Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Forced Induction and Swaps
Forced Induction and Swaps Post information/questions about Forced Induction methods (Turbos & Nitrous Oxide) and swaps here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-12-2008   #181 (permalink)
angel alberto
New Member
angel alberto is an unknown quantity at this point
Re: The 7thGen Nitrous FAQ.
Quote:
Originally Posted by 02civic View Post
not sure about the numbers you'd get...elevation and weather along with driver skill could add up to as much as .8 +/-. With a 50 shot i'd expect to see low 15's....if not a 15 flat. a 75 shot would probably put you in the mid 14s on a stock vic...tires would hold you back though
me civic 2001 do 18.1 seg auto tranny , if I put a nos kit 50hp , how time I can espect? I think put a dynotune kit ,
angel alberto is offline   Reply With Quote
Sponsored Links
Old 05-12-2008   #182 (permalink)
dryft
Senior Member
dryft's Avatar
dryft will become famous soon enough
while the threads revived, thought i'd ask a question that's been bugging me.
They say not to spray in 1st or 5th gear because you cannot "rev freely". By that do they mean in first you'll redline TOO quickly so there's not enough time to shift?
And what's wrong with spraying in 5th gear? you've got plenty of time to let go of the WOT before you redline...::::scratches head::::
(i also wanna quickly share how my cousin blew up his IS300 kuz its pretty crazy lol. Don't know all the specs but hes boosting with a 150 shot in a lexus IS300. correction WAS! He's hard headed so he decided to skip the safety features and put the N20 push button on his steering wheel. When shifting he did NOT let go his button SO when in gear his throttle body opened up and it was pretty much like a 400 shot awaiting arrival into the block. OOHHHH BOOOOIIII lmao. he still had as piece of the piston left he showed me.)
__________________
Diy:Fuel Door Fix Coupe
2005 civic coupe EX SE 5 Speed
AEM V2 Intake|_|A'PEXi GT Spec Cat-Back Exhaust|_|A'PEXi Super Grounding kit|_|AXIS Reverb 18"x7.5" rims|_|DC Carbon Steel Front Strut Bar|_|Fiber glass body kit|_|H&R Front & Rear Sway Bar|_|Skunk2 Rear Lower Tie Bar
STREET DREAMIN C.C.
dryft is offline   Reply With Quote
Old 05-12-2008   #183 (permalink)
angel alberto
New Member
some body tell me something about this kit , I want to buy this
http://www.dynotunenitrous.com/store...?idproduct=227
Old 05-12-2008   #184 (permalink)
dryft
Senior Member
dryft's Avatar
Question BUMP.
is it that dumb of a question or does nobody know the answer
__________________
STREET DREAMIN C.C.
Old 05-12-2008   #185 (permalink)
angel alberto
New Member
Quote:
Originally Posted by dryft View Post
Question BUMP.
thanks!!!
Old 05-12-2008   #186 (permalink)
civicsrcool
Super Member
civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned civicsrcool should not be questioned
dryft: well for one, i dont think you will get into 5th unless your running a crazy amount of nitrous. im boosted and i rarely get into situations where i will have to 5th gear boost, if anything i will be in 5th gear boost for 5 seconds tops (around 125ish MPH) which is as fast as you will ever have to go.
and for not spraying in 5th, 5th is not a "strong gear". your 5th gear is meant for cruising and not WOT lead foot drivers. its just the simple fact that honda didnt design the 5th gear to take up much abuse, for the simple fact is that 1) its a econo box w/ 100whp why would i make 5th gear stronger than it has to be and 2) normally the last gear in all transmissions are only meant to cruise and not race etc.
for example the rsx type s tranny is 6 gears.... 1/2 the reason why k20 rape so much is because of its short gearing. if the k20a2 had a 5 speed tranny and still had short gears you would end up being at 5k rpm at 70 mph (i dont really know but just an example). hence they added the 6th gear to 'cruise' comfortable which is not meant to be pushed on.
civicsrcool is offline   Reply With Quote
Old 05-13-2008   #187 (permalink)
dryft
Senior Member
dryft's Avatar
ahh i see i see. Now does that strong gear theory apply to 1st gear as well?
