LinkBack Thread Tools
Old 05-24-2008   #1 (permalink)
AmbulanceMonkee
AmbulanceMonkee's Avatar
AmbulanceMonkee should not be questionedAmbulanceMonkee should not be questionedAmbulanceMonkee should not be questionedAmbulanceMonkee should not be questionedAmbulanceMonkee should not be questionedAmbulanceMonkee should not be questionedAmbulanceMonkee should not be questionedAmbulanceMonkee should not be questionedAmbulanceMonkee should not be questionedAmbulanceMonkee should not be questionedAmbulanceMonkee should not be questioned
Almost a turbo.
For what I spent on this, I could have almost turbo'd my car. This is more fun for me, though.
HP 22" widescreen
Ultra X Blaster Case
PC P and C 725w PS
Plextor DVD Burner
36GB 10k rpm Raptor, in Thermaltake cooler
Ultra fan controller
2 x 2GB Mushkin 1066 DDR2 (can't get it to work with all 8GB I bought)
2 x 500GB WD SATA 3.0g/s (may get RAIDed)
Asus Maximus Formula board
Intel Q6600 Core 2 Quad
Zalman CPU cooler
2 x Diamond Radeon HD3870s, Crossfired, and OC'd with Catalyst for now
Runs Photoshop and UT3 pretty well.
AmbulanceMonkee is offline   Reply With Quote
Sponsored Links
Old 05-24-2008   #2 (permalink)
Eyger
A long winded 7th genr
Eyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questionedEyger should not be questioned
Re: Almost a turbo.
....What does it do?
Ha ha, Im just kidding. Well, with all that processing power, you're computer could calculate the G forces you would have felt if you got a turbo for your car. I need a new compy bad.... Nice case on yours though. I think it looks clean.
Eyger is offline   Reply With Quote
Old 05-24-2008   #3 (permalink)
Rufus
I drink Windex...it keeps me from streaking...
Rufus's Avatar
Re: Almost a turbo.
Quote:
You need to ride in a 15+ PSI car my friend.
Rufus is offline   Reply With Quote
Old 05-24-2008   #4 (permalink)
AmbulanceMonkee
Re: Almost a turbo.
yeah, i'm sure it's a good time. but i live in NY, and i can use this all winter and not have to worry about destroying it.
Old 05-24-2008   #5 (permalink)
Rufus
Rufus's Avatar
Re: Almost a turbo.
lol amen to that brother. lol
Old 05-25-2008   #6 (permalink)
gearbox
Super Moderator
gearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant futuregearbox has a brilliant future
Re: Almost a turbo.
i used to be into computers like that when i first got mine.
gearbox is offline   Reply With Quote
Old 05-26-2008   #7 (permalink)
white2K2EX
I sure wish my car was newer
Re: Almost a turbo.
So, basically, you have an uber-porn machine.
white2K2EX is offline   Reply With Quote
Old 05-26-2008   #8 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to beholdTRIZ is a splendid one to behold
Re: Almost a turbo.
^ Dont we all? ha.
Looks good man
TRIZ is offline   Reply With Quote
Old 05-26-2008   #9 (permalink)
briand17a2
Member
briand17a2's Avatar
briand17a2 has a spectacular aura aboutbriand17a2 has a spectacular aura about
Re: Almost a turbo.
if you want a quick way to access 4gb+ ram, with a student ID you can get a free copy of Windows Server 2003 R2 through microsofts "dreamspark" program (along with a host of other expensive softwares). Just search for dreamspark for the site. You have to sign up for a MS passport account and jump through some other hoops and whatnot, but its a small bit of time invested for $3000+ worth of free software.
Plus, win2k3 server is nerdvana. If you end up downloading it, let me know. Theres a couple things you have to do to set it up as a workstation, but once its set up, its WAY more stable than XP SP3.
Im running 4gb DDR2 800 and its rediculous. Why close programs when you can just run all of them at the same time? :-)
briand17a2 is offline   Reply With Quote
Old 05-26-2008   #10 (permalink)
modoman
modoman's Avatar
modoman has a brilliant futuremodoman has a brilliant futuremodoman has a brilliant futuremodoman has a brilliant futuremodoman has a brilliant futuremodoman has a brilliant futuremodoman has a brilliant futuremodoman has a brilliant futuremodoman has a brilliant futuremodoman has a brilliant futuremodoman has a brilliant future
Re: Almost a turbo.
36gb raptors? they still sell those? i bought my 2 in like 2003... but they are badass and still running strong. nice machine. which zalman did you get?
modoman is offline   Reply With Quote
Old 05-26-2008   #11 (permalink)
AmbulanceMonkee
Re: Almost a turbo.
i'm running server 2003 on my server. xp x64 on this. it's not a 64 bit os issue, tho. it's a hardware issue, kinda. the thing will run fine, and recognize 4 gigs, where the limit should be 3 to 3.5 with a 32 bit os. however, when i put all 4 2gb sticks in there, everything goes to hell. dram voltage is set to the high end of spec, and timings are manually set to spec. i have to look into turning the timings up a bit, and possibly slightly overvolting the ram, and/or northbridge. for now, i'm happy with 4 gigs. the other two can sit in the box till i feel like messing with this again. as it stands now, ps cs3 loads in under 3 seconds.
Quote:
CPU cooler is a Zalman CNPS 8000. I have some arctic silver on there, but my temps aren't as low as they should be. I'll have to take it off and re-grease the chip eventually. Fortunately, the cooler is pretty easy to put on and take off. As far as the raptop goes, yeah, they still sell 'em. They're $100 a piece. I didn't need anything bigger for a boot drive, and i'm sick of having my boot drive partitioned. If i install anything big, application wise, i just put the files on one of the 500 gbs.
Old 05-27-2008   #12 (permalink)
AmbulanceMonkee
Re: Almost a turbo.
Quote:
i suppose it could be used for that. but it's mostly for ram and cpu intensive stuff. i've been playing with hdr photography lately. did this in about five minutes.
Old 05-27-2008   #13 (permalink)
ryox82
Super Member
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Re: Almost a turbo.
Nice to see another computer guy here. My gaming machine is an xbox360 and a x86 machine running
2.4 ghz Core 2 Duo
2 GB ram
500 Gb HD
Nvidia 7950GT
Still runs newer games rather well but I am waiting for this summers roll out of newer cards. I gave up on ATI because of driver issues or cards prematurely failing. Even the GF had the same issues with ATI. Nice to see someone rocking the crossfire though. I am posting this from a Macbook though, I spread the love!
ryox82 is offline   Reply With Quote
Old 05-31-2008   #14 (permalink)
modoman
modoman's Avatar
Re: Almost a turbo.
ah, the arctic silver requires just a rediculously small amount spread over the chip with a razor. i feel inadequate now because my laptop is sweeter than my desktop and i can't do much modding with a laptop.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
GTA: San Andreas
NEED FOR SPEED UNDERGROUND
***OFFICIAL*** Gran Turismo 4 US Release Date: 22 February, 2005!
Nfs: Underground 2
Official GT4 pics thread
..::~~~Official Wallpaper Thread~~~::..
post pics of ur desktop/laptops
ATTN: Piracy is NOT allowed.
So how far are you in GT4?
OFFICIAL: CivicForums Battlefield 2 Thread
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
