Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-22-2005   #1 (permalink)
Hwoody77
Diamond Member
Hwoody77 can only hope to improve
Send a message via ICQ to Hwoody77 Send a message via AIM to Hwoody77
Piecing together a turbo kit? Here's a part list...
I just finished my turbo kit, so here's a list of all the individual parts you need to make a full turbo kit. This can be stickied because it gets asked all the times. Piecing together a kit is a complete and total headache, and I would probably just buy a kit next time...You can also go with a completely custom/ full-blown set-up with a fully built block, complete standalone, but I will not be discussing that here. At the end of the list is labor...followed by some questions you should ask to make sure everything is going to work out.
In paranthesis is what I would recommend, followed by the average price so you can tally up your pricing...
Bare Essentials
Turbo (T3 Super 60 / T3/T4 W/ Internal Wastegate ) $200-$600
Oil feed line $50-$80
T-Tap for oil feed line to hook up to factory sensor $5-$15
Fitting for T-Tap to screw into factory sensor $1-$5
Fitting for feed line to screw into T-Tap $1-$5
Fitting for oil feed line to match up with turbo $20
Oil return line $20-$50
Oil return fitting for the oilpan $5-$30
Fitting for oil return line to match up with turbo $20
Manifold (Maxrev/ Dezod/ Turbo Manifold ) $100-$1000
Manifold to turbo Gasket $1-$5
Downpipe (Custom / Maxrev) $100-$700
Downpipe to turbo Gasket $1-$5
Downpipe to exhaust Gasket $1-$5
Piping / Hoses / Couplers for your charge pipe $50-$200
4 QTS of new oil ( Synthetic is recommended) $10-$50
Honda Gasket Sealant - $5
Recommended Parts
Colder Spark Plugs ( Denso IK20 ) $40-$60
External Wastegate ( 38 MM Tial Wastegate ) $150-$200
Vacuum Line for Wastegate $1-$2
T-Tap for Vacuum Source $1-$5
Wastegate to turbo gasket $1-$5
BOV ( Greddy Type S BOV ) $80-$200
BOV Flange $10-$40
BOV Gasket $1-$5
Vacuum Line for Blow off Valve $1-$2
RSX Injectors ( 320 CC ) $20-$300
Longer bolts for the RSX Injectors to the Fuel Rail $1
Intercooler ( None Specified ) $50-$600
Piping / Hoses / Couplers for Intercooler set-up $200-$1000
Fuel Management ( V-AFC / S-AFC ) $100-$300
Missing Link $20-$50
Air Filter for Turbo Intake Pipe $5-$30
Manual Boost Controller $30-$100
No Shortcuts
Modded Fuel Rail for Return Fuel Set-up $20-$70
Fuel line to run into fuel tank (Stainless Steel) $20-$100
Fitting for Fuel Pressure Regulator to Fuel tank $5-$20
Fitting for Fuel Line to Fuel Tank $5-$20
Fitting for fuel tank $5-$20
Hoses for fuel tank $10-$100
Clamps for fuel lines in tank $25-$20
Fuel Pump ( Walboro 255 LPH ) $50-$150
Boost Referencing Fuel Pressure Regulator ( Aeromotive ) $100-$200
Vacuum Line for Fuel Pressure Regulator $1-$2
Fitting for Fuel Pressure Regulator fuel line to Fuel Rail $5-$20
Fitting for Fuel Rail to Fuel Pressure Regulator $5-$20
Plug for one side of Fuel Pressure Regulator $5-$20
440 CC Injectors ( RC Engineering) $200-$400
Afermarket Clutch ( Exedy Organic/ ACT Street Disk ) $150-$300
Fuel Management ( Greddy E-Manage ) $150-$400
Greddy Pressure Sensor $50-$100
Greddy Pressure Harness $10-$40
Greddy Ignition Harness $10-$40
Greddy Injector Harness $10-$40
Wideband ( AEM UEGO / Innovative LM1 / PLX M-300 ) $250-$800
T-Bolt Clamps for Piping $50-$100
Electronic Boost Controller ( Profec E/B ) $100-$600
Vacuum Line for Boost Controller $1-$2
Vacuum Manifold ( Golden Eagle) $20-$50
Fittings for your Vacuum Manifold to Vacuum Sources $5-$30
Magnetic Oil Drain Plug $10-$60
Labor
Clutch Install $100-$400
Turbo Install $300-$1500
Fuel management Install $50-$600
Fuel System Install $50-$800
Does the bolt pattern on the downpipe match the turbo?
Does the turbo piping match with the outlet of the turbo?
Is the fitting for the oil return line able to be welded to your oil pan
(Remember EX has an aluminum oil pan)?
Do all your fuel / oil fittings fit correctly with each other?
Does the turbo footprint match your manifold?
Do you have gaskets for all your turbo components?
Will A/C or P/W interfere with your manifold/ downpipe/ wastegate/ turbo?
Do your vacuum lines match their respective components?
Will your piping hold under boost?
Can your fuel set-up handle 60+ PSI?
If your oil return/feed line sized correctly with correct fittings to not rub on the downpipe or any other hot/ moving components of your engine?
