Couple Questions About D17A1 to D17A2
Rep Power: 0 Couple Questions About D17A1 to D17A2
Hey guys, ok so just to let you all know, I have been searching for a while now and I haven't been able to come across much that pertains to these questions...
First off, I'm swapping my D17A1 to a D17A2 - Not for performance gains, just for high kms and a cheap D17A2 that I was able to come across.
I have an 05 Civic Dx
So far, I have a new ECU - that will match the engine (04-05 EX MT ECU)
And the engine (plus the different headers/exhaust)
What I'm wondering is this: Will I need a new engine harness?
I haven't found a solid answer for this as some people have said that you can just run the VTEC wires to the ECU.
If it is as simple as running wires - Will I have to run anything else aside from VTEC? (and how many wires are there to run? I've heard only 2 but there seems to be 3 pins on the ECU (01-03) that include VTEC)
If I can simply run the wires to the ECU - can anyone provide me with a diagram/pinout for the 04-05 EX ECU?
I've found several for the 01-03's but nothing for 04-05.
Any help will be greatly appreciated!
Thanks in advance
Josh
Thanks in advance
Josh
Rep Power: 188 Re: Couple Questions About D17A1 to D17A2
Are you planning on swapping your exhaust too? If you are then you will need a new harness for the o2 sensor down from the cat. If not then you can run a wire from the ecu to the stock dx o2 sensor. Search some more for the pin out. I can't remember it off the top of my head
Rep Power: 0 Re: Couple Questions About D17A1 to D17A2
Yea you have to swap the exhaust with the A2 because the A1 headers are built into the cat - I have the different downpipe.
I've heard that I can just extend the secondary o2 sensor as the two primary o2 sensors for 04-05 models were both wideband. So I'll just extend the secondary o2 sensor.
And in regards to the ECU - I found the pinout locations via a different site. All I was able to dig up here was the 01-03 pinout, not the 04-05 and the ECU's changed a bit in 04.
Thanks for the reply though!
when i installed my 'a2 i used the 'a1 harness and ecu and exhaust so i didn't have to change the o2 wires. the ecu that i had recieved with my motor was for a '05, which would've meant more money and work converting for the wideband o2 sensors
the way i have it now along with apexi vafc2, its been just over a year and 25k kms and absolutly no issues.
and this way i did not have to get my keys flashed at the stealership- saving money
Thanks in advance
Josh
Thanks in advance
Josh
I removed my egr. When using the dx ecu you won't have any codes because its not programmed in the dx ecu. Remove it and put a block off plate on and problem solved
I know it's a late response but if you read my posts you would know I'm driving a '02 dx sedan. I swapped in a '05 d17a2 and using the stock exhaust with the original d17a1 harness and ecu. I've got a vafc2 wired in for vtec and now have a crower stage 1 cam and still running strong
Received 1,146 Likes
Rep Power: 485 Re: Couple Questions About D17A1 to D17A2
You (or a tuner) has to set the VTEC to engage at whatever RPM you desire. When I had a VAFC-II (in my 02 ex, granted it was for tuning AFR for a boost build), the tuner hooked up the VTEC wire (which I later disconnected because it was redundant for my setup) and set it to engage at 3500 RPM.
https://www.civicforums.com/forums/1...p-ex-vtec.html
there's the DIY guide for installing an -a2 head on an -a1. hopefully this helps.
BootyDo
06-21-2016 03:45 PM
fvckbg
07-07-2015 07:08 PM
BootyDo
07-07-2015 06:06 AM
