| Re: 97 civic sedan help There is a similar thread about doors not opening up. If at all possible, take off the door panel so you can take a look inside and you may need to "spray some silicone lubricant" (Gearbox). Otherwise did you check if the rear doors are unlocked? Maybe there is something stuck with the lock or you have the child safety on... About your window, check the fuses first and then take apart the door panel again and check out the motor and such. |
