Go Back   Honda Civic Forum > GENERAL > Honda Civic DIYs and Civic Tech Chat
Honda Civic DIYs and Civic Tech Chat Honda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-06-2002   #1 (permalink)
Grey
DIY King
Grey's Avatar
Grey has a spectacular aura about Grey has a spectacular aura about
Send a message via AIM to Grey
DIY: E-Brake Adjustment
What time is it? It's DIY time! That's right kiddies, the DIY Whore is at it again! This time we learn how to take up the slack in the emergency brake. [IMG]i/expressions/laugh2.gif[/IMG]
Seriously though, that's what I felt like DIYing. I already did this DIY a while back, but at the time I didn't have a digital camera handy. Now I do, plus it's bean some time since the last time I did this, so I felt like checking up on things.
Tools:
- phillips head screwdriver
- small wrench
- jack
First push down on the shift knob collar. Your shift knob might look different. This happens to be the base model RSX shift knob.
Then unscrew the shift knob.
Then pry up the emergency brake cover. Use lots of force and pry straight up.
Turn it around and look for any missing clips. Sometimes they fall off when taking this piece off. Find them and put them back on that piece. Notice my blue sound deadening material. That's not stock.
Unscrew two little screws under the piece that we just took off.
Move the chairs forward and unscrew two other screws in back.
Now pop out the little plastic clips holding the front. Reach under them and play with them a little. You'll like it! Hehe, no. Actually, reach in back there and make the middle of it pop out.
That large piece is now ready to come off. Just pull it out at an angle to the front. Make sure to clear the e-brake handle. Then just pull it out towards the rear of the car.
Jack up one rear wheel and lower the emergency brake. Make sure the car is on level ground and in first or reverse, so that it does not start to roll. Put sand bags around the front tires as an extra safety precaution if you'de like (anything heavy will do). Then try spinning the wheel with your hand. Wee! Watch it go.
Now, if your wheel spun in the previous step it's time to take up the slack in the emergency brake cable. If you can not spin your wheel, then you might want to consider giving the emergency brake a little more slack. Just tighten it like a screw with a wrench. Tighten a little and test out if the wheel still spins freely. Do so until you're happy with the results. You don't have to do the other side because the two cables are on a sort of scale like attachment that distributes the force applied to the cables evenly. One sides adjustment will equal the others.
Now enjoy the better feel of the emergency brake. My stops on hills have improved. Not because I made the emergency brake sptronger or anything, but because I don't have to pull up on it as much as I used to. My hand sits lower when it is pulled up all the way, so I have better leverage.
Grey is offline   Reply With Quote
Sponsored Links
Old 08-06-2002   #2 (permalink)
01civicboi
Ultimate Member
01civicboi's Avatar
01civicboi is an unknown quantity at this point
ooohh. project for tomorrow
01civicboi is offline   Reply With Quote
Old 08-06-2002   #3 (permalink)
speedracersong
speedracersong's Avatar
speedracersong is a jewel in the rough speedracersong is a jewel in the rough speedracersong is a jewel in the rough speedracersong is a jewel in the rough
Send a message via AIM to speedracersong
yay. nice diy.
i havent done a diy in awhile.
speedracersong is offline   Reply With Quote
Old 08-06-2002   #4 (permalink)
silverdevil
Ultimate Member
silverdevil's Avatar
silverdevil is a glorious beacon of light silverdevil is a glorious beacon of light silverdevil is a glorious beacon of light silverdevil is a glorious beacon of light silverdevil is a glorious beacon of light silverdevil is a glorious beacon of light
What's your mileage dude? I have 8k and still no slack in my e-brake at all.
But good project for when I do. Thanx for the DIY, you whore![IMG]i/expressions/laugh2.gif[/IMG]
silverdevil is offline   Reply With Quote
Old 08-06-2002   #5 (permalink)
Grey
DIY King
Grey's Avatar
First time I did it I had 5k or something like that. Now I have 10k. There was some slack this time as well... [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old 12-01-2003   #6 (permalink)
taz757
taz757's Avatar
taz757 has much to be proud of taz757 has much to be proud of taz757 has much to be proud of taz757 has much to be proud of taz757 has much to be proud of taz757 has much to be proud of taz757 has much to be proud of taz757 has much to be proud of taz757 has much to be proud of taz757 has much to be proud of taz757 has much to be proud of
Send a message via AIM to taz757 Send a message via MSN to taz757
Not to diss on your DIY as it's a good idea, but sometimes it's not the cable that's the problem.
