Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-07-2004   #1 (permalink)
JohnyBlaze
Member
JohnyBlaze is an unknown quantity at this point
Question For those with blown/damaged Head Gaskets...
For those of you who have damaged your head gaskets with too much boost, when you removed the head to replace the gasket, was the blown gasket visibly damaged/cracked?
I blew my HG about 3 months ago while tuning the car with a faulty wastegate actuator (which caused all sorts of boost spikes 11+ psi). I got the common symptom of a pressurized coolant system with all of the coolant pushed out through the overflow bottle (and then an overheated motor). Later on, I had the coolant system tested chemically which proved that combustion by-products were definitely leaking into the coolant system. Anyways, the headgasket is being replaced now. Everything looks good with the head off: pistons are fine, block is fine, head is not warped or cracked (passed all pressure tests).
What I find odd though is that the old head gasket doesn't appear to have any major damage. Some of the rubber seems to be damaged, but the metal part is still intact and not at all cracked.
What did your head gasket damage look like? I'm just worried that there's something else wrong -- not the head gasket. Not sure what it might be though, given the described symptoms.
On a related note, what's the latest general consensus on what the max pressure our stock head gaskets (with stock head bolts) can withstand before cracking? 8 psi daily seems to be safe for most people -- properly tuned of course. What if you see random boost spikes around 10 psi here and there? Is that okay?
Any thoughts?
Thanks,
-jB
JohnyBlaze is offline   Reply With Quote
Sponsored Links
Old 01-07-2004   #2 (permalink)
OsOBooSTeD
OsOBaNNeD
OsOBooSTeD's Avatar
Send a message via AIM to OsOBooSTeD Send a message via Yahoo to OsOBooSTeD
11psi daily is what some of us are running its all about the alcohol injection
that is why SF rules...
and from what little i know.. sometimes the headgasket gets flattened or pressured which causes it to leak but not break. i duno thats just my 2 cents..
OsOBooSTeD is offline   Reply With Quote
Old 01-07-2004   #3 (permalink)
C2i0v0i1C
SuperMODrizd
C2i0v0i1C's Avatar
C2i0v0i1C should not be questioned C2i0v0i1C should not be questioned C2i0v0i1C should not be questioned C2i0v0i1C should not be questioned C2i0v0i1C should not be questioned C2i0v0i1C should not be questioned C2i0v0i1C should not be questioned C2i0v0i1C should not be questioned C2i0v0i1C should not be questioned C2i0v0i1C should not be questioned C2i0v0i1C should not be questioned
Send a message via AIM to C2i0v0i1C
WRONG
C2i0v0i1C is offline   Reply With Quote
Old 01-07-2004   #4 (permalink)
StreetLevelPerformance
Your Parts Guy
StreetLevelPerformance's Avatar
StreetLevelPerformance is on a distinguished road
does ARP make head bolts for our application? maybe they would hold better under the stresses of boost.
__________________
Street Level Performance
sales@streetlevelperformance.com
Fuel Return Conversion Kit
NRG Strut Bars
TSI Extreme Turbo Kit
StreetLevelPerformance is offline   Reply With Quote
Old 01-07-2004   #5 (permalink)
OsOBooSTeD
OsOBaNNeD
OsOBooSTeD's Avatar
Quote:
Originally posted by C2i0v0i1c
WRONG
dont hate .
alcohole injection is the way to go if u dont have the $$ on hand to do internals...
so take ur PHD degree somewhere else
(Playa Hatin D1ckhead)
Old 01-07-2004   #6 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned andyman97 should not be questioned
Send a message via AIM to andyman97 Send a message via Yahoo to andyman97
I went through 4 head gaskets. None of the metal was cracked. That isn't what makes the seal. The rubber rings that go around the cylinder holes are what go and cause the coolant to get into the cylinders.
__________________
02 Civic d17a2 turbo
490 whp/360 tq @ 31 psi
-If you pm me and I don't respond, it's because, either:
a) Your question is stupid
-or-
b) it can be found by searching if you'd quit being lazy
andyman97 is offline   Reply With Quote
Old 01-07-2004   #7 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
You should also inspect the head for cracks in the combustion chamber and also make sure the head isn't warped. I'm not too sure if either is a common problem on the D17 or not. Im not familar at all if our block surfaces can have an effect on the sealing of the combustion chamber, but im sure you would want to make a inspection of it too.
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 01-07-2004   #8 (permalink)
futurersxswap
Passin' You On 19's.....!
futurersxswap's Avatar
futurersxswap is an unknown quantity at this point
Send a message via AIM to futurersxswap
head gasket can leak where you cant see it... under pressure little cracks taht you cant see get big enough to cause trouble....
__________________
http://www.7thgencivic.com/forums/at...postid=1359588
13.38 @ 109.13 ... 2.412 60'.. i need tires!....
SF RULES street and track
1st 7th gen with a DHRACING crank pulley> havent been to track with it on yet
futurersxswap is offline   Reply With Quote
Old 01-07-2004   #9 (permalink)
RiceBuRNeR
Turbo Member
RiceBuRNeR's Avatar
RiceBuRNeR is an unknown quantity at this point
Send a message via AIM to RiceBuRNeR
How would alcohol injection make a diff? you still have the same amount of pressure pushing on the gasket, and the rest of the internals. Alcohol just helps w/ cooling and detonation.
RiceBuRNeR is offline   Reply With Quote
Old 01-07-2004   #10 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
Well, detonation can cause pistons and rods to break, believe it can cause headgaskets to blow as well.
__________________
-or-
Old 01-07-2004   #11 (permalink)
C2i0v0i1C
SuperMODrizd
C2i0v0i1C's Avatar
dont hate .
im not hating just that some/if not most people on this site have ALCHY INJ so far stuck up their ass that not even an enema a day would dislodge it
Old 01-08-2004   #12 (permalink)
Catalyst
Ultimate Member
Catalyst's Avatar
Catalyst is just really nice Catalyst is just really nice Catalyst is just really nice Catalyst is just really nice
Send a message via AIM to Catalyst
head gaskets mainly blow because of slight detonation. Dont go and say its from too much cylinder pressure and that it never detonated. Dave hickman ran 9's on the stock head gasket. If you prevent it from detonating, you wont blow a gasket easily. If his boost was spiking, then he was most likely running into light detonation. The alcohol does an extremely good job at preventing detonation.
__________________
Out with the Old, In with the new..... Motor that is
Catalyst is offline   Reply With Quote
Old 01-08-2004   #13 (permalink)
civic01vtec
The only job I need is a blowjob
civic01vtec's Avatar
civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned civic01vtec should not be questioned
Send a message via AIM to civic01vtec
alot of drag cars use OEM head gaskets b/c u are better off having the gasket blow to alert u of damage b4 something serious get screwed up.
__________________
The 2nd Amendment America's original homeland security
'01 Civic EX -- boosted
'99 Chevy 2500 Ext. cab 4x4 with a
454 <--- under 10 mpg
'02 Chevy Trailblazer
civic01vtec is offline   Reply With Quote
Old 01-08-2004   #14 (permalink)
andyman97
Turbo Guru Mod
andyman97's Avatar
Quote:
This is very true as well. It's good to have a weak link instead of destroying a piston.
__________________
-or-
Old 01-08-2004   #15 (permalink)
iamboo
Retired - SoCal FI Mod
iamboo's Avatar
Send a message via AIM to iamboo
settle down children...
iamboo is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
The 7thGen Nitrous FAQ.
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
