorks
TheSmuggler is offline   Reply With Quote
Old 09-27-2005   #37 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
mine idled perfect with just the cc correction on RSX injectors
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 09-27-2005   #38 (permalink)
ncirom2003
ncirom2003's Avatar
Send a message via AIM to ncirom2003
how much is this "wideband" you speak of and exactly what is it?
also what this esc1 you guys are talking about? sounds good
__________________
03 nissan 350Z
02 honda civic turbo----for sale, check below.
TURBO AND ELECTRONIC GOODIES FOR SALE.
I NEED TO SELL ASAP SO I HAVE LOW LOW PRICES.
[/color]
http://www.civicforums.com/forums/19...ool-d17er.html
MYSPACE
ncirom2003 is offline   Reply With Quote
Old 09-27-2005   #39 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
Here is the wideband i have, mine cost me $450-500 ish, but you can get others for much lesshttp://www.plxdevices.com/M-Series_l...roductinfo.htm
Here is what a esc1 is
Quote:
Description:
The ESC1 EGO Signal Conditioner alters the signal from EGO sensors under boost conditions. It may be used in either single or dual EGO sensor applications. Under vacuum conditions it outputs a signal which is identical to the EGO signals that appear at the input. Under boost, it outputs an internally generated signal to allow open loop operation.
The ESC1 is especially useful for forced induction conversions where a supercharger or turbocharger is fitted to an engine which is normally naturally aspirated. In the vacuum region of operation the ECU operates in its normal closed loop mode of operation. Under boost, the ECU transitions into an open loop mode and maintains its internal mapping tables.
The ESC1 allows the conversion to forced induction on engines with modern fuel injection including those with OBDII on-board diagnostics. The stock ECU programming may be used without activation of fault codes under boost.
http://www.splitsec.com/products/esc1/esc1ds.htm
__________________
Or
DIY Head gasket
Old 11-04-2005   #40 (permalink)
DaRk_MauL
Super Member
DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light DaRk_MauL is a glorious beacon of light
Send a message via MSN to DaRk_MauL
this is also a nice wideband.
http://www.zeitronix.com/Products/zt2/zt2.htm
__________________
http://users.telenet.be/seriousspace/Jdmvicbanner.jpg
NA [I/H/X]:15.68sec on 1/4 mile
boosted: not yet
DaRk_MauL is offline   Reply With Quote
Old 11-04-2005   #41 (permalink)
Civic_RedLine
im stock now! T.T
Civic_RedLine's Avatar
Civic_RedLine will become famous soon enough
now im scared to use emanage, will the computer try to adjust it daily? and if so what do i do to stop it..
Civic_RedLine is offline   Reply With Quote
Old 11-04-2005   #42 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
Quote:
Not daily, every second or less , the key is to get it set properly for the conditions your running
__________________
Or
DIY Head gasket
Old 11-04-2005   #43 (permalink)
turboengnr
DONT PANIC
turboengnr's Avatar
dont be scared. Just follow my little guide and it will be fine.
__________________
13.624 @ 101.887
Old 11-04-2005   #44 (permalink)
Civic_RedLine
im stock now! T.T
well you can tell me what to worry about and what not when I get there...
Old 11-04-2005   #45 (permalink)
turboengnr
DONT PANIC
turboengnr's Avatar
yea.
the 25th may be our date
__________________
13.624 @ 101.887
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Does our ECU reset the Apexi SAFC2? Deadkookaburra Honda Civic DIYs and Civic Tech Chat 39 09-23-2005 05:12 AM
ODBII Datalogging experiment opto_isolator Forced Induction and Swaps 41 04-10-2004 09:13 PM
big puddle VTECnique Honda Civic Racing, Street Encounters and Competition Racing 64 04-13-2003 12:43 AM
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