Where will you get the car tuned?
Anything I missed feel free to let me know...thanks! Sticky this!
If there's anything I left out, let me know...thanks!
Hwoody77 is offline   Reply With Quote
Sponsored Links
Old 06-22-2005   #2 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
I like the post and stuck it to the top for ya!!! Hopefully a mod will add this list to the FAQ!
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 06-22-2005   #3 (permalink)
HondaLuver
Its a celebration bitches!
HondaLuver's Avatar
Send a message via AIM to HondaLuver
im too lazy, but hot much r u guesstamating, wouldn't it be just cheaper to get a kit
__________________
01 SSM em2 k24 hybrid
06 Red CBR600RR
Status:
01 SSM em2 built k24bar'd NA tune(till turbo time)...240.7 hp and 190.9 tq
Stuff for sale
HondaLuver is offline   Reply With Quote
Old 06-22-2005   #4 (permalink)
Chris3k2
Member
Chris3k2 is an unknown quantity at this point
any websites where we can get some of the small parts. such as gaskets, hoses and etc.???
Chris3k2 is offline   Reply With Quote
Old 06-22-2005   #5 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
Quote:
if there is a kit that has all the stuff that you want then a kit will prolly be cheaper. But im sure if you are a shopper then you can get a custom setup cheaper. It's all a matter of what you want/need/must have. I went custom because this way i can say I built my turbo kit. And i have learned a lot from it. But if your not in to fabricating stuff and searching for all the misc stuff you need, then i would suggest you go with a kit.
__________________
Or
DIY Head gasket
Old 06-22-2005   #6 (permalink)
Havok2k1
Wicked Pissah Admin
Havok2k1's Avatar
Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future
Good write-up
I'll leave this stickey'd for a week or so. I added it to the Turbo FAQ, but there already was a custom kit FAQ (which wasn't as thorough as this one). Like I have said before, its very helpful when people write this stuff up, I just hate cluttering the top of the forum with stickeys that can be condensed into one... aka: The Turbo FAQ
__________________
I Like Cheeseburgers
Havok2k1 is offline   Reply With Quote
Old 06-26-2005   #7 (permalink)
paradoxblue
Ultimate Member
Send a message via ICQ to paradoxblue Send a message via MSN to paradoxblue
awesome man exactly what i needed.
so the no short cuts is stuff i nEED right?
and if i jsut buy these parts for the D17 engine i will be fine.. or do i need to worry about part a and part b matching each other.. if there made for the engine. that will fit. but will allt his stuff fit togethor?
reason i want to piece on out. is cause i cant afford 4G
but a fe whundred here adn there i can do.
awesome!! saved to a txt file. woot
and what of this could be sfely gotten off ebay?
paradoxblue is offline   Reply With Quote
Old 06-26-2005   #8 (permalink)
paradoxblue
Ultimate Member
oh. people also lets start posting links to the cheapest places to buy this stuff. keep it in onwe post.
if you find a deal on a turbo or piping or a harness. post it up
Old 06-26-2005   #9 (permalink)
FTK01CIVIC
Diamond Member
FTK01CIVIC's Avatar
Send a message via AIM to FTK01CIVIC
very helpful!
__________________
http://home.comcast.net/~c.vivar/civic01/sig007.JPG
2001 Honda Civic HX Coupe
NEW PICS OF THE RIDE!
FTK01CIVIC is offline   Reply With Quote
Old 06-27-2005   #10 (permalink)
honda12
New Member
honda12's Avatar
honda12 is an unknown quantity at this point
Nice,how much your performance got up after this parts,I mean Turbo?
honda12 is offline   Reply With Quote
Old 07-01-2005   #11 (permalink)
DMunny
Member
DMunny is an unknown quantity at this point
i see you're going T3/T4 hybrid. I also know that HKS has a exhaust manifold with a t25 flange. I'm pretty sure a T3 is bigger than a T25, but a T25 would spool quicker...right? And also be good on a stock aplication, i.e. stock internals. You can also pick up a T25 failly cheeply from those DSM heads that just throw them away.
I'm just curious to see the pros and cons of T3/t4 vs. T25. Personaly I'm just looking to hit around 200 to the wheels at around 8psi. Nothing too extream. I'm not rich by any means.
DMunny is offline   Reply With Quote
Old 07-01-2005   #12 (permalink)
Blk2k2civy
Member
Blk2k2civy's Avatar
Blk2k2civy is an unknown quantity at this point
http://turbopiping.com/ is where i'm looking they have some good stuff
Blk2k2civy is offline   Reply With Quote
Tags
320 , boost , controller , greddy , installation , profec , type
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330 dezod Forced Induction and Swaps 1412 10-03-2007 01:43 PM
HX turbo questions ACURAwerx Forced Induction and Swaps 8 09-30-2004 03:35 PM
Recommended fuel set-up? Hwoody77 Forced Induction and Swaps 2 05-13-2004 02:14 PM
Check this turbo for sale!!! maxxam25 Forced Induction and Swaps 13 05-08-2004 12:45 AM
User Login
Our Partners
used new
Top 10 Threads
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
