Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-01-2005   #166 (permalink)
wantaturbo
Senior Member
wantaturbo is an unknown quantity at this point
Quote:
Originally Posted by icebergslim
You need to have the wideband sensor. Your car will run but will run really rich and have crappy gas mileage. The second sensor is the secondary 02 sensor, which just tells you if the primary sensor goes bad. You dont need this hooked up. You should be getting a "CEL" what code is it throwing?
yeah i was running super rich but ruben fixed the problem and it runs great now.
As for 240 hp, i doubt it. i wanna dyno car but it feels close to 200hp. i romp rsx-s with i\h\e with ease. even stock wrx's are not a problem
wantaturbo is offline   Reply With Quote
Sponsored Links
Old 01-20-2005   #167 (permalink)
SevenCyrus
Se7enCyrus Racing/Motorsports
SevenCyrus's Avatar
SevenCyrus will become famous soon enough SevenCyrus will become famous soon enough
Send a message via AIM to SevenCyrus
So yea i wana get this right ounce and for all. the new rsx-type s engine, what engine model is it? k20a2? k20z1? And if it is not the a2, will it still fit with the hasport mounts? thanks, plz excuse the noobism.
SevenCyrus is offline   Reply With Quote
Old 01-21-2005   #168 (permalink)
Dark2k1
French ass K20a2 powered
Dark2k1's Avatar
Dark2k1 is an unknown quantity at this point
This is a k20z1 i think... but this is the same base and head... only change Intake manifold inlet and the headers.. So yes, this will fit the hasport mount.
Dark2k1 is offline   Reply With Quote
Old 02-06-2005   #169 (permalink)
Shlomo
Super Member
Shlomo's Avatar
Shlomo is an unknown quantity at this point
Send a message via AIM to Shlomo
with the k-pro, do you still have the imobilizer and all that safety stuff?
__________________
02 SSM EM2
check out my band *The Awesomes* @ http://www.theawesomes.vze.com
Shlomo is offline   Reply With Quote
Old 02-06-2005   #170 (permalink)
doubledeuce2k2
Ultimate Member
doubledeuce2k2's Avatar
doubledeuce2k2 is just really nice doubledeuce2k2 is just really nice doubledeuce2k2 is just really nice doubledeuce2k2 is just really nice doubledeuce2k2 is just really nice
Send a message via AIM to doubledeuce2k2
immobilizer can be disabled. or not. k-pro = you are in command.
doubledeuce2k2 is offline   Reply With Quote
Old 02-24-2005   #171 (permalink)
Dark2k1
Dark2k1's Avatar
I finnaly done the AF sensor, SHO2 sensor and C101/102 connector wiring convertion yesterday. (I'm very proud of me :P ) But I don't understand what I must do for the fan switch.
I have a FAL fan for Civic 96-00 with double core rad for the same car.
Can someone can help me please...
Old 02-27-2005   #172 (permalink)
Dark2k1
Dark2k1's Avatar
I did it.... I just have to plug the thermoswitch black wire on the ground and the green on the fan relay (FanControl wire, green/white one I think) at the underhood fuse box (or C101 connector). The only matter is to fit the thermoswicht somewhere, but I make a fitting for put it in the lower hose.
So I finaly make all the wiring myself... so I just have to put the engine in place, plug everything and check if everything is alright...
Old 02-28-2005   #173 (permalink)
Dark2k1
Dark2k1's Avatar
The fan relay is the one in the civic fusebox...
For the thermoswitch the civic and RSX one is the same (same OEM number)
Old 03-10-2005   #174 (permalink)
doubledeuce2k2
Ultimate Member
i think the enjos are for all k-series. not just k20xx. but there may be an extra mount needed, wouldn't surprise me
Old 03-22-2005   #175 (permalink)
wantaturbo
Senior Member
Quote:
Originally Posted by Dark2k1
Ok ... my engine now running right
But I can't bleed the clutch system... The pedal stay very too soft....It don't seen to lose oil somewhere...
So... do you think it because I keep the civic master cylinder
I know the civic clutch line usually take all the engine bay and the fitting on the master cylinder is bigger than a RSX one.
Someone here had do the swap with the Civic one er everybody change for the rsx master cilynder ?
sorry for the dumb question but i get the master cylinder and slave cylinder mixed up. are you talking about the one on the tranny or the one on the firewall? for the one on the tranny i used the rsx cylinder with a civic fitting, very easy to change.
Old 03-22-2005   #176 (permalink)
Dark2k1
Dark2k1's Avatar
This is the one near the firewall
EDIT : The civic one work fine...just take care when you make the custom line to don't have too much loop.... you can help the system bleeding with your hand... just push a couple of time directly on the bearing release fork (slave cylinder)
Old 03-22-2005   #177 (permalink)
wantaturbo
Senior Member
oh then yeah i just used the civic one. it worked fine except the friction point was almost at the floor but im sure it can be adjusted.
Old 03-22-2005   #178 (permalink)
Dark2k1
Dark2k1's Avatar
how much long approximately is your clutch line between master and slave cylinder ??
EDIT : Useless
Old 03-23-2005   #179 (permalink)
wantaturbo
Senior Member
oh damn im not sure, the hard line is stock i think, well its actually 2 hard lines right with a rubber hose in between them? jeez its been so long since i looked at a stock engine bay i couldnt tell you. i have a friend with type-s and my girlfriend drives an 04 civic so between the 2 of them ill try to figure that out for you.
Old 03-23-2005   #180 (permalink)
Dark2k1
Dark2k1's Avatar
EDIT : USELESS
Tags
02 , 2001 , accord , c101 , civic , cluster , ecu , ep3 , honda , k24a2 , k24a3 , picher , pinout , raa , swapping , turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
