DIY: D16Y8 Manifold on D17 + fuel pump upgrade and return fuel line
Pwning Noobs 24/7
Rep Power: 241 DIY: D16Y8 Manifold on D17 + fuel pump upgrade and return fuel line
This was taken from hondacivicforum.com, was created by Chimera
7th Generation Civic Intake Manifold Swap
Including fuel pump upgrade & return fuel line
Required Parts:
D16Y8 intake manifold (OEM or aftermarket strongly discourage Skunk2)
Intake manifold gasket 6th gen
Aftermarket intake I used 99-00 Si Weapon R Secret Weapon
Adjustable Fuel Pressure Regulator If using 7th gen rail need universal
Fuel Rail You can use 7th gen rail and modify it strongly suggest replacing, makes swap much easier
Fuel Rail bolts from 96-00 Civic (4-6) Trust me.
240cc saturated fuel injectors Only if replacing fuel rail
Injector gaskets from earlier gen. Civic
SSB fuel lines Get about 23 feet, one 10ft (this will be for return) and one 13ft no larger than -6AN. Get all required hose ends and fittings. (more on this later)
Fuel Pump Make sure it is a High Pressure pump; recommend Walbro or Holley.
3 5/16th fuel line (rubber)
2 3/8th fuel line (rubber)
~ 16AWG wire in 3 different colors (red, black, and another)
3 8mm nuts
2 ½ length steel spacers
Additional Parts:
Fuel filter made it easier to install fuel pump
Throttle body I believe you can use your OEM TB.
WARNING!!!!!!
If you decide to use a Skunk2 intake manifold you will NOT, I repeat NOT be able to go back to stock without replacing the bolts screwed into the engine which the manifold sits on, also removal of a portion of firewall is necessary.
Preparation
If you do not already own one a Haynes or Chilton manual, buy one.
To bleed the fuel pressure remove the glove box and refer to the manual to see which relay to pull; on mine I only had two 1 blue, 1 brown; remove the relay(for me it was blue).
Start the engine and allow it to run till it dies. Shut engine off. Disconnect negative battery terminal.
Tools:
Air compressor capable of operating a die-grinder
Die-grinder ($30 Husky from Walmart worked great)
Ratchet set (required metric sockets 8mm-14mm most commonly used)
Metric wrenches 10-14mm
Tap and Die set (metric)
Step 1. Removal of OEM parts
I am not going to go into much detail, what I will say is that a Haynes or Chilton manual is a great tool.
Remove air box or intake if you have an aftermarket one installed
Remove accelerator cable from throttle body (also remove cruise cable if equipped)
Unplug MAP sensor and mark sensor clip for identification later; pull sensor, set sensor aside
Unplug TPS sensor and mark sensor clip for ident.
Unplug EVAP sensor and mark clip for ident. Remove from TB and manifold.
Remove coolant bypass hoses from IACV on TB. (Shop towels or a rag underneath will help reduce coolant spill)
Remove throttle body
Remove PCV fresh air connector.
Remove valve cover and remove nut on back of wiring cover connected to manifold.
Remove throttle and cruise cable and cable holders.
Remove Fuel line from fuel rail, simple squeeze and pull. (Check Haynes or Chilton for verification)
Remove EVAP line from pipe on fuel rail. (arrow in picture above shows EVAP line)
Remove fuel rail bolts and fuel rail.
o Set fuel rail and injectors aside in a plastic bag.
Remove all other hoses/sensors/etc (if any) from manifold.
Jack car up for access to underneath bolts/nuts connecting manifold to head.
Remove all bolts and nuts connecting manifold. (3 nuts, 2 bolts; bolts are at each end of manifold, nuts are 2 on top, 1 on bottom)
Remove manifold.
At this point I strongly urge those considering using Skunk2 manifold to think about how long they plan on keeping the vehicle and if you have a friendly mechanic and a welder. The next step will require you to trim your firewall and cut and re-thread the bolts from the engine head which the manifold sits on. If you are replacing the stock TB w/ the Skunk2 you will also need to make an extender in order for the TPS to fit. More about this later.
