| yeah, you can do that. I know TSI's unit is universal, so it may actually be ok. I would call TSI, and ask if you can hook up 4 injectors, and if you should use an extra or different brown wire.
The way TSIs controller works is by controlling the extra injectors. So your car will still drive like stock, since you wont be altering the stock injectors. When your car hits boost is when the 2 extra injectors dump in the extra fuel.
so you will be running 6 injectors, 2 of which you control. I wouldnt hook that unit up to the stock injectors or any other injectors than the size TSI sends you. Im not sure what size they are. But TSIs unit would be set for that size injectors, nothing smaller or bigger, IMO. |
