Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-17-2005   #1 (permalink)
Hwoody77
Diamond Member
Hwoody77 can only hope to improve
Send a message via ICQ to Hwoody77 Send a message via AIM to Hwoody77
E-Manage Ultimate...
E-Manage Ultimate
For those who don't know, the e-Manage ultimate just came out. So I'm wondering if it's worth upgrading, and read through the description....
The Greddy e-Manage Ultimate does what no other piggyback ECU can. Engineered to preserve the best features of the original e-Manage (economical price, no need for tuning from scratch, & compatible for most Japanese performance vehicles). Physical dimensions of the case are the same as the previous e-manage model, however the “e-manage Ultimate” has a black-chrome finish.
Front Panel
(Dip) Toggle Switch - 2 independent setting can now be stored and accessed via the “Toggle Switch.” 2 separate maps for the “Injection Adjustment Map” and the “Ignition Map.” (For Rotary engines, 2 separate “Primary and Secondary Injector Maps” and “Leading & Trailing Ignition Maps.”) i.e. one program for “street” and one for “race track”.
Serial port - External data (like “GReddy Warning Meters”, and other future optional products) can be monitored and recorded in real time through a data link cable.
Switch Port - “Data logging” and “Ignition Cut” features can be activated with the use of an optional “Remote Switching System” and “Switching Harness”
Option 1 & Option 2 - An additional “Option Connector” is added to the previous “Pressure Connector.” Now any two Options (like “GReddy Pressure Sensor”, “GReddy Temp Sensor,” “Multi-Switching System,” A/F Meter, Auxiliary Switch, Factory Pressure Sensor, or Other Analog Input signal) can be selected using the “Option 1” and/or “Option 2 “ ports.
USB Port - e-Manage is industry first to adapt the USB communication technology. We have improved communication with ability to use standard USB cables. This improvement also enhances the communication speed for more detailed real time monitoring and data recording.
Real Panel
Because of new Features, there are now 3 “Harness Connectors” (sold separately). The 18-pin and 12-pin connectors and the signal pins are identical to the previous e-manage system, while a new 14-pin connector was added for new features. Additional “Vehicle Specific Plug-in Harness” may also be available for certain applications.
Circuit Board
Many Optional Adapters, which previously need to be purchased separately, are now built-in. The internal circuit board contains 20 “Jumper Switches” to accommodate (previously separate) features, including:
Mazda Hotwire Airflow Meter Adapter
Ignition Signal Adapter Socket (Ignition Signal Adapter 1 & 2)
Parameter Setting - The biggest change to this system is in the “Parameter Setting” window. With all the added features, the window is now in a tab menu format.
Speed Limiter Cut Feature - This feature will eliminate the factory speed limiter. (May not work on some vehicles)
Throttle Setting - Any voltage can be inputted directly to set the throttle position.
Warning Setting - “e-manage Ultimate” can illuminate the Active L.E.D. as a warning light for RPM and/or one additional parameter from the menu, by selecting and setting a warning point value (or an unused “I/J CH” can be used to activate a relay to illuminate an external warning light).
Ignition Cut Feature - With the installation of a switch (in the “ON” position), ignition can be cut at a set RPM point
Map Trace
Protect Feature - Each Map has the option to be password protected
A/T Shift Compensation Feature - On vehicles with Automatic Transmissions, ignition timing can be compensated at set shift-up and shift-down points
Channel Change Feature - Vehicles with a distributor type ignition system may able to use group fire or individual ignition systems (Replacement parts and modifications to the wire harness is required)Also, Group injection systems may be changed to sequential injection (Modifications to the wire harness is required).
Map(s)
Airflow Output Map - Previously labeled “Airflow Adjustment Map” is now “Airflow Output Map”. (#)This can now used to eliminate the factory airflow meter. This is done by directly inputting voltage or frequency in to this map.
Anti Engine Stall Feature - The 8 adjustment cells are now upgraded to 16 cells, for even finer adjustment.
Injection Adjustment Map - Fuel trimming in the previous system was achieved by adjusting the “Airflow Adjustment Map” which could also affect the ignition timing. The improved “Injection Adjustment Map” is used to trim and add fuel directly by controlling the injector signal, therefor it will not affect the ignition timing at all. (However with an internal jumper setting change, the system is still able to trim the fuel by adjusting the airflow signal like the previous unit)
Acceleration Injection Map - Like the “Injection Adjustment Map”, the “Acceleration Injection Map” can trim fuel by controlling the injector signal. This is used if it is necessary to smooth rapid transitions to wide open throttle.