Step 2. Preparing Vehicle for Manifold
Ok I will do my best to recall and point out any and all issues I ran into later in the swap so you can be prepared and do them in this step.
Lets get into the cutting first, here is where your die-grinder and air compressor come in handy. I dont have a picture but I will describe it in detail.
o Youll need a cutting disc for your die-grinder and youll need to plug up the runners of the cylinder head w/ shop towel; I suggest not using thin paper towel as the die-grinder cutting produces heat.
o From the end of the threads closest to the engine, measure 1/8 inch and mark with a sharpie on all 3 bolts, cut at these lines.
o Once finished cutting all three bolts start with your 10mm die and begin to re-thread the bolt, the 10mm wont do much but it will give you a guide to use on smaller dies. You should be able to turn the 10mm by hand. Start all three bolts or do one at a time which ever you are comfortable with. Next you will need a 1 inch socket and a ½ inch ratchet, I found it convenient to use a smaller socket to put inside the 1 inch to aid in keeping the threads straight, now place your 9mm die into the socket and begin to tighten and thread the bolts. Once you are done with the 9mm do the same with the 8mm die. You only need to thread a little more than half-way down the bolt. After all bolts are done replace the cutting disc on the die-grinder.
Now we will trim the firewall. **NOTE: This is only necessary if using the Skunk2 manifold. If using OEM or short runner manifold skip this step and move on.
o Remove the bolts and wire clips circled in yellow, cut along black line and underneath as far back as possible. The A/C line (thick alum. Pipe) may need to be moved out of the way, remove bolt and carefully bend alum. Piping as needed.
o Once finished trimming the firewall take a grinding stone and your die-grinder and smooth out the edges.
NOTE**** This part of the firewall will be patched later.
Now that all that is done we will move on to trimming the manifold itself so the bolts will line up properly.
o I used a metal cutting rod that came with my die-grinder to widen the top bolt holes. I did nothing about the intake runners, Im going to leave that for a port-match when I get a P&P done.
That is the power steering fluid line, it needs to be moved a bit, the easiest way I found was to take circle 1 and bend it straight down then take the plastic to metal converter and bend it in the direction of the arrow. If you are a little sketchy about bending it DONT, if you break it, it costs $120 from the dealership to replace. Circle 2 is the nut that keeps it connected, remove, allow to drain and then remove it from the power steering pump via two bolts (second image)
o After getting the manifold in replace the line, this will make it much easier to bend into necessary shape, but takes some time since you will not have much room to work.
Now the larger A/C line will also need to be moved, I found it easiest to just bend it upward, and let it sit just above the manifold(once the manifold is installed).
o Before:
The circled bolts and hoses will need to be removed before bending the A/C pipe. NOTE*** If you are not replacing the fuel rail and using the stock fuel lines, you are on your own here; I suggest you use an OEM manifold.
o After:
Next remove your batter from your car, also remove the battery stand. Set the battery aside; I relocated my batter to inside the car and ran wires. If doing so follow the next step, if not skip.
o Ok running the wires is very simple, what you will need is battery wire from PepBoys or any other auto shop, get 2 cables at the longest length; you will also need 8 gauge wire( I used wire from Lowes get about 6-8 ft. possibly more if running from trunk) You will also need electrical connectors, I found a nice one at Lowes, it was metal with screws and it came with shrink wrap(Need at least 4). You will also need to drill through the floor of your car/trunk where ever you decide to place it. Pick up some rubber grommets (3/8ths I think, about the size of your pinky). What I did to connect the wires to the OEM ones was I cut off the battery connector from the stock cable and shave the plastic back a little, connect your stock w/ your new wires w/ the connector and shrink wrap. Viola!
If you are replacing your stock fuel line continue reading; if not skip and move on.
o Ok get out your die-grinder and cutting disc again, verify that the line is the fuel line and start chopping it up, where the line travels down the firewall I wasnt able to do anything about, too much in the way, so I cut as far down from the top and as far up from the bottom that I could. Also the EVAP line, its easier if you cut and replace that line; I chose to cut mine at the bottom of the firewall. Remove all cut line from vehicle. Leave cut until manifold is installed. We will add the fuel line when I cover replacing the fuel pump.
