D17a2 stage 2 crowder camshaft
Rep Power: 0 D17a2 stage 2 crowder camshaft
I bought a crower stage 2 camshaft about a month ago. I was wanting to get some tips on getting the most performance outta it. Like what all do I need? Just the springs and retainers? If I get a k-pro engine management system would I still need a ecu? If someone who knows more about this could help me out that would be sweet. Car is been in the driveway for a couple months now and just wanna get it done the right way.
Received 1,144 Likes
Rep Power: 485 Re: D17a2 stage 2 crowder camshaft
Just to make sure.. I'm assuming your engine is not turbocharged, so did you make sure you got the N/A version of the cam?
And to piggyback on GolNat, titanium springs/retainers ($300), fuel/engine management, and a GOOD tune. I vaguely recall reading somewhere that you may have to notch the block, but I have no source to back that up on.
Rep Power: 0 Re: D17a2 stage 2 crowder camshaft
Good lord, no. Stock can handle maybe 8psi max.
You're gonna need a custom intake manifold that can take that kind of pressure. I couldn't tell you off the top of my head what kind of internals you'd need to handle the boost. You're also gonna need fuel injectors, aftermarket fuel pump, likely a return-style fuel system conversion.
09-27-2015 11:33 AM
beanhead
09-24-2015 12:04 PM
WaryDriver
08-16-2015 11:22 AM
