Honda Civic DIYs and Civic Tech ChatHonda Civic DIYs and Civic Tech Chat - for the true gearheads! Bring your wrench, it's time for some Honda Civic DIY projects! Questions about problems with your car do NOT go here.
Welcome to civicforums.com!
Welcome to civicforums.com.
I don't know, it just has this growl to it at high rpm while gasing it. My auto DX did not sound like that. The engine sounded smooth through its whole range. When the car is idling, I can hear what sounds like something loose in the valve area --like something is shacking, but not like a loose bolt. It sounds like the valves themselves as if something is "wobbling," and I'm certain nothing is loose in the outside area. I'm not experiencing clicking and my valves clearances are all within spec. At high rpm I hear the same noise but in different form.
Could it be a bent push rod?
our 92 accord is leaking trans fluid from the axle seals but the car is worth less than what the repair costs so we just keep an eye on the fluid. its only dripping tho not pouring out. usually it loses an ounce a month. its just messy on the street lol. unless something badly needs to be fixed, i say dont waste $$
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
are you keeping enough transmission fluid in your transmission like you should be?
Why is it that honda added a dipstick for the auto 6th gens but not the manual? That's lame. Any way, the current fluid in there is honda MTF which I put in 4000 miles ago (It's good for 15k). During that 4000 miles, I drove the car from Reno to Phoenix which is like a 14 hour drive back and forth. By the time I got down there, my fluids in the engine and trany were like water it felt. In fact I was like "oh shit, am I running on low engine/trany oil?" Which I wasn't.
I do wonder if there is currently not enough trany fluid in there. Where the hell could it go? Does it go out as gas? I will go check now...
How much are they charging for the job? That's really easy to fix, except for the ball joint removal the first time. I still haven't found an easy sure-fire way to do it. The NAPA ball joint seperators are a joke. The craftsman ratchet trick looks promising.
Yeah I figured it out. You're right gearbox, most people do fall under the severe catagory. Under that chart, it's an oil change + filter every 3750 miles or 6 months. After that trip my engine oil is really thin and worn out causing the noise.
Also, trany fluid is every 30k for severe, not 15k like I said.
yeah if you went on a long trip, the oil and trans fluid needs to be changed asap, even if you just changed it before you left. trans fluid is prolly dark black, oil isnt doing great either because the constant hi temps sheared it down to nothing. trans fluid i would say 10-12k is the max with normal driving, but if you go on road trip, you need to change it when you get back. fluids are severely broken down and usually mine come out black like its been there for 20k miles just after one long trip. i never understood hondas reasoning behind the 30k trans fluid change. at 18k when my car was almost new, i had the fluid changed early and it came out pure black with all sorts of chunks. if engine oil you change every 5-10k, trans fluid should be the same. it is just oil afterall and the trans works as hard or harder than the engine.
__________________
Member 1025782
I've never seen my fluid nor my friends fluid anywhere near dark. He did a change at 55k miles on his subaru 5-speed for the first time, and it was clear, almost like new. Unless auto's are different, that leaves me scratching my head as to why you're getting black fluid (with chunks!) coming out. You are driving with one of the problematic civic trany's, so maybe something is being eating up?
As for engine oil, mine wasn't bad when I changed it yesterday. On the dipstick it was a clear and tan color. When it was drained it was dark but it's the thinness that was the problem--too many hard miles on it, should have been changed after the trip like you said.
Any way, I'm going to change the trany fluid too. Am I wasting my money buying the honda stuff? I could just be using 10w-30...
ya true, and autos do use up fluid much faster. honads recommended manual change is 60k miles, and 30k for autos. for auto trans you must use the honda stuff or you will have very rough shifting. its worth it, even once a year you only spend $24 for 3 bottles.
__________________
Member 1025782
Well you guys were right, it was my MTF. It's was very thin and dark. I replaced it with some ford motorcraft 10w-30 semi synthetic. I will try 10w-30 synthetic next time. I like to expiriment.