Step 3. Upgrading Fuel System (Includes pump, lines)
We will start with the pump and then add the lines; the lines are fairly simple so I wont be talking much about them, Ill say what you will need you can choose the size of your line and all else. You will need plenty of towels incase things get messy and make sure you have the windows down or the doors open, breathing in gas fumes can make you sick.
The pump is a bit difficult removing so be gentle and take care. The lid for the fuel tank is under your rear seat. Unscrew the 4 bolts holding the cover on and then unplug the wires going to the pump, move the cover to the side where it wont get damaged.
Remove the stock fuel line (same as removing from fuel rail) and push out of the way.
Get a hammer and a flat-head screwdriver and start tapping the ridges of the screw on cover lid to the fuel tank in a counter-clockwise direction; once loosened try unscrewing the rest by hand. Pull that off and set aside.
[IMG] Carefully remove pump housing from tank, I cant give specific directions for removing it; youre going to have to tilt it at some point to get it out; BE VERY CAREFUL not to damage the fill gauge or you will never know how much gas you have till you replace it.[/IMG]
o Drill a hole anywhere in the top of the housing and place a NPT-AN adapter, I used a 3/8NPT to -6AN. Screw in tight, use a Teflon paste to help seal the hole.
o Plug in any and all electrical connections that were unplugged.
o Once everything is plugged in gently set the housing back in the tank and put the cap back on nice and tight, might be a little difficult.
o Plug electrical connection back in. Leave cover off until assured pump works properly.
Stainless Steel Fuel Lines
o You will need plenty of zip ties and a pair of scissors for this.
o First get your length of 3/8ths rubber hose place a -6 AN hose end on one end(90* or straight will work great) and then connect the other end to the fuel pump.
o Next take your 13 piece of hose and measure the length you will need to connect it to the fuel rail, use the zip ties to secure the hose to get a more accurate measure. Cut as needed Prep the line by wrapping electrical tape around the area where you will be cutting; cut closer to one end of the tape; dont remove tape, to cut use the cutting disc and your die-grinder.
o Dependent on what size hose you bought and if you are using an aftermarket fuel filter you will need from 2-4 hose ends; 1 90* and 1-3 straight.
o To put the hose ends on the hose you will need a pair of gloves, a vice (wall mounted or the likes), an adjustable wrench and various metric wrenches; take the cap and twist it over the hose(leave the tape on from where you cut previously), once it is fully on start the connector end into the cap, then use the vise and wrenches to finish, be careful not to tighten too much as you can easily damage the connector end. This can be difficult and may take some time to accomplish.
o Use the 90* to fit on the fuel rail.
o If you are using a fuel filter, get the measurements for the openings and search Jegs or SummitRacing for AN adapters that will work, crush washer are also a must (or you will be cleaning up a lot of fuel later).
o You will need a -xAN to -yAN adapter to fit on the fuel rail.(where x = size of hose & y = opening of fuel rail)
o Secure your hoses underneath with zip ties.
Step 4. Installing Manifold/TB/FR/FPR/Injectors
Ok at this step you are nearly finished, the journey is coming to an end and you should see a small tiny light at the end of the tunnel. A lot of this part of the project takes finesse so dont get frustrated, take a break, drink a beer and come back later.
Manifold installation First put the gasket on the bolts coming out of the cylinder head. I found the easiest way to get the manifold on was to insert the back of the manifold under the AC hose and ease the front end down as you lift the back end up, this may take some finesse and some force at times, possibly insert the left end of the manifold first and work the right end into position, once the bolts are lined up in the holes place the manifold flush again the head and start the top two nuts on the bolts; DO NOT tighten all the way yet. Make sure all hoses behind the manifold are not in the way as it will move slightly when the engine jerks or under WOT the engine does move a little, make sure there is an inch between the manifold and anything it can hit. As long as the manifold is far enough away not to hit anything , tighten the nuts and install the bolts with the steel spacers and tighten about 1/3 turn past hand tight. Once this is set and everything looks good we can move on to installation of the fuel rail, fuel pressure regulator, injectors and then on to the throttle body.
