Forced Induction and SwapsPost information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Great thread btw...lots of great info...thanks to everyone that contributed...
now for my question...for spark plugs...are the IK20's the proper plug to use?? Thanks!!
__________________ ~Justin~
02 NHBP Civic EX Coupe
Reppin EM2 Crew!
Sponsored Links
What's up with the zex dry kit is any one running it on there car. I found one for 200.00 and its almost new is that a good deal should I get it. Its a complete kit with 3 different jets. and if I do get it can I use it on the stock air box any info on dry kit will be helpfull thanks
From what i hear dude the dry kits are WAY too dangerous. Running a danger of having an uneven about of nitrous in each cylinder plus the issue with the factory fuel pump not being able to supply the extra needed fuel, if i remember right something about our injectors or SOMETHING thats has a return feed..........meaning the extra fuel would be routed back to the tank or pump. Then that would cause ur engine to run lean (i think) and lean+nitrous-->BOOM! Long story short, me and coutless other 7thgen-ers would HIGHLY recommend a wet kit. The extra needed fuel gets mixed and atomized in the spray in your intake runners. Wet kits are a little more pricey, but would you rather spend a few extra hundred dollars or a few grand replacing your engine? If i'm wrong or too vauge about anything above then somebody please correct me. Oh, and yes, if you still do stick with the dry kit then yes, you can intall it onto your stock airbox, but most peeps would recommend on upgrading your intake.
K, i got a question. I understand that with nitrous i shouldn't have any ECU upgrades or the Venom 400 or anything else that advances the ignition timing, but would other engine mods like a crank pulley, or undrive pulleys put my engine in risk?? Some insight would be very helpful
I got a quick question. If I bought the 55 shot ZEX kit, and armed it, since I have an auto, i'm always on wot when racing lol. Is there gonna be a problem here, something i should take careful note of?
will I have trouble passing smog on my 2004 Civic here in California if I have a ZEX nitrous kit installed in the car at the time of the somg inspection?
__________________
No Mission Too Difficult
No Sacrifice Too Great
Duty First
I wouldnt think so, not unless you plan on using the nitrous while they're doing their emissions test.
so will denso IK20's work and if not what spark plugs are compatible besides the copper ones. A lot of people around here say that the platinum tips or whatever are better than using copper or nickel. Does that just apply for stock cars or for cars with nitrous too??
NEVER use platinum tips with nitrous. Use ngk instead of denso for nitrous.
