Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-05-2002   #1 (permalink)
Grey
DIY King
Grey's Avatar
Grey has a spectacular aura about Grey has a spectacular aura about
Send a message via AIM to Grey
DIY: SPC Front Camber Kit
First off, you may want to read this: Honda Project Car: Front Alignment
Then you may want to read the instructions printed on the back of the box.
If you didn't get the original box for some reason, then here you go:
The first step is to jack up the car up front. Look under the car for an arrow on the plastic. It points to the reinforced piece of metal that can withstand the force of the entire front of the car on it. Just it up under this point. You can do each side at a time, but I wanted to do both sides at once for comparison. Jack it up so that the tires are still on the ground. Then unbolt the lug nuts. Then jack it up all the way and put jack stands under the sides of the car. Then take off the wheels.
Follow the directions to start up your compressor. Of course, you can just remove the upper strut-spindle bolt using a large wrench. I assumed that it would be hard to do with just a regular wrench, so I broke out the big guns (the impact wrench that is). Use 'em if you've got them I guess...
Then hook up the accessory hose and the impact gun and set the pressure to about 100psi. That pressure setting worked for me anyway. Then Just use a 19mm socket; although a regular socket will work, one that is specially made to be used with an impact wrench is preferable. Always wear safety glasses! I did.
Now, I did not set the camber myself. I guess it could be done by parking in a level garage and using a square, but this would be pretty time consuming. I was in an accident and I curbed my rims and I haven't had an alignment yet, so I think it's time to get one anyway. I basically did what the instructions told me, but I did not loosen the lower bolt. Instead I rotated the camber bolt all the way clockwise and the large tab all the way counterclockwise until I could not rotate it any further by hand. Do not use too much force or you'll actually be changing your camber.
I chose to put in the bolt sort of symmetrically aligned to the lower bolt, but it's the other way around in SPC's DIY (shouldn't matter which way it goes though). I then held the bolt with one wrench and the nut with a torque wrench. The socket for the nut is 18mm; I had to buy it since I didn't have one in my socket set. I set the torque according to what was on the box (77 foot pounds). I tightened everything up and put the wheels back on and took it for a test drive. Nothing changed, just as it should be (since I just wanted to install the camber kit for the alignment).
Grey is offline   Reply With Quote
Sponsored Links
Old 10-05-2002   #2 (permalink)
allURbaseRbelong2us
Member
allURbaseRbelong2us is an unknown quantity at this point
grey = god
__________________
Somebody set us up the bomb!
allURbaseRbelong2us is offline   Reply With Quote
Old 10-06-2002   #3 (permalink)
Tiki
Senior Member
Tiki's Avatar
Tiki is an unknown quantity at this point
Send a message via AIM to Tiki
Grey DIY GOD[IMG]i/expressions/beer_yum.gif[/IMG]
__________________
Tahitian Green 91 Si
I/H/E and some extra goodies
Coming Soon: Project Boost
Tiki is offline   Reply With Quote
Old 10-16-2004   #4 (permalink)
nindoo
Why is my vagina bleeding?
nindoo has a spectacular aura about nindoo has a spectacular aura about
Grey the pics and link aren't working.
nindoo is offline   Reply With Quote
Old 10-16-2004   #5 (permalink)
Mr.Modify
Mr.Modify's Avatar
Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all
Send a message via AIM to Mr.Modify Send a message via Yahoo to Mr.Modify
u can always use this
http://www.spcperformance.com/PerfTe...rojHon1_E.html
__________________
DIY SIGNATURE POST....
NO engine mods... SWAP or TURBO .....nothing less!!!!!
-Akia's the name and civics the game!!
Mr.Modify is offline   Reply With Quote
Old 10-20-2004   #6 (permalink)
nindoo
Thanks
Old 10-21-2004   #7 (permalink)
4drcivic2k1
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1's Avatar
4drcivic2k1 is an unknown quantity at this point
Quote:
That post is 2 years old.
4drcivic2k1 is offline   Reply With Quote
Old 10-21-2004   #8 (permalink)
Grey
DIY King
Grey's Avatar
BTW, I'll be fixing all of my DIY pics soon. Stay tuned...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