Place your plug at one end of the fuel rail(I chose to plug the side opposite the intake fuel line) make sure you use a crush washer to ensure a proper seal. Now take youre AN union adapter with crush washer and fasten to the other opening. Plug the opening in the top of the fuel rail unless you are using it for a FP gauge. If you are using a fuel pressure regulator that mounts right to the fuel rail, follow the instructions that came with the FPR. If using a universal FPR find a suitable place to mount it and follow the instructions provided. Fuel rail, I suggest that you buy extra bolts earlier I suggest 4-6, you may be good with 4 but expect to buy up to 6 they are very easy to strip the threads on the top of the bolt. Use a bit of anti-seize on the end of the bolts going into the intake manifold, hand tighten. Place your injector gaskets in the 4 injector openings; coat the gaskets with a thin coat of oil, coat the injector ends with oil and insert in the injector gaskets. Place the fuel rail on top of the bolts.
Line up the injectors with the holes in the fuel rail, you may need to tap the fuel rail onto the injectors to ensure a sealed fit. Gently put on the stock nuts from the 7th gen. fuel rail (they will fit) and tighten hand tight. Dont over-tighten because the threads strip very easy.
Put your throttle body together, if you have aftermarket TB youll need a TPS from a 5th or 6th gen, the TB comes with screws for it. To get the TPS off youll need to cut a flat head groove in the screw with your die-grinder and cutting disc and unscrew it. Screw on the TPS and position it with the top lobe farthest to the left. Youll need to drill out the hole for the MAP sensor and use 2 o-rings and a couple washers to make sure it seals. Put the rubber connector on the TB and tighten the clamp.
You will need to have an extender made for the throttle body to fit if you are using an aftermarket one, Im not sure about the OEM, it may fit without the extender. Here is a picture of the extender.
To make this I took my gasket that came with the Skunk2 manifold to a machinist and told him that I needed two plates with that exact design layout of the gasket and the material had to be weldable. Then I bought a mandrel bent 45* 2.5 exhaust pipe and cut it at the beginning of the bend and 25 degrees from the first cut. Took them to a mechanic that did welding and had him weld it up, make sure you leave enough room to get the bolts in. I had to use 2 gaskets on each side when I put this together to get a good seal.
o Put the extender on the manifold first and then put the throttle body on the extender. Tighten bolts as much as you can. Connect your accelerator cable to the TB.
Make it look like this.
Install your intake onto the throttle body, check for fitment and tighten clamp on intake. Now onto the electrical
Step 5. Electrical Work
Ok most of this is VERY simple, all you are doing is extending the wires so they will reach the sensors in their new positions. For the TPS you will need to use the connector from the 5th or 6th generation civic and connect the power wire to the green/yellow wire, black to black and the other wires together. For the IACV from a 5th or 6th again, it is only a 2 wire connector, again power wire to green/yellow, red to black/red and ground to the TPS ground. I have only hooked up the electrical connector and the coolant hoses, I did not connect it to the manifold so you will need to close the holes in the back of the manifold and the screw hole.
At this point connect your fuel lines and turn your car to the on position, DO NOT START YET, check the fuel lines for leaks and check the rail/injectors for leaks, if none exist start the engine and let it idle for 15-20 minutes to allow the ECU to go into closed loop mode. While the engine is idling check for any vacuum leaks, fix where applicable. At this point in time you may throw engine codes, the two most common I got were P1106 Barometric Pressure (BARO) Sensor Circuit Range/Performance Problem and P1129 Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than Expected and P1509 PCV Leak. The first two were caused by a vacuum leak in the extender, the last one was from the fresh air collector; the hose from the top of the cylinder head to the intake. If you got the same size injectors your ECU should have no problem with A/F ratios, I put slightly larger injectors to compensate for the dry kit I have on as well so Im also running a SAFC2, if you have the money picking up one wouldnt be a bad idea. Now take it for a test drive and have fun!!!!
