Quote:
Originally posted by andyman97 I hate this boost controller. I've had it since I've had the turbo and I still can't set it accurately. |
Ok.
Is it spiking or is the boost falling off? If it is spiking then you want to turn the gain down 2%. If boost is falling off then turn the gain up 2%.
Also, make sure your set gain is close to your start boost setting. I know one is a percentage and one is PSI/KPA but you will need to determine the total output of your turbo to correctly set these settings.
If total output is 20 psi then 4 psi for set gain would be 20% for start boost.
