Forced Induction and SwapsPost information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Ok I search a lot of time but I didn't find an answer ...
I gonna swap a k24 for a friend ( I ever swap a k20a2 in my Em)
And I want to know why everyone say we should take a k20 tranny...
What the matter with the accord tranny ?
i believe the accord has a different case. k24's have different cases so the hasport mounts dont work. if anything use an ep3 trans or base rsx trans case and swap in tsx gears. that is the perfect setup for a k24. i have a k24 with ep3 1st and 2nd, tsx 3rd, rsx 4th and 5th and tsx 6th with quaife lsd. it is awesome. good launching abilities and great midrange and tsx 6th for cruising.
I gonna remake the lower plate of the mount.... you know the top part is bolted in the lower plate...I have an access to everything for make a good job (sorry I don't know the name in english)
So I use the stock head... The ECU surelly gonna make is engine work propelly...
So the only trouble I see for now is about the MIL... because de Accord ECu is design for give the information to the cluster with only 2 wire... like the multiplex language. but the civic cluster work with individula wire...
u are supposed to use the type s or ep engine harness.. not the accord engine harness... from there wire up the engine harness according to my DIY.. then when you use the ecu it has to be one of the ecu's i stated earlier
__________________ ITS BACK!!.....
Cars.. Models.. Shows..
200+ Arcade Games and more www.xproductionz.com
Ok but...I swap this for a guy didn't really want to have 250 whp... He just get a k24a3 Accord for a cheap price and find it better than the D17 modified...
So the pinout is different... but I just plugged it differentely. He didn't want to drop a k20 head or a Kpro in a near future...
So the RAA ECU is the better way again to make the swap for a resonable price...why pay 1500$ for a Kpro and RSX ECU, when we already have the Accord one...
I ever swap a K20a2 in my Civic and the k24a3 is more complicated... but this is only bout the wiring and engine mount ... I gonna give some feedback about running the k24a3 with is ECU....
well u might have some problems because for one the accord ecu will be throwing a CEL because it will be looking for the drive by wire which you cant use on our cars.. the only way around it is to use a k20 ecu.. the other thing is that all you are going to be on your own cause your going to need the clip C101 pinout which is the in-dash harness and then from there your going to need the accord ecu pinout.... then your going have to wire the in-dash harness with the engine harness.. then wire in the relay for the primary o2 sensor.. then wire in the primary o2 sensor.. then wire in the secondary o2 sensor relay.. then wire in the secondary o2 sensor... then your need to reflash the ecu to reprogram the key so that way you can bypass the immobolizer.. if you dont bring the car down to a dealer to reflash the ecu when the cars done then the car wont start..
if you had a hondata kpro you can skip doing the immobolizer and secondary o2 sensor wiring.. because it will let you bypass those 2 things
note** - $1500 is the price of kpro with the ecu... some people think thats the price without the ecu just in case anyones wondering
