Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-22-2004   #61 (permalink)
canadian2k1si
Super Member
canadian2k1si's Avatar
canadian2k1si is on a distinguished road
I paid $75 for these used RSX injectors, and when I get them, the o-rings have sand on them, and one of the ends where the fuel sprays out is cracked, about to fall off!
Can I still use them, if I clean them & snap off this broken piece?
ID:	33536   Click image for larger version
ID:	33537   Click image for larger version
ID:	33538   Click image for larger version
ID:	33539   Click image for larger version
canadian2k1si is offline   Reply With Quote
Sponsored Links
Old 07-22-2004   #62 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold
Send a message via AIM to dezod
Good place to get injectors cleaned & flow tested:
http://www.cruzinperformance.com/
Rich is a honest and nice guy! Very professional and highly recommend.
__________________
Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
7thgen Dedicated Section
Dezod Myspace
W: www.dezodmotorsports.com
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
dezod is offline   Reply With Quote
Old 07-22-2004   #63 (permalink)
canadian2k1si
Super Member
Taht would be fine, but did you see the cracked piece on the end of one of em? I am wondering if that might mess my stuff up?
Old 07-22-2004   #64 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
Quote:
I am not sure. Call Rich from there. He'll help you!
__________________
Dezod Myspace
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
Old 07-23-2004   #65 (permalink)
cdmx
Post Master General
cdmx's Avatar
cdmx will become famous soon enough cdmx will become famous soon enough
Send a message via AIM to cdmx
So how are those rsx injectors better than stock?
And how safe is it too use another route than a returnless fuel system made by SLP..
Like what are the other optinos
Cause i hear SLP's kit will be REALLY expensive....all top of the line parts...eh too much for me
cdmx is offline   Reply With Quote
Old 08-10-2004   #66 (permalink)
Civictuner04
Super Member
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
Send a message via AIM to Civictuner04
Quote:
Originally Posted by StreetLevelPerformance
Modified OEM Fuel Rail, Boost Referencing FPR, Fuel Pump, ALL lines, ALL fittings, ALL clamps, and best of all a detailed DIY with pictures.
About 98% bolt-on with the fuel pump cage modification and mounting of the FPR to the fire wall being the only exceptions.
This kit will not be comprised of Carquest parts. Each part will be hand-picked from the best of the best.
What size injectors do u think u will be using?
__________________
Tragedy is when I cut my finger. Comedy is when you walk into an open sewer and die.
Civictuner04 is offline   Reply With Quote
Old 08-18-2004   #67 (permalink)
canadian2k1si
Super Member
Quote:
Originally Posted by opto_isolator
They are a direct replacement. The only modification that is necessary is the mounting studs on the intake manifold spacer plate.......
I was going to put those RSX ones in my car today, and test the E-manage injector size option, but what exactly needs to be modified on those mounting studs. Do they have to be removed & larger ones installed? If so, hou much larger, and do you know what type of stud to use (side, dimentions, thread, etc.)
I have time to do this today, if I can find out what exactly needs to be modified.
Thanks
Old 08-18-2004   #68 (permalink)
Hwoody77
Diamond Member
Hwoody77 can only hope to improve
Send a message via ICQ to Hwoody77 Send a message via AIM to Hwoody77
PM Opto_Isolotor, or SpdRcrCHk or madwheel, they are all running RSX injectors, and let us know how it goes!
Hwoody77 is offline   Reply With Quote
Old 08-18-2004   #69 (permalink)
canadian2k1si
Super Member
Installed RSX Injectors - Replace Stud with Bolt
I installed my RSX Injectors today;
Had to replace the fual rail stud with a bolt instead, I used a Metric (I am Canadian!) bolt 30mm, M6x10, and 2 washers because the RSX injectors are about 0.75In longer that the Stock Civic ones.
It was easy, and I set my E-manage at 240 Old & 340 New Injectors, what did other people use. This worked great, but I didn't try any other settings.
Some Pics:
Done & Done.
Old 10-07-2004   #70 (permalink)
xproductionz
xproductionz's Avatar
xproductionz is just really nice xproductionz is just really nice xproductionz is just really nice xproductionz is just really nice
Send a message via AIM to xproductionz Send a message via MSN to xproductionz Send a message via Yahoo to xproductionz
i am runnig my injectors too now.. but how has everyone modified there bolts to hold the rail down.. post up some pics
xproductionz is offline   Reply With Quote
Old 10-09-2004   #71 (permalink)
canadian2k1si
Super Member
Anybody having problems with these RSX injectors like me? My car ocassionally misses the idle point when the RPM's fall back (clutch in) and goes off! And also sometimes bogs down if I give it too much gas and not enough clutch engagement on launches.
Old 10-09-2004   #72 (permalink)
xproductionz
i have the same problem.. thats why i need emanage
Old 10-09-2004   #73 (permalink)
civicskater
Chicks dig my scent
civicskater's Avatar
^^Mine has that similar problem, low rpms (below 2K) when im idleing or in 1st and am at a roll it will kind of sputter, but throughout the rpm range isnt bad, get emanage, it'll clear it up, for my starts id rev up to 1500 with the clutch and slowly release so it wasnt as bad, once the rpms picked up
__________________
2002 Civic LX sedan turbo
COMING SOON: 2004 subuaru wrx..hopefully...
civicskater is offline   Reply With Quote
Old 10-09-2004   #74 (permalink)
canadian2k1si
Super Member
Quote:
Well I have Emanage, but not tuned. I need a tuner.
Old 10-10-2004   #75 (permalink)
opto_isolator
Ultimate Member
opto_isolator's Avatar
opto_isolator has a spectacular aura about opto_isolator has a spectacular aura about opto_isolator has a spectacular aura about
Quote:
Heh - I'm having idle problems in general....I think its just the nature of OBDII. I try to play around with it in the emanage, and it idles fine when the car is running that time, but when I go to start it another time, it idles like crap until it "learns" again....not sure why - but I am trying to figure it out....
opto_isolator is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
