Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-30-2003   #1 (permalink)
CarbonFly
CarbonFly's Avatar
CarbonFly is a name known to all CarbonFly is a name known to all CarbonFly is a name known to all CarbonFly is a name known to all CarbonFly is a name known to all CarbonFly is a name known to all CarbonFly is a name known to all
Send a message via ICQ to CarbonFly Send a message via AIM to CarbonFly Send a message via MSN to CarbonFly Send a message via Yahoo to CarbonFly
DIY: Schroth Rallye 4 Harness Install
Product: Schroth Rallye 4 Harness
Description:
The Schrothe Rallye 4 is designed for the enthusiast who is looking for a DOT approved 4 point, 2" wide harness with the simplicity of a traditional push button release. It is equipped with Schroth's unique asmŽ system, which reduces the risk of submarining. A quick-release buckle enables you to disconnect the tail strap, allowing occupants easy access to rear seats when the harnessbelt is not in use.
This harnessbelt is designed to mount to the two stock rear seat lap belt anchor points (the 'D' and 'E' points). It MUST be installed with a SCHROTH tested and approved seat which includes most stock seats having a single or dual post adjustable headrest and nearly all aftermarket 'racing' seats.
Where to get the product:
http://www.soloracer.com/rallye4.html
THIS IS THE ONLY STREET LEGAL, 50 STATE/DOT APPROVED HARNESS
Supplies needed:
- Schroth Rallye 4 Harnesses
- 14 mm socket
- 10 mm socket
Step 1:
Begin by removing the rear bench seat to get to the bolt points for the harnesses. The Schroth harness bolts straight to the stock positions. No modification is needed.
Use you 10mm socket to remove the bolt indicated below. Then just pull out the bench seat.
__________________
7th Gen Ninja Clan #2
CarbonFly is offline   Reply With Quote
Sponsored Links
Old 04-30-2003   #2 (permalink)
CarbonFly
CarbonFly's Avatar
Step 2:
Attach the rear straps to the bolt positions(indicated by the green circles). You can go ahead and attack the driver side rear straps on the other side at this time too.
Use the 14mm socket to undo and redo the bolts for the belts.
Old 04-30-2003   #3 (permalink)
CarbonFly
CarbonFly's Avatar
Step 3:
Using the 14mm socket again, unbolt your seats so that you may gain access to the stock buckle. Unscrew the buckle from the bracket and place the lapbelt onto it. Re-tighten the buckle back on to the bracket. Bolt your seat back down tight.
Old 04-30-2003   #4 (permalink)
CarbonFly
CarbonFly's Avatar
Step 4:
Using the 14mm socket, unbolt the rod that holds the stock shoulder belt. Place the other end of the lapbelt on it and re-tighten the bolt.
Old 04-30-2003   #5 (permalink)
CarbonFly
CarbonFly's Avatar
Step 5:
Attach the rear harness to the front harness by clipping them together.
Old 04-30-2003   #6 (permalink)
CarbonFly
CarbonFly's Avatar
Step 6:
Adjust the straps so that they are comfortable yet tight at the same time.
RINSE AND REPEAT FOR THE OTHER SIDE
__________________
Old 04-30-2003   #7 (permalink)
CarbonFly
CarbonFly's Avatar
__________________
Old 04-30-2003   #8 (permalink)
prototype
x-factor
prototype's Avatar
Send a message via AIM to prototype
daym that looks hot!!!!!!!!! i envy u
prototype is offline   Reply With Quote
Old 04-30-2003   #9 (permalink)
RedDragon333
Stage7 Head
RedDragon333's Avatar
Send a message via AIM to RedDragon333 Send a message via Yahoo to RedDragon333
looking good FLy once again a great DIY. Not too hard for them looks of it
__________________
RedDragon333 is offline   Reply With Quote
Old 04-30-2003   #10 (permalink)
4bangin
Ultimate Member
4bangin's Avatar
Send a message via AIM to 4bangin
looks great. what is submarining? is that if you flip the car or roll it over you still curl forward like with the stock belts, since you dont have a roll bar?
4bangin is offline   Reply With Quote
Old 04-30-2003   #11 (permalink)
CarbonFly
CarbonFly's Avatar
asmŽ is the abbreviation for anti-sub-marining, a mechanism created by Schroth to reduce the risk of submarining or sliding underneath the lap belt. Submarining can cause serious, even life threatening injuries to legs, spine and internal organs. How does asmŽ work? The device is positioned on the in-board strap of Schroth's double-shoulder harness. When the energy converter is deployed (caused by dynamic forces of instant deceleration) it forces the driver's torso and hips to rotate slightly into an asymmetrical posture which tightens the lap belt milliseconds faster.
Old 04-30-2003   #12 (permalink)
4bangin
Ultimate Member
4bangin's Avatar
oh ok. thanks.
Old 04-30-2003   #13 (permalink)
cdmx
Post Master General
cdmx's Avatar
cdmx will become famous soon enough cdmx will become famous soon enough
Send a message via AIM to cdmx
your seats look sooo hot...damn thats nice fly
cdmx is offline   Reply With Quote
Old 04-30-2003   #14 (permalink)
cdmx
Post Master General
cdmx's Avatar
show us a pic from the front outside the car
Old 04-30-2003   #15 (permalink)
AzNmiKex215
2k1civic.com O. G.
