Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-20-2005   #1 (permalink)
Boost_Junkie
Platinum Member
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura about Boost_Junkie has a spectacular aura about Boost_Junkie has a spectacular aura about
Garret T3/T04 .48A/R vs T3 Super 60 .48A/R
which would be better for our d17 application in your opinion? i mean do they both start to spool and get full boost at the same rpms? or do they equally put out as much hp...yada yada...lookin for an answer from dezod To remove this ad, register today for free or log in if already registered!
Boost_Junkie is offline   Reply With Quote
Sponsored Links
Old 01-20-2005   #2 (permalink)
4drcivic2k1
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1's Avatar
4drcivic2k1 is an unknown quantity at this point
T3 Super 60 would be the better choice.
Are you looking at at T3/T04E or T04B? A T04E is too big for a stock motored application.
4drcivic2k1 is offline   Reply With Quote
Old 01-20-2005   #3 (permalink)
Pedro Lopes
Senior Member
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
I say the T3 super 60 spools a little faster than the T3/T04. The T3 is what my turbo guy recommended for my car. He says it will spool between 3,200-3,400 but you knows there are so many opinions on this subject. Good luck with your turbo project.
Pedro Lopes is offline   Reply With Quote
Old 01-20-2005   #4 (permalink)
HyaBoosta
HyaBoosta's Avatar
Send a message via AIM to HyaBoosta
depends what you plan to do with the motor and how much power you want to achieve.
HyaBoosta is offline   Reply With Quote
Old 01-20-2005   #5 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold
Send a message via AIM to dezod
The T3/T04E is geared more toward a built motor and higher boost application.
The T3 Super 60 is geared toward stock bottom end and daily driving.
__________________
Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
7thgen Dedicated Section
Dezod Myspace
W: www.dezodmotorsports.com
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
dezod is offline   Reply With Quote
Old 01-20-2005   #6 (permalink)
Boost_Junkie
Platinum Member
well, i really dont plan on building the engine and just probably plan to run the tial 38mm wastegate at .4 bar which would be like...5.5-6psi? something more on the safe side for the unbuilt engine
so if i just want to run the .4 bar i wont need the greddy electronic boost controller rite?
and even though i want to run emanage...would i still need the synapse missign link?
so ill prob go with the garret t3 super 60
Old 01-20-2005   #7 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Stock bottom end, low boost....T3 all the way
The boost controller will keep the WG closed as long as possible and increase boost response. Not necessary, but a nice luxury.
FYI-on this note, the WG starts to creep open a few PSI prior to the spring max....so this creates a chase your tail scenario w/o a boost controller.
No you won't need the ML if you use the E-Manage because with the E-Manage, you have the option of using the voltage clamp, which is like the ML.
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 01-20-2005   #8 (permalink)
KalliGarri
A.K.A BlackCar --- Not From Califorina!
KalliGarri's Avatar
KalliGarri is on a distinguished road
Quote:
you just answered a question of mine
KalliGarri is offline   Reply With Quote
Old 01-20-2005   #9 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Quote:
Excellent.
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 01-20-2005   #10 (permalink)
Boost_Junkie
Platinum Member
please explain chase your tail i dont follow...i mean i could always get a manual bc rite?
Old 01-20-2005   #11 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Ok...
Scenario: TiAL 38MM w/ a 6 PSI spring
No EBC
Turbo builds boost...at about 3 PSI it creeps open...4 PSI a little more...5 PSI even more.....6 PSI fully open.........The turbo is trying to build more boost quickly, but the WG can not stay shut....therefore, you want better boost response so you change the spring in the WG........same scenario with say an 8 PSI spring.....begins to open at 4 PSI.....fully by 8.....Chasing your tail.
The boost controller diverts the pressure from the WG to keep it closed as long as possible thus improving boost response because now the WG is staying fully shut to 6 or 8 PSI then flying open.
Hook me up with some rep points if this made sense and helped you.
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 01-20-2005   #12 (permalink)
Pedro Lopes
Senior Member
Thanks dezod I just learned something.
Old 01-20-2005   #13 (permalink)
Havok2k1
Wicked Pissah Admin
Havok2k1's Avatar
Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future Havok2k1 has a brilliant future
...added to turbo FAQ.....
__________________
I Like Cheeseburgers
Havok2k1 is offline   Reply With Quote
Old 01-20-2005   #14 (permalink)
Boost_Junkie
Platinum Member
nice explanation ...iono if i have the money ill get the greddy electronic bc...can i get a manual bc?
Old 01-20-2005   #15 (permalink)
allmotor
nor cal 7thgens
allmotor's Avatar
great info
allmotor is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
WTB:T3/T4 Turbo HyaBoosta Honda Civic Parts Wanted 1 12-08-2004 10:13 AM
T3 Super 60 Turbine Choices abmerop18 Forced Induction and Swaps 11 08-16-2004 01:17 PM
Where to buy a t3 super 60? abmerop18 Forced Induction and Swaps 6 08-09-2004 03:32 PM
GARRETT or TURBONETICS TURBOCHARGERS? dezod Group Buy's Wanted 54 08-09-2004 02:59 PM
wtb: turbo, gauges etc chrisgushue Honda Civic Parts Wanted 11 02-17-2004 04:11 PM
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
