Honda Civic DIYs and Civic Tech ChatHonda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
I don't think removing the valve cover requires changing the head gasket since you aren't removing the head from the block. But you should probably replace the gasket under the valve cover just to be on the safe side.
WOW i totally read that wrong, boilers right if your just removing the valve cover you do not need to replace the head gasket, although i highly recomend you replace the valve cover gasket................p.s there is a DIY on how to do this
If you want to save time and spend a little money, just get it powder coated. It should only cost $25 or so. I got mine done on my old car. I got it for free though because I worked there at the time. But when I took my valve cover off, I had to replace it with a new valve cover gasket. It's recommended that you do that anyway, because it was previously copmpressed, you need to create a new seal. (that's how a nissan altima is anyway)
No I think not. The wire cover (which is whats being made by ALLMAN) covers wires.
Not spark plug wires as we all know, but the wire harness that supplies our "direct fire ignition".
When I take off my wire cover I see wires. When I take off my valve cover I see my cam and the tops of my valves.
__________________ 133.48 whp 117.57 tq all motor untuned dynojet
188.87 whp 187.99 tq 75 shot n20 untuned dynojet
147.5 hhp 130.5 htq all mtr tuned church's dynapack
my old d17 set up.
now swapped k20a2 4.7fd lsd kpro
