Forced Induction and SwapsPost information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
From what i hear dude the dry kits are WAY too dangerous. Running a danger of having an uneven about of nitrous in each cylinder plus the issue with the factory fuel pump not being able to supply the extra needed fuel, if i remember right something about our injectors or SOMETHING thats has a return feed..........meaning the extra fuel would be routed back to the tank or pump. Then that would cause ur engine to run lean (i think) and lean+nitrous-->BOOM! Long story short, me and coutless other 7thgen-ers would HIGHLY recommend a wet kit. The extra needed fuel gets mixed and atomized in the spray in your intake runners. Wet kits are a little more pricey, but would you rather spend a few extra hundred dollars or a few grand replacing your engine? If i'm wrong or too vauge about anything above then somebody please correct me. Oh, and yes, if you still do stick with the dry kit then yes, you can intall it onto your stock airbox, but most peeps would recommend on upgrading your intake.
Dry shots are just that. DRY, the air going into your car is cooled tremendously by the n2o <like a fridge> and it is the colder air that causes an increase of power more than the actual n2o itself.
also the shot is based off of a full bottle. as you use it you wont feel as much of a punch. i think the recommend pressure is 900psi <dont quote me on that>
I would also recommend a blow-down kit. the n2o bottle has a burst disk that will blow in an extreme pressure situation the blow down will keep you from being exposed to it in the car. It diverts the gas out of your trunk.
All you need to do to change your fuel deficiency is a FPR <b&m makes one>
If you are not going over 55shot you dont really need to worry about going lean. 35-55 shot should be fine on stock inj and stock fuel pump.
anything over 55 you should prolly either go wet OR get bigger injectors.
I have a friend with a 99si on a 75 dryshot stock injectors and he has 0 issues. He has the FPR tho so he can correct any fuel mix issues he has.
If you are REALLY worried about it or want some crazy ass power do a motor swap and build it out.
and I am pretty sure higher compression pistons will help with the n2o
__________________ Wait a minute! What am I doing.? I am far too sober for this.
You sound like you're a little lost in the n2o department...if you're suggesting that a dry kit is a better choice for our 7th gens and is just as safe as a wet kit, I'm sorry but I think you're outta your fvckin mind. Using a dry kit on our 7th gens does cause our a/f to lean out. Ask anyone on the board here who has ever used one. A wet kit doesnt require a FPR on our cars either. I can bet your friend HAS encountered a couple issues along the way using his dry kit on his SI regardless of what he has told you. Also, I can run my bottle damn near empty and still get just had hard of a punch out of it as I can when its full as long as the bottle pressure is high enough.
Have you had any dyno time to tune your a/f ratio??
wet 50 and 35 causes our cars to run really rich, around 15.8,I had to use a 50 shot nitrous jet and a 35 shot fuel jet to get a a/f ratio of 14.7, which IMO is still to rich. You could easily get away with using a dry 35 shot using no fuel mods, a/f ratio may be a little on the lean side, but not enough to cause detonation.
I personally havent, but I know someone who has with the same kit with the 75 shot and they were not running too rich at all (between 11 and 12) What was your bottle pressure at during those runs? Thats a very important factor regardless of what shot you're using. If the pressure is between 900-1050psi with a wet kit, then you shouldnt be running rich period.
denso iridium ik20 plugs are more than enough to use. I personally went to vic edelbrock headquarters and asked them if this was ok and they said yes its more than ok.
I got a quick question. If I bought the 55 shot ZEX kit, and armed it, since I have an auto, i'm always on wot when racing lol. Is there gonna be a problem here, something i should take careful note of?
Could somebody answer this question....I'm in the same boat.
N2O NooB questions:
Can activating the a N2O shot right when you launch with an auto hurt? In what way if any?
Can us auto guys flip the switch of the wet kit at a light when we are stopped, and then when he hit WOT the system will activate? Will this hurt the engine in any way?
What other precautions would us lowly auto guys have to take if we want to spray?
Sombody mentioned if you can use ur factory fuel line/pump to feed your wet system. I have a 04 Civic EX and I had to install a inline fuel pump to help the system run in the sweet spot. By using your stock line you will run lean, I ran a50 and 75. Clutch, will go in no time specially w/ a 75. It sucks too my car only has 7,000 miles :-(
P.s. I run a NOS wet system with remote opener, purge, a/f guage.
you shouldn't use any type of precious metals when using nitrous. stick with copper plugs, ngk coppers are fine.
I know that 'Wet' Nitrous contains both Nitrous and fuel (helps to keep correct AF ratios), but I'm wondering where the fuel comes from? (Do you need ot tap into the cars fuel line, or is it actuualy mixed within the tank?) from the pictures I've seen of kits, it looks like there's 2 lines (usually red and blue) that feed into the nozzle...so I'd assumed that the fuel line is coming from the car's fuel line-is this right?
One more Q:
is there a way to install more than one nozzle, say a 35 and 50 shot, so I can switch between the two depending on who I'm runnign against?