AzNmiKex215's Avatar
AzNmiKex215 will become famous soon enough AzNmiKex215 will become famous soon enough
Send a message via AIM to AzNmiKex215
this may sound dumb but what happens wen someone wants to use the rear seats? they just unbuckle the harness? then what? you have to use the stock front and driver seatbelts?
AzNmiKex215 is offline   Reply With Quote
Old 04-30-2003   #16 (permalink)
Renamazazo
Platinum Member
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Send a message via AIM to Renamazazo
How comfertable are those belts, and where does the buckle sit, it looks as if it would be across your legs right now, and do they do a good job of holding you in place, NICE DIY btw, those seats look tizzight (i'm a silly white boy...)
-Mark
Renamazazo is offline   Reply With Quote
Old 05-01-2003   #17 (permalink)
CarbonFly
CarbonFly's Avatar
Quote:
Schroth thought of everything when designing these belts. To carry passengers in the back just unclip the belts. See the pic below....
__________________
Old 05-01-2003   #18 (permalink)
CarbonFly
CarbonFly's Avatar
Quote:
-Mark
They are comfortable and do not cut into my skin. BE WARNED, If you don't like enclosed spaces or have a fear of being held down then these harnesses are NOT for you.
The Harnesses are made to hold you still, upright, and tight into your seat. This harness is not a show piece. It is an actual functioning harness used by many race car teams(usually autocross).
If you do it right then the buckle and lapbelt will be across your legs and hips. When getting in the seat always tighten the lapbelt into place first and then tighten the shoulder straps.
It is NOT safe the have the lapbelt across your stomach or waist. This could allow you the submarine in and accident.
__________________
Old 05-01-2003   #19 (permalink)
AzNmiKex215
2k1civic.com O. G.
yeah i know it disconnects. but wen u disconnect it does it make the harness not functional anymore?
Old 05-01-2003   #20 (permalink)
CarbonFly
CarbonFly's Avatar
When you disconnect you go back to using your stock seat belts.
__________________
Old 05-01-2003   #21 (permalink)
david02civic
I'm The Shit
david02civic's Avatar
david02civic is an unknown quantity at this point david02civic is an unknown quantity at this point david02civic is an unknown quantity at this point david02civic is an unknown quantity at this point david02civic is an unknown quantity at this point david02civic is an unknown quantity at this point
Send a message via AIM to david02civic
lol.so you kept your stock set up as well?
david02civic is offline   Reply With Quote
Old 05-01-2003   #22 (permalink)
CarbonFly
CarbonFly's Avatar
Quote:
Yes, you are supposed to.
__________________
Old 05-06-2003   #23 (permalink)
dragoon
Post Master General
dragoon's Avatar
Send a message via AIM to dragoon
RACECAR!
dragoon is offline   Reply With Quote
Old 05-06-2003   #24 (permalink)
18inchpride
Senior Member
18inchpride's Avatar
18inchpride is an unknown quantity at this point
awww ya i want those!!! how much did you pay for those!!!
And im gettin the same seats tomorrow!!! yehhhh i'll post my pics as soon as possible!!!! im soooooo excited!!!!!
can i have my stock seatbelt or do i need a harness!!!??????
JONNY
__________________
blahhhhh! poop
18inchpride is offline   Reply With Quote
Old 05-06-2003   #25 (permalink)
bickford05
Super Member
bickford05's Avatar
bickford05 is an unknown quantity at this point
Send a message via AIM to bickford05 Send a message via Yahoo to bickford05
nice dyi
bickford05 is offline   Reply With Quote
Old 05-06-2003   #26 (permalink)
RoadRunner
Diamond Member
RoadRunner's Avatar
Send a message via AIM to RoadRunner
nice DIY man, your a lot of help when it comes to doin DIY's
RoadRunner is offline   Reply With Quote
Old 05-06-2003   #27 (permalink)
CarbonFly
CarbonFly's Avatar
JONNY
This is where I got the harnesses........
The total cost including quick grips and shoulder pads came to $388 shipped.
Yes you can still use your stock belts with racing seats.
__________________
Old 05-27-2003   #28 (permalink)
bublik
Truehonda.com
bublik's Avatar
bublik is an unknown quantity at this point
Send a message via AIM to bublik
Does anyone know how to mount them onto the floor, I think I am going to try to do that. The seats in the back seem to be usefull.
bublik is offline   Reply With Quote
Old 05-27-2003   #29 (permalink)
CarbonFly
CarbonFly's Avatar
Quote:
read the DIY. They don't mount to the floor. The mount to the stock positions of the existing belts. The one strap mounts to the buckle bolt on the side of the seat and the other strap mounts to the bar where the strap is.
__________________
Old 05-27-2003   #30 (permalink)
bublik
Truehonda.com
bublik's Avatar
Thank you, I know that. I mean, that it looks ghetto mounted to the back seat saying it is usable and people can sit in it. I was thinking of trying to mount it right behind the seat to the floor. Custom.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
Detailed smoked out taillights DIY w/ pictures
Need help with Radio Code
DIY: Trunk Shocks
Oil Changes
DIY: tricked out trunk
SOHC VTEC Explained
DIY: No More Trunk Rattle!
DIY: Grounding kit Install
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
