Normally the browser will make one request to a web page at a time. When you enable pipelining it will make several at once, which really speeds up page loading.
2. Alter the entries as follows:
Set "network.http.pipelining" to "true"
Set "network.http.proxy.pipelining" to "true"
Set "network.http.pipelining.maxrequests" to some number like 30. This means it will make 30 requests at once.
3. Lastly right-click anywhere and select New-> Integer. Name it "nglayout.initialpaint.delay" and set its value to "0". This value is the amount of time the browser waits before it acts on information it receives.
If you're using a broadband connection you'll load pages MUCH faster now!
I would like to state that the network.http.pipelining.maxrequests number of 30 is just an example. The number that may help you best attain your sweet spot will vary based on the speed of your connection. To large a number may cause perceived latency. Also there was some concern over this increasing server loads, but this should not be a problem usually (1 page served is still 1 page served). The exception is if people have frequent disconnects from your site, then the process of pipelining everything simultaneously can be a little more costly.
Give it a try-- you'll like it!
Sponsored Links
K&N FIPK II / HP Top Portion Header / Neuspeed Front Upper Strut Bar / RSX 19mm Rear Sway Bar
Generic Rear Upper Strut Bar / 15" Silver Rota Slipstreams (11.8lbs) / 205/60/15 Falken ZE-512's