As soon as you get a chance get a piece of sheet metal and pound it into the shape you need to fill the part of the firewall you cut make sure you design it so that you can pull the manifold off if needed, take it to a welder and have them weld it in.
Required Parts:
3 8mm nuts
Additional Parts:
WARNING!!!!!!
Preparation
Tools:
Remove manifold.
o Before:
o After:
Rep Power: 275 Re: DIY: D16Y8 Manifold on D17 + fuel pump upgrade and return fuel line
"must spread rep before giving it to damadscientist again"
ohh well
ohh well
1 Post
Rep Power: 364 Re: DIY: D16Y8 Manifold on D17 + fuel pump upgrade and return fuel line
Any point it putting this manifold on a NA setup?
Rep Power: 216 Re: DIY: D16Y8 Manifold on D17 + fuel pump upgrade and return fuel line
heres a question. i already have the fuel pump installed but im still running a stock FPR in the tank. what do i do about it in order to run a aftermarket? it says nowhere up there about it. it just says that this hose connects to where stock FPR was. doesnt say what to do with it. do i just run a hose to where it used to be and remove the FPR? or what? also. can i use my stock fuel line to use as my feed line and just put a return line in? i plan on doing it that way and adding an aftermarket FPR in the return line if i can...any help would be nice
Rep Power: 0 Re: DIY: D16Y8 Manifold on D17 + fuel pump upgrade and return fuel line
You can use the stock feed line and just run a return line. If you're using an aftermarket FPR, then just bypass the stocker as it says in the DIY, and install your new one per its instructions.
but i mean what do i do with the open port in the tank? if i take the stocker out do i run a new hose to the bottom ofthe tank?
Rep Power: 213 Re: DIY: D16Y8 Manifold on D17 + fuel pump upgrade and return fuel line
If you are seriously going to do this swap, pm me, I've done it. But if you are just toying with the idea please don't waste my time.
Is this worth it?
I wanna do the swap as i hate the D17 intake plus using the y8 would make my future boost project easier.
Anyway as it stands n/a will it do much and even it if does nothing is it a better idea?
N/A I wouldn't bother. If you are going boost, yes it's a rather inexpensive alternative to a custom manifold. You do have to use the stock throttle body though, at least in my experience. I've tried both y8 throttle bodies, neither work. I also used the stock fuel rail with srt-4 injectors, so you need some sort of engine management. If you have EGR you must eliminate it as well, or not have it in the first place.
im doing this d16y8 swap on a d17a2 turbo right now so can we get the pictures back up ? also i'm not converting to the return fuel system yet just swapping the manifold first so can i still use the d16 fuel rail and block off return ? will i get a gain from swapping fuel rail ?
Received 1,146 Likes
Rep Power: 485 Re: DIY: D16Y8 Manifold on D17 + fuel pump upgrade and return fuel line
unfortunately, the photos are not hosted by civicforums.com, so we have no way to get the pictures back up. You'd have to contact the OP to see if those photos still exist in his (or her) personal files. Or, contact hondacivicforum.com admins to see if they have archives of the photos OP hosted on their forum.
As for the fuel rail, (and I'm too lazy ATM to read the whole first post. lol) I'm willing to assume the D16 rail was used because it's utilizing the D16 injector block. I guess you can see if the D17 fuel rail aligns the injectors up properly, but I couldn't tell you for sure. The conversion to a return style fuel system is so you can utilize a downstream FPR and supply enough fuel for as much boost as you can throw at it. The D17 utilizes a returnless fuel system, and fuel capacity can't be regulated as efficiently for varying fuel demands.
thanks for the reply im currently using the stock d17a2 fuel rail with stock returnless fuel system. i have 750cc injectors and walbro fuel pump and turbo with d16y8 intake manifold and Kpro but i was wondering can i install and use my d16y8 aem fuel rail without converting to return and just block off the return port ? my thinking is anything is better than the stock d17a2 fuel rail, i also have a stock oem d16y8 fuel rail i can use
Thanks
Thanks
CarStuff
12-06-2020 12:52 PM
Jonnie.
01-13-2019 11:21 AM
