Honda Civic DIYs and Civic Tech ChatHonda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
I dont know what i am screwing up here, but i could use a little help. I replaced the axle shaft this afternoon and drained the fluid. I cant feel any in the check plug anymore, but when i pour fluid back in through the check hole (funnel + hose) it pours right back out. Am i missing something here? am i pouring into the wrong place?
how much gap is left between the inboard end of the drive shaft and the differential. I didnt take note how much was originally was there, but now it seems to be about 1/4 -1/2 cm on the generous side..
Sponsored Links
http://www.hondapartscheap.com/south...t=0&quantity=0
On this picture (what mine is) #12 at the very bottom is the square-drive drain plug. #17 just aft of the cv joint is the check/ fill bolt. No other square-drive ones on mine. The cv joint is about 4 or 5 mm away from differential case.
