Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-15-2004   #1 (permalink)
opto_isolator
Ultimate Member
opto_isolator's Avatar
opto_isolator has a spectacular aura about opto_isolator has a spectacular aura about opto_isolator has a spectacular aura about
Post Mistake - Missing link doesn't really suck ass, just not a good solution with emanage
Quote:
Ok guys - this thread is not meant to disrespect ANYONE on the board about parts - but this is truly a waste of money if you are using the emanage.
I just installed one tonight to see if it improve my drivability at all...well, was I mistaken. Car started, idled and ran fine. Than I slowly went into into boost, which is where my problems came into play.
I started to see extremely lean values in my wideband, so I backed off. At first I thought it would be a leak at the MAP sensor, no it wasn't that.
After datalogging the MAP sensor through the emanage - I saw that the missing link locked out the map voltage round 2.08 volts. This is far below my 2.95 boost cut setting in my emanage.....THAT is where my lean spot came from. That approximately .9 volts is huge! I can't believe the damn thing clamps voltage that low.....
The ECU still has fueling capacity on the stock maps all the way to 0 vac. I'm taking this POS of tomorrow....
Don't run this if you are using the emanage - if you do, you will have to tune your car a lot more than necessary.....
Read below - I made a mistake.....
opto_isolator is offline   Reply With Quote
Sponsored Links
Old 10-15-2004   #2 (permalink)
bakablo
Senior Member
bakablo's Avatar
bakablo is an unknown quantity at this point
good stuff.. my cars getting tuned next week.. I didnt put in a missing link.. and now that I know this.. I wont either.. thx opto
much much appreciated
:thumbsup:
__________________
msn.. andresanto@hotmail.com
bakablo is offline   Reply With Quote
Old 10-15-2004   #3 (permalink)
flowerpowerlove
just breathe...
flowerpowerlove's Avatar
flowerpowerlove is an unknown quantity at this point
yeah, thanks for the heads up!
flowerpowerlove is offline   Reply With Quote
Old 10-15-2004   #4 (permalink)
supermex
supermex's Avatar
supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all supermex is a name known to all
Is there another option?
Or is better not to have one at all?
__________________
MY SHOW CAR IS FASTER THAN MY JDM CAR...FOR NOW
NX & AEM sponsored car.
2004 HONDA TUNING featured car.
1st Place at NOPI Nationals 2006
1st Place Funk Master Flex 2007
1st Place HIN's Night Shift 2007
434.3 hp 352 Lbs torque @ 21 Psi fully build D17A1
CARS WEBSITE
DRIVEN!
supermex is offline   Reply With Quote
Old 10-15-2004   #5 (permalink)
thrash_273
deploy,engage,destroy.. to fail is not an option
thrash_273's Avatar
thrash_273 is an unknown quantity at this point
none.... i dn't intindi...
__________________
2004 Civic Ex Coupe
Magnesium Metallic
" dn't hate the player, hate the game "
thrash_273 is offline   Reply With Quote
Old 10-15-2004   #6 (permalink)
opto_isolator
Ultimate Member
If you use the emanage - you don't need it....its a waste of money. In fact, I threw a baro code P1106 for the first time tonight when I installed it. Never had that code before.
Car ran fine with the clamp in place, don't plan on using it...
Old 10-15-2004   #7 (permalink)
opto_isolator
Ultimate Member
Ok - I am officially a dumbass tonight.
I opened my log files again after thinking about things. The reason that the MAP sensor voltage was .9 volts low is because of the fuel injector correction factor.
Yeah - so the missing link IS doing its job, because the MAP sensor input voltage was around 2.91 volts. But my injector correction is clamping it to .667 times that, which was outputing around 2.08v.
What happens when the missing link isn't installed? The factory MAP passes 2.95 volts, but the emanage clamps it to 2.95...
The only way to use the missing link and emanage with the injector correction factor is to "pad" the MAP signal around boost. Since you can only tune the AR map RPM against TP, there is no real way to accurately fatten up the MAP signal when boost kicks in.
The missing link works - but the boost clamp is an overall better way to tune the turbo setup.....
Old 10-16-2004   #8 (permalink)
abmerop18
Jam out with your clam out.
abmerop18's Avatar
abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future abmerop18 has a brilliant future
so you are saying the missing link works fine, but the e-manage is all you really need?
__________________
abmerop18 is offline   Reply With Quote
Old 10-17-2004   #9 (permalink)
opto_isolator
Ultimate Member
It depends on your setup...if you are using the emanage - you don't really need it, unless you want to waste your time tuning longer...
Old 10-17-2004   #10 (permalink)
canadian2k1si
Super Member
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
Quote:
OK, so if that is the case - I have E-manage, and Missing Link (Not installed Yet).
Missing Link for Sale....Hint Hint.
canadian2k1si is offline   Reply With Quote
Old 10-17-2004   #11 (permalink)
guns
Skyline R33
guns's Avatar
guns is an unknown quantity at this point
Anyone running a VAFC or SAFC will need the missing link. Someone will buy it from you post it in the forsale section.
__________________
1993 RX-7 FD3S 450whp
2005 GTO-Turbo 550whp(sold)
1995 Skyline (sold)
1990 240sx/Sylvia (complete conversion) (blown up & sold)
2004 Dodge Ram Hemi (sold)
2003 Civic Ex-T 5spd (Sold)
1989 CRX Si w/ B18a1 swap (Sold)
guns is offline   Reply With Quote
Old 10-17-2004   #12 (permalink)
opto_isolator
Ultimate Member
Yeah - I put mine for sale as well. I don't need it, plus now I need the money because I have other issues.
SAFC / VAFC guys can still use it, and they need it.....
Old 10-17-2004   #13 (permalink)
abmerop18
abmerop18's Avatar
i guess mine is for sale now too
__________________
Old 10-17-2004   #14 (permalink)
supermex
supermex's Avatar
Good feed back opto
You are a big man for admiting a mistake.
I'll use the data for consideration when tunning my car soon..
__________________
CARS WEBSITE
DRIVEN!
Old 10-20-2004   #15 (permalink)
HyaBoosta
HyaBoosta's Avatar
Send a message via AIM to HyaBoosta
thanks for posting the heads up. Im going to hold on to mine till after the install just in case.
HyaBoosta is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