If you wanna go at it, you basically take off the rear wheels, knock off the cover on the drum, and there's a little adjustment nut on the spring for the shoes. You move it in and out as to how close you want the shoes to the inside of the drum.
I'm not knocking this. It's a good idea, but also take a look at your shoes. Might not be a bad idea to do them both at the same time.
__________________
taz757 is offline   Reply With Quote
Old 12-01-2003   #7 (permalink)
Connie
Abercrombie And Fitch
Connie's Avatar
Connie is a jewel in the rough Connie is a jewel in the rough Connie is a jewel in the rough
Send a message via ICQ to Connie Send a message via AIM to Connie Send a message via Yahoo to Connie
nice CHEAP diy....thanks!
Connie is offline   Reply With Quote
Old 12-01-2003   #8 (permalink)
civicvtec1ps
Search and Learn
civicvtec1ps's Avatar
civicvtec1ps is just really nice civicvtec1ps is just really nice civicvtec1ps is just really nice civicvtec1ps is just really nice civicvtec1ps is just really nice
Send a message via AIM to civicvtec1ps Send a message via MSN to civicvtec1ps Send a message via Yahoo to civicvtec1ps
Very easy DIY.
I did it when i was installing new shifter bushings.
__________________
2008 Chicane S2k (5-01 08 Project Begins)
civicvtec1ps is offline   Reply With Quote
Old 12-01-2003   #9 (permalink)
dirtySAMURAI
Formerly Known as infinite012
dirtySAMURAI's Avatar
dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all dirtySAMURAI is a name known to all
Send a message via AIM to dirtySAMURAI
how the hell did you get the center console out? my arm rest keeps getting in the f***ing way...
dirtySAMURAI is offline   Reply With Quote
Old 12-01-2003   #10 (permalink)
civicvtec1ps
Search and Learn
Quote:
That should help.. Why cant you get it out though? You dont even need to take out arm rest to take out center console..
__________________
Old 12-02-2003   #11 (permalink)
Da1lyDr1ver
Platinum Member
Da1lyDr1ver has a spectacular aura about Da1lyDr1ver has a spectacular aura about
Send a message via AIM to Da1lyDr1ver
the way i did mine is i jacked up the rear of the car and took off the drum cover. then i looked for the little bolt thats on a screw-like-cylinder and spun the screw clock wise or counter clockwise (i forgot which way). this does the same thing to your e-brake without having to take off your center console.
Da1lyDr1ver is offline   Reply With Quote
Old 06-13-2004   #12 (permalink)
civicstyle82
7thGen Junkie
civicstyle82's Avatar
civicstyle82 is a name known to all civicstyle82 is a name known to all civicstyle82 is a name known to all civicstyle82 is a name known to all civicstyle82 is a name known to all civicstyle82 is a name known to all civicstyle82 is a name known to all civicstyle82 is a name known to all
Send a message via MSN to civicstyle82
After months of procrastinating I finally went out and did this last night, so easy and it's nice having an e-brake that doesn't end up in the back seat when you pull it up.
__________________
Puerto Vallarta Pictures
civicstyle82 is offline   Reply With Quote
Old 11-06-2004   #13 (permalink)
SpeedFreak
Senior Member
SpeedFreak's Avatar
SpeedFreak is an unknown quantity at this point
Send a message via AIM to SpeedFreak
I'd really love to do that but i cant see any of the pics for some reason?
SpeedFreak is offline   Reply With Quote
Old 11-06-2004   #14 (permalink)
streetglower
7thGen Junkie
streetglower's Avatar
streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all
Send a message via AIM to streetglower
that seems like alot to do for just the adjustment. Everytime I had mine adjusted at a shop, it took them less then 5 min.
streetglower is offline   Reply With Quote
Old 11-07-2004   #15 (permalink)
Grey
DIY King
Grey's Avatar
I will re-post all of my DIY's with updated pics soon. The shop probably adjusted them in the rear. You can do that too, but I haven't been able to locate the screw we supposedly turn to tighten things up.
Tags
2001 , adjustment , arm , brake , civic , ebrake , emergency , fell , honda , install , knob , rear , rest , spin , turn
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
ALL of Grey's DIY's...
DIY: Trunk Shocks
Detailed smoked out taillights DIY w/ pictures
Oil Changes
DIY: tricked out trunk
DIY: No More Trunk Rattle!
SOHC VTEC Explained
DIY: Grounding kit Install
Need help with Radio Code
Site Supporters
aluminum radiator
Honda car spoilers
