Girl knows nothing about cars, needs advice
Old 08-24-2011
CindyL's Avatar
CindyL is an unknown quantity at this point
I have a 2003 Honda Civic almost at the 100,000 mile mark. What should I be having maintenanced on it? I'm getting the timing belt replaced as well as the water pump...the Honda dealer package quoted at around $539. An alignment is needed. How much does that run? Should I have the shocks and wheel bearings checked? I haven't had to buy a new battery since I got it. Sears tested it a few months ago and said it was fine for now. I plan to keep it for another 100,000 miles and do not want any problems unexpectedly. Knowing absolutely NOTHING about cars, I cannot afford to put $1,000's into it if i don't need it.
Old 08-24-2011
Received 1,440 Likes on 1,196 Posts
Re: Girl knows nothing about cars, needs advice
see gases test in here. Better do it at once if gas test comes positive.
https://www.civicforums.com/forums/3...reference.html
shocks are easy later on, but if need do bearings better do at once too.
Old 08-24-2011
around $500 is fair for the service. alignment add an extra $90 maybe.
Old 08-26-2011
jackwagon's Avatar
jackwagon should not be trusted
Bring it to me... I only charge $50 per hour, not $100. That's why they call it the Stealership...
Old 08-28-2011
glenniz's Avatar
glenniz is an unknown quantity at this point
Download the Service Manual for your vehicle from:
http://hondatech.info/search/civic/
There will be a section that will tell you what needs to be serviced at different mileage intervals. Look for the service recommendations at 100K and have your mechanic take care of them for you.
Also, the dealership is about 40% more expensive that most private automotive repair business'. You may wish to look around for a reputable mechanic and have him give you a quote.
Best of luck and if you have any questions just hit us up. Most of the guys around here will be more than happy to help out!
Old 09-01-2011
kbook's Avatar
kbook has a spectacular aura aboutkbook has a spectacular aura aboutkbook has a spectacular aura about
Look at the dealer website like Bloomfield Honda if this dealer is closer to you. They do have coupon $100 off for timing belt job too. I got it done at Bloomfield since it's the cheapest at that time.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
ChristinaVHH
05-10-2015 03:51 PM
superstanko
04-28-2015 04:38 AM
F1wanabe
04-27-2015 11:06 PM
daynoesaur
11-08-2001 11:01 PM
Quick Reply: Girl knows nothing about cars, needs advice