Individual Cylinder Injection Adj. & Individual Cylinder Ignition Adj. Maps - It is possible to correct uneven combustion between cylinders, by fine tuning each individual cylinder for more advanced tuning.
Vehicle Speed Correction Map - Inconsistencies due to differences in vehicle speed (difference in load) can be corrected with this map.
Coolant Temp Correction Map (Must be Selected with Knock Signal 1) - When the ECU Coolant Temp Calibration does not match the e-manage’s tuning, this map is used to tune the system at various temperature ranges.
Intake Air Temp Correction Map (Must be Selected with Knock Signal 2) - When the ECU Intake Air Temp Calibration does not match the e-manage’s tuning, this map is used to tune the system at various temperature ranges. (#)This map is also be used when eliminating the airflow meter on a vehicle equipped with a hotwire type airflow meter.
Rev Limiter Cut - For vehicles with a fuel cutting controlled rev limiter, this feature will drive the injectors past the factory rev limiter. *This feature will not work on vehicles with rev limiter controlled by ignition cut.
A/F Target Value Map (feedback tuning function) - By inputting target Air Fuel values in this map, “e-mange Ultimate” will automatically make corrections to the “Injection Map,” if an A/F meter (*high quality) is connected to the Auxiliary Output signal. This feature can shorten the tuning time.
Ignition Adjustment Map - The “Ignition Adjustment Map” can accurately advance ignition timing by controlling the crank angle / cam angle signal.
Acceleration Ignition Map - Ignition timing can also be corrected for a rapid change in the throttle opening rate for a smoother transition into wide open throttle.
NVCS Control Map - NVCS (Nissan Valve Control System) can be controlled with out the need for NVCS Adapter 1.
Analog Output Map - This feature can be used to eliminate the factory boost cut function on vehicles that are equipped with both an airflow meter and a pressure sensor (i.e.: FC3S, Subaru). Also, on some vehicles, the factory feedback range can be adjusted by outputting a corrected throttle position signal.
Auxilary Output Map - The fixed 4x4 map on the previous unit is now a fully adjustable 16x16 map. Set your own "ON" and "OFF" conditions.
Idle Stabilization Map - If the factory idle control valve is a solenoid type valve, this map can vary the valve’s duration to adjust the injection rate. (#)This is used when eliminating the airflow meter.
Other Added Features
RPM Signal RecognitionImproved RPM signal. If the standard RPM signal wire cannot be used, an RPM signal can be recognized though a crank angle / cam angle signal. With an internal jumper setting, the system can even recognize RPM from the negative signal of the ignition coil.
Fouled Plug Feature - When initiated this feature can help clean fouled spark plugs by cutting the injector’s firing at start up. To fix the fouled plug start the engine with wide-open throttle.
Data Log Features
Data Logging - Samplings can be recorded at 20msec on up to different 8 channels on the unit itself and over 30 when using the included software. The data can be recorded even when the PC is not connected.
TEXT File Feature - The data recorded in the Real Time Display mode can now be save as TEXT file. Organizing the data can simplified by opening the data in Excel and creating a graph.
Knock Monitor (Future update) - Knock can be monitored and reviewed.
Ignition Timing Display (Future update) - Ignition Timing can be monitored in the Real Time Display mode.
So, let's see. Let's get some input....
First off no more need for the support tool, this one does straight USB.
Speed limiter - Who thinks this would work on our cars?
Rev limiter Cut - Now this is what I'm really interested in...our rev limiter is controlled by ignition or fuel?
A/F Target Map - If you have a wideband (Running AEM) this is a pretty badass feature...
Those are the 3 features that could make this thing worth it, everyone chip in!
Hwoody77 is offline   Reply With Quote
Sponsored Links
Old 07-17-2005   #2 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
Quote:
Originally Posted by Hwoody77
E-Manage Ultimate
Front Panel
Real Panel
Circuit Board
Map Trace
Map(s)
Data Log Features
D17 isnt supported as of yet. As i recall its Vehicle/engine specific isnt it ?