__________________
STREET DREAMIN C.C.
Old 05-13-2008   #188 (permalink)
civicsrcool
Super Member
1st gear can hold up. its just the fact that the sudden increase in power will most likely break your tires free which obviously gets you nowhere. if you are skilled enough to spray 1st gear and not get the wheels to spin then sure you can do it. with a combination of "light" throttle control of the pedal and feathering of the clutch pedal you can slip the clutch effectively so your tires dont spin but you make your clutch spin instead. practice makes perfect. this means slipping your clutch enough but not too much in order to still achieve a good 60' time. this is the same reason why good engine management systems have boost cut off via certain gears/lbs of boost. ex if you had a quick spooling turbo and tried to get off the line when you already hit 12lbs of boost at 3k rpm, the only thing you would do is spin tires, unless your running slicks of course. if you get my dryft.
Old 02-28-2009   #189 (permalink)
01_CiViC_CoUpE
New Member
01_CiViC_CoUpE is an unknown quantity at this point
I have just hooked up my zex wet kit. when i got my jets i got a 75 shot by mistake i was just going to run a 55 shot but i wanted to see if anyone has been running a 75 shot with any problems. heres my setup
4-1 header
2.25 exhaust with cleaned out cat
aem sri
VAFCII
01_CiViC_CoUpE is offline   Reply With Quote
Old 03-27-2009   #190 (permalink)
westcali_playa
Member
westcali_playa is an unknown quantity at this point
i got a 15 lb nitrous tank.. not for my car tho
westcali_playa is offline   Reply With Quote
Old 03-27-2009   #191 (permalink)
JLcivic01
New Member
JLcivic01 is an unknown quantity at this point
Send a message via MSN to JLcivic01
possible future mod! VERY nice FAQ
JLcivic01 is offline   Reply With Quote
Old 04-06-2009   #192 (permalink)
dryft
Senior Member
dryft's Avatar
Quote:
aaahahahaha, i believe N02 cuts off the oxygen to your brain...not positive
__________________
STREET DREAMIN C.C.
Old 04-07-2009   #193 (permalink)
westcali_playa
Member
shits fun tho haha
Old 4 Weeks Ago   #194 (permalink)
Newjd2
New Member
Newjd2's Avatar
Newjd2 is an unknown quantity at this point
I just wanted to comment on this thread and bring it back from the dead again because I just read all 13 pages...word by word by word...good thing I read this before jumping into buying a zex kit...I still wanna buy it though, but now I am a lot more knowledgeable...
If anyone reads this I still have a couple questions though...So at what pressure should the bottle on a wet kit truly be at?...some have said no higher than 900....another has said between 900-1050...and another i've seen is 1000-1200 and don't touch near 1300...so which is it?
Another thing is when running nitrous and you hit WOT does it automatically kick the n2o into your TB regardless if the switch is off or that switch has to be off with the bottle open and then it will kick...(p.s....i'm getting a window switch...)
Appreciate if anyone reads and answers this...
__________________
..The Kid G.I. #2..
Newjd2 is offline   Reply With Quote
Tags
7th , civic , d17 , dry , engine , gen , install , kit , mess , nitrous , nos , shot , smallest , wet , works
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Dezod Motorsports Turbo Kit! Now Shipping!! VIDS ON 979 & Pics, DYNO on POST 1330
The 7thGen Swap FAQ.
DIY: K20/K24 into 2001+ Civic **Updated 4/20/2008**
DIY -- Installing SF Turbo kit
*Updated SF Turbo Kits Page (aka. kits ready to ship)
Project "Super 7" *Supercharging K20* Update pg 20! Update.
Poll: D17 Stuff **future boosters, please enter**
K20z1 Swap/Turbo in process.
It has arrived !!!
Site Supporters
aluminum radiator
Honda car spoilers
