Help from k20 guru's and boosted civic's
Rep Power: 0 Help from k20 guru's and boosted civic's
hey guys I'm new here and i figured it would be the best place to inquire.
here's my setup right now
i have a 2004 vp civic, d17a1 that i boosted a few years ago. I'm running about 14.8 psi on a gt25, EMS standalone connected to my truboost, oil, and wideband. it's been great and so far so good and i personally will never go back to an N/A ever again! Now my question is the following, i've been considering upgrading to a k20 and turbo it.
The reason is because i want to upgrade my pipping to stainless steel (currently have aluminium) and i have to build a custom intake manifold since the d17 is in plastic. I also have to do my down pipe in the near future since it came with my kit and i want it to match my custom exhaust from the cat back.
I was wondering if there was a way i can upgrade to the K20 but keep my EMS and if i would be requiring all the parts that i've found on the forums. I'm a bit confused with the whole k20 swap and i know i need a bit more research, but if someone could shed the light for me it would help.
Thanks in advance for your help
Live for the Twisties
Rep Power: 260 Re: Help from k20 guru's and boosted civic's
The D17 and K20 use the same AEM EMS unit I believe, call them to confirm.
https://www.civicforums.com/forums/7...0-d17-k20.html
As far as what parts you need, have you read the xproductions DIY, it's the bible of k-series into 7th gens.
Rep Power: 0 Re: Help from k20 guru's and boosted civic's
hey thanks for the response
I'm pretty sure that it would be compatible, and yes i will be calling them to confirm, but my main point that made me unsure is the wiring harness, from what i understand, ill have the rsx harness so it will no longer plug directly into my ems, but i will let you know about it when i speak to AEM
i haven't seen his diy, but i will now!
thanks for your help and guidance
Understandable concern.
For reference, although you probably have already found it, a link to xproductions..
https://www.civicforums.com/forums/7...20-2008-a.html