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 08-02-2005   #3 (permalink)
Hwoody77
Diamond Member
Back, no it isn't exactly Vehicle specific, the old E-Manage dosen't have our cars listed anyways...so discuss f00s.
Old 08-02-2005   #4 (permalink)
TheSmuggler
TheSmuggler's Avatar
TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned TheSmuggler should not be questioned
Send a message via AIM to TheSmuggler
LOL, ok you win, I just didn't see it, and it wasent listed under search or FI so lol
__________________
JDM'ing it since 1985
HighwayStar - /super highway/stunt driving/transport service/fast delivery/
RoadPirate - /live forever/interstate commander/highway hijack/
PerfectWorks
TheSmuggler is offline   Reply With Quote
Old 08-02-2005   #5 (permalink)
MiamiUgen7
MiamiUgen7's Avatar
MiamiUgen7 is a name known to all MiamiUgen7 is a name known to all MiamiUgen7 is a name known to all MiamiUgen7 is a name known to all MiamiUgen7 is a name known to all MiamiUgen7 is a name known to all MiamiUgen7 is a name known to all MiamiUgen7 is a name known to all
whats the a/f target map? do you plug in an a/f ratio you want it and auto keeps it at that for you?
MiamiUgen7 is offline   Reply With Quote
Old 08-03-2005   #6 (permalink)
Hwoody77
Diamond Member
Quote:
Yes sir.
Old 08-03-2005   #7 (permalink)
MiamiUgen7
MiamiUgen7's Avatar
damn. that would be nice. it would totallt eliminate the need to dyno tune the car every time you change something on it.
Old 08-03-2005   #8 (permalink)
exturbo6
Post Master General
exturbo6's Avatar
exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future exturbo6 has a brilliant future
Send a message via AIM to exturbo6
how much is it? the link does not work for me.
exturbo6 is offline   Reply With Quote
Old 08-03-2005   #9 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold
Send a message via AIM to dezod
Street value is circa $535-575
I heard the interface is more complex & it's a little harder to come by.
__________________
Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
7thgen Dedicated Section
Dezod Myspace
W: www.dezodmotorsports.com
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
dezod is offline   Reply With Quote
Old 08-03-2005   #10 (permalink)
TheSmuggler
Well if that A/F statement is true above.... hmmmm
__________________
PerfectWorks
Old 08-03-2005   #11 (permalink)
IDQcivic
Diamond Member
IDQcivic's Avatar
IDQcivic should not be trusted
They took my idea! That is so sweet that you can use it to tune, very helpful so you don't run too rich/lean....
IDQcivic is offline   Reply With Quote
Old 08-03-2005   #12 (permalink)
Hwoody77
Diamond Member
Quote:
Hate to tell you,but it's been thought of.
Old 08-03-2005   #13 (permalink)
TheSmuggler
I jsut can't imagine that being true to tell you the truth, sounds similar to gaurdian.
__________________
PerfectWorks
Old 08-03-2005   #14 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Quote:
What they fail to mention is that you need a specific wideband O2 sensor to make this happen
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 08-03-2005   #15 (permalink)
KnocturnalEM2
I am your Mom's Hero!!
KnocturnalEM2's Avatar
KnocturnalEM2 is just really nice KnocturnalEM2 is just really nice KnocturnalEM2 is just really nice KnocturnalEM2 is just really nice KnocturnalEM2 is just really nice
Send a message via AIM to KnocturnalEM2 Send a message via MSN to KnocturnalEM2
Sounds nice...anyone looking to take the plunge and try it out?!?!?
__________________
~Justin~
02 NHBP Civic EX Coupe
Reppin EM2 Crew!
KnocturnalEM2 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Profec E-01 = E-manage ???? 03-Acura-1.7-EL Forced Induction and Swaps 5 06-16-2005 01:44 AM
V-AFC II terms and meanings ? kkk Other Honda Civic Parts and Products 20 11-07-2004 01:57 PM
My experiences with installing the E-Manage.... opto_isolator Honda Civic DIYs and Civic Tech Chat 20 07-02-2004 10:37 AM
I just had fun with my friends sequoia Escaladeryder Off Topic 11 12-13-2003 10:05 PM
Yellow evo 8 vids civicvtec1ps Honda Civic Racing, Street Encounters and Competition Racing 5 08-11-2003 04:14 AM
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
