Air fuel ratio
Old 09-05-2007
Jza
Jza's Avatar
Jza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the roughJza is a jewel in the rough
Air fuel ratio
What is the ideal air/fuel ratio? I've heard figures like 10 parts air, 1 part gas. Is this correct? What is the air/fuel ratio given off by a completely stock engine?
Old 09-05-2007
Jap-Euro Fusion
Boilermaker1's Avatar
Re: Air fuel ratio
14.7:1 is complete combustion (everything is expended). You dont want to run that high under load, as you want some factor of safety set into the system, NA, I think you could get away with High 12s at WOT, under boost, you want mid 11s
Old 09-08-2007
Jza
Jza's Avatar
Re: Air fuel ratio
So complete combustion is 14.7 parts air and 1 part gas. But idealy, you want 12 parts air and 1 part gas at WOT (wide open throttle)?
Old 09-08-2007
speedfoos's Avatar
Re: Air fuel ratio
For boost or NA?
Old 09-08-2007
Jza
Jza's Avatar
Re: Air fuel ratio
Both
Old 09-28-2007
Turbo Guru
andyman97's Avatar
Re: Air fuel ratio
12 anything :1 is uber rich. You won't make power that rich. I'd say mid-high 13's would be good under n/a apps. Mid-low 11's is ideal for boost, gives a good cushion of safety.
Old 09-28-2007
7thgen Power Maker
dezod's Avatar
Re: Air fuel ratio
12's:1 on an N/A all motor app should be fine. That will allow for some buffer of bad gas and top end runs.
juror
05-26-2015 06:35 PM
cruisers10
05-12-2015 10:46 PM
AFlyer
03-04-2002 05:09 PM
Booohahaha
01-20-2002 12:03 PM
02Si
01-01-2002 11:30 AM
Quick Reply: Air fuel ratio
