Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-02-2004   #151 (permalink)
MCivic32
New Member
MCivic32 is an unknown quantity at this point
does anyone have good websites to buy the k series engines? To remove this ad, register today for free or log in if already registered!
MCivic32 is offline   Reply With Quote
Sponsored Links
Old 12-02-2004   #152 (permalink)
aznboysrfr
DOHC i-VTEC TiMEX
aznboysrfr's Avatar
aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of aznboysrfr has much to be proud of
www.passwordjdm.com
www.hmotorsonline.com
I wouldn't trust anyone else
__________________
恐怖を教えて野郎
aznboysrfr is offline   Reply With Quote
Old 12-11-2004   #153 (permalink)
SevenCyrus
Se7enCyrus Racing/Motorsports
SevenCyrus's Avatar
SevenCyrus will become famous soon enough SevenCyrus will become famous soon enough
Send a message via AIM to SevenCyrus
Well, I was about to order wheels, and they said that if i get wheels specified for my civic, when it comes time to get SI axels, they wont work. I also compared specs and they are diff. SI have 5-114.3 on wheel and civic has 4-100. Or is the guy wrong??
SevenCyrus is offline   Reply With Quote
Old 12-12-2004   #154 (permalink)
Hawk
You boost, I-VTEC
Hawk's Avatar
Hawk is a jewel in the rough Hawk is a jewel in the rough Hawk is a jewel in the rough
Axles have nuthing to do with the lug pattern. The 04-current SIs have 5 lugs. You need the axles off the 02-03 SI if you plan to keep your car 4 lug.
__________________
http://OpieandAnthony.com
Hawk is offline   Reply With Quote
Old 12-12-2004   #155 (permalink)
SevenCyrus
SevenCyrus's Avatar
ahh shit. lol, got it. Thanks. So the ones that hasport sells is perfect with wheels that im gona get for my civic right now?
Old 12-12-2004   #156 (permalink)
Hawk
You boost, I-VTEC
Hawk's Avatar
that i don't know. Email hasport and ask them if the axles they sell work with your existing brake/hub setup.
__________________
Old 12-12-2004   #157 (permalink)
SevenCyrus
SevenCyrus's Avatar
Ic. Ok so what do u know for shure? The 02-03 Sir axels can be installed on my civic, will suport K20a2, and will fit with wheels that are origenoly bought for my Civic DX?
Old 12-12-2004   #158 (permalink)
Hawk
You boost, I-VTEC
Hawk's Avatar
Quote:
yes 02-03 SI axles will work with your exsiting setup.
__________________
Old 12-12-2004   #159 (permalink)
wantaturbo
Senior Member
wantaturbo is an unknown quantity at this point
oh yeah i forgot 04-05 si has 5 lug now. its funny because i was using ruben stock si rims before i got tires for my rsx rims, i probobly should've known that lol
wantaturbo is offline   Reply With Quote
Old 12-13-2004   #160 (permalink)
Hawk
You boost, I-VTEC
Hawk's Avatar
coo, thanks guys. So hows the gas with the k20? mileage wise.
i normally get somewhere close to 300 on the tank. I used to get 330 so i'm really not losing much for what i'm gaining
__________________
Old 12-21-2004   #161 (permalink)
Dark2k1
French ass K20a2 powered
Dark2k1's Avatar
Dark2k1 is an unknown quantity at this point
I see in the RSX manual shop (also heard something on Hasport site) I neeed the AF sensor. But this seen to be a o2 sensor with another name. Do you know if I really have to buy it from Acura, or a Honda o2 sensor will make the same work...
EDIT: The AF sensor is a wideband o2 sensor, for a better effiency you must use it
Dark2k1 is offline   Reply With Quote
Old 12-21-2004   #162 (permalink)
wantaturbo
Senior Member
Quote:
i dont have an AF sensor. There is some pretty tricky wiring when it comes to the o2 sensors and i have no idea what ruben did but my car runs fine without an AF senor.
your car looks tight by the way. I used to have those rims before i went 5 lug. My car is the same color too but with 4 doors. nice carbon fiber hood too. Im jealous
Old 12-31-2004   #163 (permalink)
Bmkarr
Senior Member
Bmkarr is an unknown quantity at this point
Send a message via AIM to Bmkarr Send a message via MSN to Bmkarr Send a message via Yahoo to Bmkarr
if you do the electric power steering from the si then cuttin the hood wont be a issue right?
Bmkarr is offline   Reply With Quote
Old 12-31-2004   #164 (permalink)
wantaturbo
Senior Member
Quote:
i would assume that to be correct but i dont know cause i dont have it. go to the dealership and check it out.
Old 01-01-2005   #165 (permalink)
icebergslim
BOOSTED HYBRID
icebergslim's Avatar
icebergslim is an unknown quantity at this point
Quote:
You need to have the wideband sensor. Your car will run but will run really rich and have crappy gas mileage. The second sensor is the secondary 02 sensor, which just tells you if the primary sensor goes bad. You dont need this hooked up. You should be getting a "CEL" what code is it throwing?
__________________
*11.55@120 20 lbs* 2k1 civic coupe
FOR SALE:
24.5x8x15 MH slicks
24.5x8x13 MT slicks
PM me if you're interested
"Hondas are like that old girlfriend thats just always around in case you need some action but you dont stay with her because you think you can do better but in time you realize she was the best thing you ever had" -An STI owner
icebergslim is offline   Reply With Quote
Tags
02 , 2001 , accord , c101 , civic , cluster , ecu , ep3 , honda , k24a2 , k24a3 , picher , pinout , raa , swapping , turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
