Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-20-2003   #1 (permalink)
sang
Member
sang is an unknown quantity at this point
magna flow muffler rattles..help!
Hi. I have a 2001 coupe xs-2 edition.
it came with the magnaflow muffler.
but the muffler starts to rattle so bad...even over small tinny rocks.
so I went to the dealer and have them fixed..
2days later...starts rattles again..and now a month past
it rattles very bad.
is there anything I can try?
cause I don't trust my dealer no more since their service is really poor quality.
(santa monica honda)
is it the rubber hanger? or is there something else to strongly thighten the muffler?
oh btw, I'm real noob on tech stuff so...
help in detail will help me.
sang is offline   Reply With Quote
Sponsored Links
Old 05-20-2003   #2 (permalink)
4jacks
Diamond Member
4jacks's Avatar
4jacks is a glorious beacon of light 4jacks is a glorious beacon of light 4jacks is a glorious beacon of light 4jacks is a glorious beacon of light 4jacks is a glorious beacon of light 4jacks is a glorious beacon of light 4jacks is a glorious beacon of light
Send a message via ICQ to 4jacks Send a message via AIM to 4jacks
Do you know if it is a Cat back System or Custom Pipe back to a muffler,
Look under the car, if it's all bolted together, it's cat back
If it's welded on , its custom bent
customt bent tends to have less rattles, due to less metal on metal, at joints of cat back systems.
The only hard part is to locate the rattle.
Put your car up on Jack stands
(Back onto ramps would be best. )
Have someone step on the gas to create the rattle
While your underneath trying to find it
Once you find it, it's really not rocket science, just bend, prod, poke until all the metal is secured so not to create a rattle.
And remember Don't use anything on it that will melt !!
no Duct Tape !
4jacks is offline   Reply With Quote
Old 05-21-2003   #3 (permalink)
old beater
Member
old beater is an unknown quantity at this point
yeah, what he said. and look at your rear sway bar, my piping used to rattle against my sway bar when i got my pipes bent.
old beater is offline   Reply With Quote
Old 4 Weeks Ago   #4 (permalink)
jerseymike68
New Member
jerseymike68 is an unknown quantity at this point
Re: magna flow muffler rattles..help!
I have the same magnaflow too and love it, you can usually get a used one on ebay or cragislist. I wanted a valid warranty so I got it here. Magnaflow 93991. Also some of the forum sponsors usually have a sale going on. Either way its a great exhaust system, sounds great, and very easy to install.
jerseymike68 is offline   Reply With Quote
Old 4 Weeks Ago   #5 (permalink)
Staninator
Member
Staninator's Avatar
Staninator is an unknown quantity at this point
Quote:
Uhh thanks guy!
Original Poster: The rattling is probably from metal on metal and you'll need to re-bend the piping or try to find a cushioned wrap that is resistant to heat. Good luck I've been trying to find it and no luck... I have a cat-back exhaust and one of the joints on the exhaust hits the heat shield of the under-body sometimes. It's normal but it's seldom for me. If yours is constant try to re-bend the piping.
Staninator is offline   Reply With Quote
Old 4 Weeks Ago   #6 (permalink)
lowlife9
Super Member
lowlife9's Avatar
lowlife9 will become famous soon enough
you have some opticians first one is it could be hitting the heat shield which is a easy fix just bend or cut the contact point . or if you have wider piping from down pipe its most likely hitting the sub frame were the pipe bends near the front right tire i have seen people take a hammer to this area to stop the rattling but that would be the last resort . another thing to try would be after markit polyurethane hangers that are stiffer then stock so they should stop the rattling . another thing to do if your not lowerd is to have an exhaust shop weld on longer pieces for the hangers that will actually slightly lower the exhaust.
__________________
lowlife9 is offline   Reply With Quote
Old 4 Weeks Ago   #7 (permalink)
jdm,EM2
New Member
jdm,EM2 is an unknown quantity at this point
if you bottom out alot your exaust is probley rattling against your heat sheild.
jdm,EM2 is offline   Reply With Quote
Tags
2001 , 93991 , back , bad , civic , forum , front , honda , jerseymike68 , magnaflow , muffler , piping , rattle , rattling , tires , xs2
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
