| take out the disks, using the tool mentioned above, replace or resurface
before u install the new pads, take the 2 pins out of the pad assembly and lube them up with the lithium grease replace
install the pads, attach to caliper, install the disks, install the caliper and pump the gas until desired resistance
and your done
__________________ 01 ES2, if you dont know what that is.. SEARCH
78 X1/9, if you dont know what that is.. i dont blame you
Honda Trained Technician
Project 5lug: Coming Soon |
