Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-18-2003   #1 (permalink)
KaZeLL
Ultimate Member
KaZeLL's Avatar
KaZeLL will become famous soon enough
Send a message via AIM to KaZeLL Send a message via MSN to KaZeLL
One Vehical Problem Solved
ok. Not to long ago i posted a problem i was having with my civic. When i would drive the car 4 about 20 min or so under above normal driving conditions( 5000 rpms or higher ) and shut the sucker off for longer then 20 min or somtimes didnt even have to shut it off just let idel or cool the next time i tryed to reach above 4000 rpms the car wouldnt let me. It would bog in every gear at 4000 rpms.
Only after reseting the brain via the fuse under the hood would it go back to normal (well semi normal). Also before the car would act up it would give you a warning that it was about to do so....I would notice a lag or a feeling of somthing holding me back from 1 - 5000 rpms, after 5000rpms the damn thing would take of like if turbo kicked in. Needles to say this pissed me off big time...
I took it to honda since they claim to know it all when it comes to their cars and to my suprise they couldnt tell me a damn thing. They took a reading of the codes and the best thing they could tell me was it doesnt make sence....( what doesnt make sence i asked? ) the codes it's a bunch of jiberish <------" their exact word " . since you have a these high performance mods ( headers, intake, exhaust, N20 ) you should try taking it to a speed shop...
Well after that i did, to 2 actually and they never hurd of that problem.....
Well now I'm really pissed so i took it home and was going to rip the whole thing apart myself since no one could fix it ,WHAT HARM COULD I DO. After about 20 min or so of inspection i notice i had a exhaust leak ( no biggie ) not enough to make the car act like that....the motor was dirty a little....Humm..well
LETS CHECK OIL!!!!! WTF.......NO F'N OIL......AT ALL...!!!!!..so i added 3 1/2 qts
well it turns out that the car has a sencer or somthing that limits the use of the vehical if their is no oil, a safty messure i guess...glad to have actually..Not to sure how low the oil has to be to kick on this safty mecanism but you'll know because you'll feel it in the pedal.....
You might be asking yourself " what about the oil light" well it never came on....why i dont know maybe the bulbs burnded out, i dont know i have to check.... " where did all the oil go"? that i do not know since the car is running fine and not smokeing, leaking or anthing like that, i need to do a compression test to figuer that part out still ...but what i can tell you is that HONDA was the last to do my oil change, maybe they didnt put oil in....3 months ago! you would think they would check everything if you bring it in and are having a problem with it, you know filters, gas, hoses ......OIL!!!!
The last time i took it there the forgot to tighten the oil cap...guess what happen then....oil evry where...
Well hope this helps you out if you come accross this problem.
__________________
jazell26@hotmail.com
If you need me
KaZeLL is offline   Reply With Quote
Sponsored Links
Old 02-18-2003   #2 (permalink)
mohawkboom
Post Master General
mohawkboom's Avatar
Send a message via ICQ to mohawkboom
Maybe they did knowing you run N20...not put in any oil..that way you'd blow your engine..not under warranty because of the N20 and hope you'd buy a new one from them?
Either that or 5000Rpm+ Driving consumed up the oil..
High RPM driving allows more oil to pass the rings and evaporate with that heat and leak out youtr PCV
mohawkboom is offline   Reply With Quote
Old 02-18-2003   #3 (permalink)
Drnknmnky13
Diamond Member
Drnknmnky13's Avatar
Send a message via AIM to Drnknmnky13 Send a message via Yahoo to Drnknmnky13
Gotta love Honda techs. They told me a rattle from the INTERIOR of my car was caused by my lowering springs..therefore not under warranty. Anyway as far as checking the oil light, turn the key to the on posistion but dont start the car. All the idiot lights (ABS, oil, seat belt, etc..etc..) should turn on for a few seconds. Hope this helps.
Drnknmnky13 is offline   Reply With Quote
Old 02-18-2003   #4 (permalink)
kjgracing
Hail to the king baby
kjgracing's Avatar
kjgracing will become famous soon enough kjgracing will become famous soon enough
just a thought...
Maybe these forums should have spell check or something...
I have no idea what you are trying to say here
Quote:
Quote
[hr]Well after that i did, to 2 actually and they never hurd of that problem.....[hr]
kjgracing is offline   Reply With Quote
Old 02-18-2003   #5 (permalink)
slowride
Member
slowride's Avatar
slowride is an unknown quantity at this point
You should check your oil after every oil change unless you change it yourself.
slowride is offline   Reply With Quote
Old 02-19-2003   #6 (permalink)
philliesblunt420
Super Member
philliesblunt420's Avatar
philliesblunt420 is an unknown quantity at this point
Let me get this straight....you took your car to Honda and 2 speed shops and no one bothered to check the oil??![IMG]i/expressions/face-icon-small-nono.gif[/IMG]
philliesblunt420 is offline   Reply With Quote
Old 02-19-2003   #7 (permalink)
MangoEX
Just Be
MangoEX's Avatar
MangoEX should not be trusted
Send a message via AIM to MangoEX
Seriously dude... your "english" (if you want to call it that) has to go. There's no excuse for that kind of spelling. None at all.
MangoEX is offline   Reply With Quote
Old 02-20-2003   #8 (permalink)
KaZeLL
Ultimate Member
KaZeLL's Avatar
yup, no one checked the oil, can you belive that...my car sat at the dealer 4 3 days, and they said they checked everything out, and couldnt find any problems with the car. kinda shady if you ask me....
I forgot about the idiot lights going on when you click it once what an idiot i am...lol.
Not going to that dealer anymore...
Old 02-20-2003   #9 (permalink)
jiggerachi
Zoom zoom
jiggerachi's Avatar
jiggerachi will become famous soon enough
My 87 civic hatch acted just like that b4 it blew due to a mad oil leak & me being 17. Maybee thats just what happens & u got really lucky, I dont think my 87 had any safety stuff like that, maybee it did???[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
jiggerachi is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
